4 Bangin, Fuel Sippin, Full Tank Challenge!
Discussion in '4 Cylinder' started by 2TRunner, Aug 29, 2011.
  1. Apr 27, 2013 at 6:50 AM
    #901
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Plus us 6 luggers have 4.10 diff gears. At least the penalty for spinning up the 4 cylinder is nowhere near as bad as the V6.
  2. Apr 27, 2013 at 8:10 AM
    #902
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    I remember in the 2012 brochure that the 4x4 reg cabs were over 400 lbs more than the 4x2 reg cabs.
  3. Apr 27, 2013 at 1:33 PM
    #903
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Transfer case and front driveline.
    That 400lbs difference is reflected in cargo capacity (4x4 is derated by 400lbs)
  4. Apr 27, 2013 at 1:34 PM
    #904
    Rich91710
    Rich
    Los Angeles
    08 Base
    The lower gears offset the taller tires. Our final effective drive ratio should be comparable.
  5. Apr 27, 2013 at 8:05 PM
    #905
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Adjusted for tires and gears you are right with the Automatic. The 5-lug turns only 1.6% lower.
    However with the stick the 5-lug is turning 10% lower.
  6. Apr 27, 2013 at 9:55 PM
    #906
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    This is interesting. I wonder if my speedo being almost 7% off has something to do with this. When going 75, my gps says I am going around 70 on flat road.
  7. Apr 27, 2013 at 11:22 PM
    #907
    Rich91710
    Rich
    Los Angeles
    08 Base
    Nahh... That's intentional.
    Mine is the same way. My motorcycle is worse, to the point that I installed a Speedo-Healer to correct it.
    It is very common for Japanese vehicles to be as much as 12% "fast" on the speedo. Part of this is the European CE standards impose heavy penalties if the speedo reads a speed lower than actual.
    Basically, if you were speeding, you can't blame the vehicle for misleading you.
    Typically, the odometer is about half the speedo error... my Kawasaki and Taco are pretty close to that. Honda got spanked in civil court over the odometer running 10% high... ended up having to give away some extended warranties.
  8. Apr 28, 2013 at 8:34 AM
    #908
    aidenhardcore
    aidenhardcore Well-Known Member
    mike
    boston,ma
    2017 trd off road
    None yet but soon all black.
    The truck came with 265s, and I have 31s on there and there almost the same size. I know my bfgs are alittle heavier so I get that will bring it down a bit but not that much. I know my truck isnt fast and i never floor it. I always try to keep my driving slow and when it goes green i go easy on it but still only get 270 a tank lol.
    Well I have the stock intake. I just changed the filter to a afe pro dry flow one. Thats all. Everything else is completely stock. By the way I have an auto.
    You have some good infor. I do know that 4x4 and 4x2 are different and there mpg will not be the same at all. Its just weird that my friend has a 03 2.7 but stick and gets over 400 a tank and me with auto gets 270. I know there would be a difference but that big of a gap lol. Seems weird. I also have the 456 gears. Idk lol. Im gonna change the plugs and see if that helps. Thanks guys
  9. Apr 28, 2013 at 10:20 AM
    #909
    sandstock
    sandstock Member
    Morehead, Ky
    2012 4x4 5-speed 4cyl Tacoma
    My fourth tank on my new 2012 Tacoma, not sure if I can improve on these numbers, would love to get it up to the 26-30MPG range. My gas light had just came on, but had to stop where gas was cheaper.. I think I could have got 430-450 miles out of this tank.. All stock, except air pressure.
    Scan Gauge showing 24.9MPG. Actual pump numbers, gallons=409 miles/16.7=24.49MPG
  10. Apr 28, 2013 at 12:40 PM
    #910
    Taco Pete626
    Peter
    Southern California
    For a 4x4, that is great!
  11. Apr 28, 2013 at 1:09 PM
    #911
    sandstock
    sandstock Member
    Morehead, Ky
    I will say the one thing killing these trucks are that they have so much rolling resistance. My other car is a prius, and on some down hills when I go to neutral in my prius it picks up 5-10mph, in my Tacoma it gains very little or slows down, but hey it is a 4x4 truck.. A scan gauge can help anyone with mpg's, I have found just a little change in throttle makes a big difference in mpg's but almost no difference in power:eek:.. I will be going to synthetic motor oil after my free oil changes, and see if that helps..
  12. Apr 28, 2013 at 2:59 PM
    #912
    Rich91710
    Rich
    Los Angeles
    08 Base
    Don't go to neutral on an automatic trans in a Tacoma. With the engine at idle, the pump is not running at a high enough RPM to properly lubricate the trans at highway speed.
    Same goes for the transfer case on a 4x4... the splash lubrication is driven from the input.
  13. Apr 28, 2013 at 3:29 PM
    #913
    sandstock
    sandstock Member
    Morehead, Ky
    Its a 5-speed :)
  14. Apr 28, 2013 at 3:52 PM
    #914
    Rich91710
    Rich
    Los Angeles
    08 Base
    That was more of a general warning to someone reading that doesn't know.
  15. Apr 28, 2013 at 10:24 PM
    #915
    Warhawk
    Warhawk Well-Known Member
    Hot Springs, Arkansas
    2019 TRD OR AC
    Quicksand 2019 TRD Off Road Access Cab
    My Taco is getting better and better mileage. I'm still working out of town and racking up a LOT of highway miles. The current tank is 100% gasoline, and has 455 miles on. The gauge is barely below 1/4 and the light is NOT on.
    The last few tanks I've been getting mid 25's to low 26's.
  16. Apr 29, 2013 at 2:59 PM
    #916
    iroh
    michigander
    tonneau
    So dang close. 286.3 miles, 11.479 gallons, overall 24.94 mpg. I guess I should have put a little effort into that one.
  17. Apr 29, 2013 at 3:41 PM
    #917
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    My best so far was 172.4 Miles 6.099 Gallons
  18. Apr 29, 2013 at 6:06 PM
    #918
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    It will happen as we get into summer. Late summer and early fall seem to be the best for me.
  19. Apr 29, 2013 at 7:29 PM
    #919
    Rich91710
    Rich
    Los Angeles
    08 Base
    Been fighting 23-24 for a couple of months. Couple of weeks ago it took a turn for the better, delivering slightly above the UG estimate.
    Today was 351 on 13.94 for a 25.2. Only had 12 tanks better over the last year (72 fillups).
  20. Apr 30, 2013 at 5:00 PM
    #920
    Warhawk
    2019 TRD OR AC
    The low fuel light came on at 483 and I had about 20 mile stretch ahead of me with no gas, so I filled up at 488. 17.9 gallons for 27.26 mpg.
    I sure wish we could get ethanol free gas here.
