4 Bangin, Fuel Sippin, Full Tank Challenge!
Discussion in '4 Cylinder' started by 2TRunner, Aug 29, 2011.
  1. Aug 1, 2012 at 6:31 PM
    #541
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    Yes. Especially north of the boarder, with the synthetics, the cold morning starts are lots easier. Here in New England, there are a few mornings where I was glad to have it in there. Plus the overall benefits of reduced wear and performance, makes the extra expense justified in my opinion.
  2. Aug 1, 2012 at 6:40 PM
    #542
    2004 2.7l
    2004 2.7l Active Member
    craig
    southern new brunswick canada
    i was wondering the same....went 375m never seen it come on:confused:....well next oilchange..synthrtic itis
  3. Aug 9, 2012 at 4:23 PM
    #543
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    You made 500. :D Damn good.
    I don't run my A/C much but I have been surprised when I do that it doesn't hurt too bad. I could do a test with the scangauge but haven't bothered.
  4. Aug 9, 2012 at 4:28 PM
    #544
    2TRunner
    2TRunner [OP] Snoop Dad
    My House Usually
    Great tank for me this last time around!
    395ish when the light came on. Irritated that I couldn't get the 4.
    Rough estimate...23?? Still pretty darn good for what I've got going on. Fill up tomorrow, had to drive around with the light on for a bit this afternoon. Price is gonna be killer, MPG should a little higher than usual.
  5. Aug 9, 2012 at 5:56 PM
    #545
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Same here.
    Traffic hurts my mileage more than the AC.
    Even mythbusters confirmed that having the AC on is more efficient than windows down.
  6. Aug 9, 2012 at 10:06 PM
    #546
    Pinoiako916
    Pinoiako916 Well-Known Member
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    on 8-8-12, I traveled from LA to Citrus Heights,CA on a single tank of gas, I averaged 70 mph and had the A/C on the whole time.
    How common is it for a 2.7l to have 400 miles per tank?
  7. Aug 10, 2012 at 12:25 PM
    #547
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    453.3 miles on 18.252 gallons for an average of 24.8 MPG...too much traffic. :(
  8. Aug 10, 2012 at 4:55 PM
    #548
    Rackster
    Kevin
    Connecticut
    For stock vehicles, I'd say pretty common. Regular Cab, 5 lug trucks with manual transmissions do it with ease. Tougher as you add 4 wheel drive, auto tranny, and a Double Cab (adding weight). Of course, better MPGs at lower speeds, fewer stops, flatter terrain and warmer temperatures. Some pretty impressive numbers posted in this thread!
  9. Aug 10, 2012 at 5:04 PM
    #549
    02TACOMA4WD
    02TACOMA4WD Well-Known Member
    02 Tacoma TRD 4x4
    240 miles on 18 gallons.... 13 mpg. Bad driving habits and 33 inch tires
  10. Aug 10, 2012 at 5:48 PM
    #550
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Did a short fill the other day and my MPG dropped to 25.4, 219.8 miles gallon of 87 octane. Traffic and more short trips of 4 miles or less. Still hot as Megan Fox around these parts. May your A/C keep working.
    Happy motoring my friends:burnrubber:
  11. Aug 10, 2012 at 6:35 PM
    #551
    2TRunner
    My House Usually
    Good estimate.
    Pulled to the pump with 392.7
    Factoring tire/mile discrepencies, thats 431.97
    On 18.15 gallons.
    For 23.8 MPG
    On 30's!!!
  12. Aug 10, 2012 at 10:13 PM
    #552
    Rich91710
    Rich
    Los Angeles
    08 Base
    Easy, depending on how low you want to run the tank.
    I typically refuel at about 350-360 miles and take in the ballpark of 14 gallons.
    14 gallons... I still have 6 left, 5 comfortably... I could comfortably get 460 miles even on a "poor" MPG tank.
    My Ultragauge regularly estimates 500 miles to empty.
  13. Aug 10, 2012 at 10:18 PM
    #553
    Rich91710
    Rich
    Los Angeles
    08 Base
    Keep in mind that your 33" tires make it look worse than it is.
    If you have a Prerunner and did not regear, you're over 5 miles off for every 65... so 240/65=3.69.... 3.69*5=18.45.
    You actually went closer to 260 miles for 14.4mpg
  14. Aug 11, 2012 at 3:16 AM
    #554
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Does anyone run 285/70/17 or 285/75/16 in a good street or light tread tire like Dueler Revos or something and have their MPG difference? I had great MPG with my 265/65/17 Dueler stock tire but then lost a chunk when going to the 265/70/17 BFgoodrich TKOs. I'm thinking about getting a set of 285/70/17 Revos and I'm wondering if I will see the same MPG?
  15. Aug 11, 2012 at 5:16 AM
    #555
    Rackster
    Kevin
    Connecticut
    Tires can make a big difference. A more aggressive tread pattern will not yield as good MPGs as a highway rated street tire. I saw a loss when switching from Firestone's to Dueler A/T's years ago. But with a RWD Ranger, I wanted more bite for the snowy days. Size and inflation are other factors to consider.
  16. Aug 11, 2012 at 9:58 AM
    #556
    Rich91710
    Rich
    Los Angeles
    08 Base
    This.... Don't forget about the calibration errors introduced, as I mentioned above when going to 33" tires.
    The 265/65-17 to 265/70-17 wasn't a huge difference, but it still introduced a math error of about 3.3%... for every 100 miles on the odometer, you actually went 103, and your MPG calculation will reflect that.
    Moving up to 285/70-17 will push that error up to almost 7%...
    Calculated 18mpg would actually have been a hair over 19.
    So when MPG drops due to new tires, don't freak... look at your fueling history. For me, 4 trips to work and back is in the ballpark of 14 gallons.
    If I change tires and now I'm only making 3 trips for 14 gallons, then I know I lost a huge bit of MPG, but if I'm still making 4 days and 14 gallons, then whether the odometer says I went 350 or 250 miles, I'm actually unchanged.
    Larger tires are a blessing and a curse. At conservative highway speeds (55-65), they can help mileage by lowering the final drive ratio... basically give you two overdrives.
    But you have to get that moving, so the lower ratio will hurt your around-town mileage and performance.
    Regearing will restore the proper ratio and bring the speedo calibration back... but you still need to consider tire/wheel weight, tire width, tread pattern, inflation, etc.... All of these things impact mileage.
  17. Aug 12, 2012 at 5:29 PM
    #557
    91r100gs
    Dan
    Kansas City area
    Filled up today. 372.0 mi - 13.475 gal = 27.6 MPG My best ever on a fillup that was greater than a half tank. :woot:
  18. Aug 13, 2012 at 5:15 PM
    #558
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Well done! :cool:
  19. Aug 15, 2012 at 8:25 AM
    #559
    Carper87
    Carper87 Member
    Tony
    Missouri
    2007 DCSB super white sport
    That's what I am getting so far working on keeping my foot out of it and driving a little better
    This is with an 06 access cab
  20. Aug 15, 2012 at 11:31 AM
    #560
    worthywads
    Not ready to fill up yet but I had to tease with the latest shot from just after the gas light came on. :D Could be a 35mpg Tank. Could make it to 700 miles if I wanted to.
