4 Bangin, Fuel Sippin, Full Tank Challenge!
Discussion in '4 Cylinder' started by 2TRunner, Aug 29, 2011.
  1. Jun 10, 2012 at 8:41 AM
    #481
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    447.7 miles on 16.487 gallons for an average of 27.2 MPG. Not bad for a lot of hauling and working the truck.
  2. Jun 10, 2012 at 3:03 PM
    #482
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Good tank Andrew, is that figure corrected upward for your larger tires?
  3. Jun 10, 2012 at 5:44 PM
    #483
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    No. I should add another 8% to the overall miles traveled. So 483.5 miles on 16.487 gallons for an average of 29.32 MPG. :)
  4. Jun 10, 2012 at 6:18 PM
    #484
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Wow.
    Some of you guys are seeing a HUGE difference between winter and summer gas.
    In my case, California runs highly oxygenated gas all the time, but I'm seeing my MPG drop by around 2mpg compared to early spring.
  5. Jun 13, 2012 at 2:40 PM
    #485
    91r100gs
    Dan
    Kansas City area
    Filled up today to beat 15¢ increase. 323.7 miles-11.945 gallons-27.1 MPG 4th tank in a row of 27+MPG.
    Let's keep up the great tanks.
  6. Jun 13, 2012 at 3:20 PM
    #486
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    Rich,
    The Winter gas here hurts the FE but not as much as the cold winter air. Now that things are warming up (and we're back to Summer gas), the MPGs are climbing. That said, on warmer days in the winter, I would see improved MPGs but just not as high as I see with the better fuel and warmer weather of Spring/Summer.
    Kevin
  7. Jun 14, 2012 at 6:33 AM
    #487
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    Just filled up my 4x4 reg cab with auto trans and 265/70/16's this morning. Got 21 mpg and I do all city driving! Very pleased.
  8. Jun 16, 2012 at 7:55 PM
    #488
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Filled up today 614 miles on 18.980 gallons for 32.3 mpg.
    A little quicker than usual, put on 200+ miles for work including hauling 2 welders and an axxair pipe cutting bench that stuck well over the top of the cab for over 100 miles. Obvious increased wind drag, didn't exceed 30 mpg that trip, which usually would have been 36.
    Sorry for the whining. :cheers:
  9. Jun 17, 2012 at 4:46 PM
    #489
    91r100gs
    Dan
    Kansas City area
    Great tank Worthywads
  10. Jun 18, 2012 at 5:34 PM
    #490
    91r100gs
    Dan
    Kansas City area
    Nice tank Litegide
    I find that my method of topping off nets about one more gallon going in. It gives me the most consistent readings. 90% of the time I fill at the same station and same pump. This also seems to help the consistency factor.
    Keep on truckin'
  11. Jun 18, 2012 at 5:50 PM
    #491
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Modern fuel pumps are quite accurate. Considering the high price of fuel, if the pump were to be incorrect, it will pimp slightly less volume than the display reads. The gas stations are not going to be pumping extra gas into your tank. This is only going to make your fuel economy seem even better. Plus the difference from pump to pump may only alter your calculations by .1 MPG or less.
  12. Jun 18, 2012 at 6:19 PM
    #492
    91r100gs
    Dan
    Kansas City area
    Andrew,
    The main reason I use the same pump all the time is the angle at which the truck sits, giving the pump the same backpressure from the tank at each fill. You bet that the pumps are not going to give you too much. In Missouri the Weight and Measures Dept requires it be accurate to within 2 cups. Lots of fudge factor there IMO
  13. Jun 21, 2012 at 1:22 PM
    #493
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I like where your heads at. ;)
    BTW, I didn't fill up today...but my light came on at 440 miles which should average out to 25.5 MPG or so.
  14. Jun 21, 2012 at 5:58 PM
    #494
    Rich91710
    Rich
    Los Angeles
    08 Base
    Similarly rolling on a "happy" tank right now.
    I'm at about 255 miles on this tank and Ultraguage says I've got another 270 to empty... says average is 25.7, and I intentionally have the calibration set a smidge high to be on the conservative side, example, Ultragauge will say 24.7 on a tank and Fuelly shows 24.9 to 25.
    The average on the UG was sitting on 26.1 when I got to work this morning, but afternoon traffic killed it.
  15. Jun 24, 2012 at 7:53 AM
    #495
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    457.8 miles on 18.063 gallons of fuel for an average of 25.3 MPG.
  16. Jun 26, 2012 at 3:53 PM
    #496
    91r100gs
    Dan
    Kansas City area
    Filled up with 499.1 miles showing and used 18.83 gallons. 26.5 MPG Probably using A/C 70% of the time. Not bad. This week will probably be 100% We have a heat wave starting here.
  17. Jun 27, 2012 at 6:23 PM
    #497
    Rich91710
    Rich
    Los Angeles
    08 Base
    First pic taken when I got to work this morning :D
    Second when I got home tonight :(
  18. Jun 29, 2012 at 6:04 PM
    #498
    Motor96
    Motor96 Well-Known Member
    Joe
    Ca
    Man how are you guys getting these #s? I have an 06' access cab and just filled up today barley getting 350 17.5 gallons. half city/hwy
  19. Jun 29, 2012 at 10:18 PM
    #499
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    21.9 mpg on my first full tank out of my 22R-E
    Should be up after swapping some parts and even more after regear
  20. Jul 2, 2012 at 6:16 PM
    #500
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ultragauge, cost is around $65 shipped, it plugs directly into the OBD-II port.
    I fabricated a bracket to mount it to the mirror stem.
