4 Bangin, Fuel Sippin, Full Tank Challenge!
Discussion in '4 Cylinder' started by 2TRunner, Aug 29, 2011.
  1. Sep 1, 2011 at 7:30 PM
    #41
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
  2. Sep 1, 2011 at 9:33 PM
    #42
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I wanted to try that, but I didn't want to loose power steering and run into something.
  3. Sep 2, 2011 at 2:34 AM
    #43
    dan0
    dan0 Well-Known Member
    swamplands of sc
    Sold 2011 Prerunner Doublecab 4cyl auto
    22.7 best mpg so far over 400miles per tank avg
    documented below
  4. Sep 2, 2011 at 5:31 AM
    #44
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    You forgot to add, "drive like you have an egg between your foot and the gas pedal! :D
    I guess I could be better based on this list, but I still do not see above 25 mpg even if I improve in areas I can?
  5. Sep 2, 2011 at 6:46 AM
    #45
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Try it, somewhere where you can hit anything. You'll find it isn't like you can't steer, just takes a little more effort at slow speeds. And for the power brakes you still have 2-3 emergency stops of vacuum left before it also gets more difficult, but even with no power brakes you can stop.
  6. Sep 2, 2011 at 8:27 AM
    #46
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Hahaha...:D
    I think the 3k shifts and short trips are causing most of your mileage woes.
    I'll give it a try on the highway at 1 AM or something so no one will be anywhere near me.
  7. Sep 2, 2011 at 9:10 AM
    #47
    worthywads
    Really it's not that different, just click back from run to acc, wait 3-4 seconds while shifting into neutral, then click back to run and release the clutch. And coast away, check how the steering feels, slam on the brakes a few times and see when the power goes out.
    Your engine is just a quick bump start away, shift into 4th or 5th and pop the clutch momentarily and you are running again.
  8. Sep 2, 2011 at 7:22 PM
    #48
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    Sounds like your setting someone up for a butt ram if they are not careful or not understanding your procedure? :eek:
  9. Sep 2, 2011 at 8:36 PM
    #49
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I know how to do it...I'll just wait to try it when no one else is around.
  10. Sep 2, 2011 at 10:28 PM
    #50
    worthywads
    Just didn't want you turning the key to off and locking your steering wheel. ;)
  11. Sep 3, 2011 at 5:55 AM
    #51
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Hahaha...yes, that would be very bad. :p
  12. Sep 5, 2011 at 4:52 PM
    #52
    2TRunner
    2TRunner [OP] Snoop Dad
    My House Usually
    Mmkay, here is the 1st trip tik pic
    376.4 Miles.
    I got slightly bigger tires that throw that off a little.
    (The math is 1:1.05)
    So, 376.4x1.05
    395.22 miles til the light came on.
    I went further, I was on the way to pick up a bunk bed for my daughter, then had to quickly find a gas station.
  13. Sep 5, 2011 at 4:58 PM
    #53
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    Just curious . . .different gens have different size tanks . . :notsure:
    I'll be posting soon. :cool:
  14. Sep 5, 2011 at 5:36 PM
    #54
    2TRunner
    My House Usually
    Check your owners manual.
  15. Sep 5, 2011 at 8:20 PM
    #55
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Yes they do.
  16. Sep 5, 2011 at 8:39 PM
    #56
    jzicc86
    jzicc86 Active Member
    jake
    wisconsin
    11 dbl cab longbed trd
    3 inch readylift block lifts, westin bull bar, piaa lights
    uhhhhhh?????????/ 36mpg?
  17. Sep 5, 2011 at 9:28 PM
    #57
    DanglingFury
    Keith
    2006 4Runner 4x4
    I no haz :(
  18. Sep 5, 2011 at 9:31 PM
    #58
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    that's with the A/C running constantly and idling with the A/C on for extended periods.
  19. Sep 6, 2011 at 2:58 AM
    #59
    2TRunner
    My House Usually
    ^ Awesome!!
  20. Sep 6, 2011 at 4:48 AM
    #60
    snowdrifter
    snowdrifter Well-Known Member
    Indiana
    11 SR5 AC 4x4
    On a trip several weeks ago. First tank over 400! Interstate cruising about 70MPH. Ran it right down to E and put it about 18.9 gallons IIRC. Works out to about 21.1MPG. The truck has under 5K miles so hopefully it'll keep going up as it breaks in.
