4 Bangin, Fuel Sippin, Full Tank Challenge!
Discussion in '4 Cylinder' started by 2TRunner, Aug 29, 2011.
  1. Apr 11, 2013 at 7:07 AM
    #861
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    have yall noticed a mpg increase using ethanol free gas? or is difference it very minimal if any? there is a station by me that is always one of the cheaper stations and has ethanol free gas and i was wondering if i should make a point to use it.
  2. Apr 11, 2013 at 2:15 PM
    #862
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    IIRC winter blend is phased out slowly over several weeks. The refiners have access to long range weather forecasts for all regions, and adjust the amount of oxygenates that the fuel has in it during the switchover of seasons. The oxygenates cost more than pure gas, so it is to their advantage to use less if possible. I doubt if fuel in Mid to south Texas and Florida even have winter blend. Just my 2¢
  3. Apr 11, 2013 at 10:41 PM
    #863
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It can be significant.
    While Ethanol has a base octane rating of 118, making it a cheap octane booster that allows for more timing advance, it is stoich at around 9.5:1 compared to gasoline's 14.:1
    If you had two identical engines, one tuned for gasoline and one tuned for ethanol, if the gasoline engine got 29mpg, the pure ethanol engine would get 19mpg, and it would put out 25% less power due to ethanol's lower BTU content.
    That's comparing pure gasoline against pure ethanol.
    Pump gas is only around 10%, but the computer still needs to add more fuel to compensate for the lean burn.
  4. Apr 12, 2013 at 7:37 AM
    #864
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I understand ethanol's lower fuel content per volume compared to gasoline, and the resulting lower mpg numbers. But if ethanol is stoich 9.5:1 compared to gasoline stoich of 14.7:1, doesn't that mean more ethanol is added per volume of air compared to gasoline? If yes, wouldn't the additional ethanol balance out the otherwise lower power output of the ethanol engine? I just don't understand why an ethanol engine would put out so much less power if it's burning *a larger quantity of lower energy content fuel,* especially since an ethanol engine would be tuned to take advantage of the super high octane ethanol... wouldn't the power output be a wash for the most part? When I ask this question, I'm not considering fuel economy, only final power output of engines of equal displacement.
    Consider this: high-compression gasoline engines put out more power than a normal compression engine of the same displacement, while burning premium fuel which has no more energy content than regular gasoline.
  5. Apr 12, 2013 at 9:35 AM
    #865
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
  6. Apr 12, 2013 at 4:59 PM
    #866
    Rich91710
    Rich
    Los Angeles
    08 Base
    I was referring to two identical engines. The ethanol engine only tuned to avoid the lean burn... not optimize power.
    This is the only thing your engine's ECU can do when you go from pure gasoline to E10... dump in more fuel.
    Flex-Fuel engines are able to compensate outside of the parameters of a normal engine, but the result of E85 is still significantly reduced power and economy.
    This is following the parameters of the question as it relates to this thread.
    Moving beyond issues pertaining to this thread and our Tacomas, for an engine designed and built to run ONLY on E85 or pure ethanol, then the design can compensate for that through greatly increased compression and timing. Ethanol burns cooler, so the engine is also more tolerate of a lean condition. There is a reason that racing cars use alcohol fuels. A properly designed alcohol engine can easily make more power than a gasoline engine of the same displacement... but it is also going to burn a lot of fuel.
  7. Apr 12, 2013 at 5:14 PM
    #867
    arlypoo
    arlypoo Well-Known Member
    Arlin
    Port Something
    2005 2.7 4x4
    with 285/70/17 on stock gearing and full armour i get around 20mpg consistantly. However if someone else were to drive my truck for a full tank the results would be far worse.
  8. Apr 12, 2013 at 5:16 PM
    #868
    MikeCB600F
    Plainfield, IL.
    Yehaaaaa!!! Back over 19 MPG
  9. Apr 12, 2013 at 6:53 PM
    #869
    2TRunner
    2TRunner [OP] Snoop Dad
    My House Usually
    Fuck the cold.
    Love my truck.
    It hates the muthafuckin' cold.
  10. Apr 13, 2013 at 5:43 AM
    #870
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    That's pretty good Kase given you are sitting higher than most of us. 400 miles in my truck is decent.
  11. Apr 13, 2013 at 5:48 AM
    #871
    Rackster
    Kevin
    Connecticut
    I also understand that the E85 engines are more expensive to build (high compression engines).
  12. Apr 13, 2013 at 6:20 AM
    #872
    MikeCB600F
    Plainfield, IL.
    About 10 or so years ago, I started to fill my Jeep TJ up at a gas station that was on average 5 cents a gallon cheaper. For two straight tanks, I got around 12 MPG. Then I read in the newspaper that this station was selling E85 on unmarked pumps and many people were having problems with their cars. The problems ranged from bad MPG/no power to a few people had $1,000 or more repairs. Took about 3 fill ups to get back to normal MPG. That E85 sucks and if the ECU can't handle the change, you may have to completely drain the fuel system and reprogram/recalibrate everything.
  13. Apr 18, 2013 at 3:34 PM
    #873
    EricTheRed
    EricTheRed Damn dirty Swede
    Eric Sven
    Kelowna, BC
    Five lugs of might and fury
    BHLM, General Grabber A/T2 235/75R15 on stockers, Magnaflow 11225, Tonneau cover, Pop 'n Lock, Lots of dog hair...
    I got my 5-lug in the middle of winter (January) and have been making regular highway trips 600km+ every couple of weeks since then. The PO used it as a service truck so it never saw much highway action prior to me.
    My first trip (627km on January 22nd) got me 23.55mpg
    My most recent trip (638km on April 17th) got me 27.41mpg
    This is 98% highway driving through mountain passes (Calgary, AB to Kelowna, BC)
  14. Apr 18, 2013 at 8:00 PM
    #874
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Is that imperial gallons?
  15. Apr 18, 2013 at 9:38 PM
    #875
    EricTheRed
    Eric Sven
    Kelowna, BC
    Nope. US.
    The app I use (Road Trip) can automatically convert from l/100km to MPG.
  16. Apr 19, 2013 at 5:40 AM
    #876
    worthywads
    Doing well then. :thumbsup:
  17. Apr 19, 2013 at 3:09 PM
    #877
    EricTheRed
    Eric Sven
    Kelowna, BC
    I see you've got an all-time mileage of 30.3mpg...what's your secret???
  18. Apr 19, 2013 at 6:40 PM
    #878
    Rich91710
    Rich
    Los Angeles
    08 Base
    Wads cheats.
    He's a hypermiler.
    He only uses his engine to drive TO work. It's all downhill coming home.
    There's a few things you can get away with on a manual that'll damage an automatic.
  19. Apr 19, 2013 at 8:31 PM
    #879
    worthywads
    Latest tank, 575 miles on 19.409 gallons for 29.6 mpg.
    Thought for sure I'd be able to break well into the 30s but we had a cold snap with lows in the teens and 34.9 inches of snow for the month.
    Still didn't need 4x4 :p
    I only use my engine to accelerate, then it's off while coasting.
    Here's some techniques.
    http://www.cleanmpg.com/forums/showthread.php?t=1510
  20. Apr 19, 2013 at 8:45 PM
    #880
    MikeCB600F
    Plainfield, IL.
    I hate you 5 luggers:D. I traveled about 30 miles to meet someone to sell some Jeep parts. I was heading into a 30MPH+ wind and the instant MPG on the ultra guage never went above 21MPG. When returning, the instant MPG was in the upper 20s (27-30) most of the time. The trip was on two lane roads at 60MPH for about 25 miles each way.
    What sucked was the gas was 25 to 30 cents a gallon cheaper than around my house. I filled up and averaged 19.8MPG.
