4 Bangin, Fuel Sippin, Full Tank Challenge!
Discussion in '4 Cylinder' started by 2TRunner, Aug 29, 2011.
  1. Nov 11, 2012 at 9:08 AM
    #721
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    Saw a commercial last night that the new Ram 1500 V6 will get 18MPG city and 25 MPG highway. Do you think that is a bunch of bull ****?
  2. Nov 11, 2012 at 10:40 AM
    #722
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I've heard the 8-speed automatic has a lot to do with that rating, could be legit with good gearing.
    But does it have balls enough for average buyer? I'm happy with my I4 but most here aren't happy with the V6 Tacoma.
  3. Nov 11, 2012 at 12:48 PM
    #723
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    No.
    Lighten the truck enough, and if they're using the same technology that GM is using to shut down cylinders on the highway, that's very possible.
    My buddy's been getting well over 22 highway from his '08 Silverado.. I think he's got the 5.0 but it might be bigger.
    One problem remains. It's still a Dodge.
  4. Nov 11, 2012 at 12:49 PM
    #724
    Rich91710
    Rich
    Los Angeles
    08 Base
    Most here wouldn't be happy with an 8.0 and a 6-71 blower sitting on top :rolleyes:
  5. Nov 11, 2012 at 8:57 PM
    #725
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    What is being described here is 'flow'. In manufacturing, in driving, and life in general, flow is key to optimization. And if folks would just alternate cars from lanes at the merge, everyone will benefit. But too many folks are self-centered, so they will disrupt the flow by cutting someone off. I agree that folks need to consider one another and serve the greater good, even if it's to burn another quarter gallon to help maintain the flow. Suboptimization of the one for the greater optimization of the whole is a good tradeoff.
  6. Nov 14, 2012 at 6:42 PM
    #726
    Rackster
    Kevin
    Connecticut
    OK - colder weather is impacting the MPGs. This is my first Fall/Winter with the Tacoma, so I'm a bit surprised at the losses so far. Only a couple tanks in, but it looks to have dropped about 7%. What's throwing me off a bit is that I've had a few changes on the truck over the past couple of months, including a new aftermarket cat after it was stolen when it was at the garage for an EVAP problem. I'm wondering if the new cat constricts the flow and is contributing to part of my FE losses. I might need to wait until Spring/Summer to confirm that though.
    Getting Summertime FE numbers is next to impossible with the winterblend and cold temperature, so new challenges for the cold months to keep it interesting.
  7. Nov 14, 2012 at 7:13 PM
    #727
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Hitting the highway in the morning. Just filled up a partial so this trip will be my first few readings after the new intake, header n cat back n spark plugs.
  8. Nov 14, 2012 at 8:04 PM
    #728
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Have not seen him on here or on fuelly.com for quite a while now. and his account is closed on fuelly.
  9. Nov 17, 2012 at 8:04 AM
    #729
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    I got the deckplate installed, so I will start getting some data pretty soon. I will post what the startup intake air temperature is and then what the temperature is once I am up to temperature.
    First impressions on the install: see if you can get a 3" deckplate because you have to do a lot more modifications to get it to fit. The stock intake diameter is about 70mm, so 3" is perfect.
  10. Nov 17, 2012 at 10:50 PM
    #730
    2TRunner
    2TRunner [OP] Snoop Dad
    My House Usually
    Time to come clean...
    I've wondered the same myself, a lot, about being able to draw in some of the warmer air that is emitted from the hot engine through the air box. Especially since the airbox is close to the exhaust.
    I've never admitted it on here, but the side of my airbox, the side you did your deckplate on, is littered with holes that I drilled through it. In the idea of trying to draw in some of that warmer air.
    I'm not sure what, if any difference it's made. The intake temp will definitley rise with idle however, thats a fact. I was mostly wondering about the idea for idle temps really, since idling+cold+2TR-FE=shitty MPGs.
    I've even pondered the idea of acutally directly piping in hot exhaust into the airbox. Would be kinda neat to set up some kind of system where a small pipe, is threaded (ie an o2 sensor) into the exhaust somewhere and led back up to the airbox.
    I didn't go the giant hole route, don't want critters/nests in it. Maybe you could cover you're opening with some screen? I also did mine with consideration of water, since I've been in some. I didn't want to just immediately suck in a big helping of H2O, should such a situation arise.
  11. Nov 17, 2012 at 11:40 PM
    #731
    worthywads
    Heated intake was standard on most carburated engine. Maybe this will give you some ideas.
    The air cleaner had a 2-way heat/vacuum controlled valve to draw air up from the exhaust manifold which had a heat absorber shroud. The intake manifold and heads also had ports the allowed exhaust gas to flow through the intake. All to help the engine intake heat up faster for quicker drivability.
    The shroud says Dodge on it and the duct is hanging from the air cleaner with the 2-way valve on the snorkle.
  12. Nov 17, 2012 at 11:50 PM
    #732
    ToyComa84
    ToyComa84 Well-Known Member
    Matt(hew)
    "flatland"
    03 prerunner sr5
    plasti dipped wheel caps,
    WOW! some of these numbers are IMPRESSIVE!! how does one get those numbers for a 2003 4 banger auto extended cab prerunner? Send a PM, as i'm not on here as much as i'd like to be. the only "mod" is Hankook Dynapro MT's, grilleguard, and tow hitch minus the rear bumper. any help would be greatly appreciated as i'm about to "broke as a joke" come monday or tuesday.
  13. Nov 17, 2012 at 11:55 PM
    #733
    worthywads
    Most it's driving slower, there are no mods to make significant gains. If you avoid braking hard and accelerate while keeping the rpm low you'd do a lot better.
  14. Nov 18, 2012 at 12:38 AM
    #734
    Rich91710
    Rich
    Los Angeles
    08 Base
    Bingo.
    No mods or gadgets or chemicals will ever pay for themselves in fuel savings... and very few will even make a statistically significant difference.
    Save one....
    Duct tape and an egg.
    Mount this mod to the accelerator and don't break the egg.
  15. Nov 18, 2012 at 2:02 AM
    #735
    2TRunner
    My House Usually
    Ok, at least I'm not totally stupid with my idea/thinking. I may pursue it further. It probably wouldn't be uber complicated to make a basic metal shield.
  16. Nov 18, 2012 at 4:56 PM
    #736
    Rackster
    Kevin
    Connecticut
    I wouldn't say that. You started with a theory and now you are considering modifying it...sounds pretty smart to me!
  17. Nov 18, 2012 at 5:05 PM
    #737
    2TRunner
    My House Usually
    Oops. I ment to say "I'm NOT totally..."
    Edited.
  18. Nov 18, 2012 at 5:36 PM
    #738
    Rackster
    Kevin
    Connecticut
    Thanks for posting the picture WW. I remember those foil ducts - always got crushed and distorted.
    I'm wondering about a heatsync approach, perhaps a metal rod attached to the exhaust manifold/block that runs inside/along the intake duct.
    With the volume of air flowing through the intake, it seems that warming it enough under driving conditions might be a very difficult challenge. But at start up/idle where MPGs suffer significantly, maybe the warmer air would make a more noticable gain?
  19. Nov 18, 2012 at 5:42 PM
    #739
    Rackster
    Kevin
    Connecticut
    Yes...much better.
  20. Nov 18, 2012 at 5:56 PM
    #740
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    I will probably end up with some screen over the gaping hole and possibly run a dryer hose across and over the headers. I was going to give it a little time to see what the baseline looks like. I will likely put several tanks through it in the next few weeks so I should have a pretty good idea where I end up.
