4 Bangin, Fuel Sippin, Full Tank Challenge!
Discussion in '4 Cylinder' started by 2TRunner, Aug 29, 2011.
  1. Nov 8, 2013 at 3:25 PM
    #1141
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I bet it'll be fine. The fan clutch is pretty aggressive and the cooling system is definitely capable. I knew it was past time to take it off in early summer when my max coolant temp went UP without it. It could be 70F outside and I'd get 190fwt with the block but 194-196fwt without it (and I couldn't hear the whoosh of the fan anymore). The day it came out it was 94F and it peaked at 198fwt climbing a hill on the freeway after an hour or so of driving. (That was the 2/3 block.)
    I have a full upper block and one for just the top two openings. I'm considering trying the full upper block as it worked well on the 4.0L in the deep freeze. Either way it's also getting the side blocks for the lower grille again that narrow it up to match the width of the radiator.
    It dawned on me a couple days ago I've been forgetting to turn off the heat when I start. Sure enough, with one minute of idle after cold start in 31F air, got on the road, engine got to 180F in just over two miles with open grill. Heck of a lot faster than the 4.0 ever could even with the block.
  2. Nov 9, 2013 at 9:45 AM
    #1142
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    Thanks for the data. How did you construct the blocks?
  3. Nov 9, 2013 at 2:24 PM
    #1143
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Keep in mind, not recommended for automatics unless you have separate trans temp monitoring.
  4. Nov 9, 2013 at 4:16 PM
    #1144
    iroh
    michigander
    tonneau
    It's easy on the 2nd gen. Remove two screws, pop out two plugs, and the upper grill is out. Then it's just a matter of blocking a couple unseen holes to make the back side's edges into one smooth curve (not difficult, even gorilla tape works well there), and ziptie some coroplast to it. The vertical supports are strong enough to hold it. I covered the face of the coroplast with black gorilla tape and it's essentially invisible.
    :amen:
  5. Nov 14, 2013 at 7:00 PM
    #1145
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    22.8 on 33s :bananadance: stock gears :0
    Finally put my aero turbine muffler on also
  6. Nov 15, 2013 at 11:05 AM
    #1146
    Timberland Taco
    Timberland Taco Well-Known Member
    Berlin, NJ
    2013 V6 6-speed 4x4
    Bilstein 5100's set at .85, OME 885x coils w/ 1/2" top plate spacers, Total Chaos UCA's, Wheelers 1.5" HD 3 leaf progressive AAL w/ factory overload leaf, DT Pipe Bomb Ypipe, Vibrant resonator, Magnaflow pro series catback system, URD Short Throw Shift Kit, Debadged, BHLM, BTLM, 6000K BiXenon Headlights & Fogs.
    I must just drive like a maniac. 2010 4x4 access cab 2.7 5 speed Ive never gotten 20mpg out of it. Closest i came was with the stock 245's which was like 19.5. Ive tried granny driving and it didnt seem to help. I do a lot of stop and go city driving as well as highway driving in the 75-80mph range (any slower you get run over here...) so i guess thats why I dont do as good. Oh well ill just settle for the steady 18-19mpg, better than the 8-10 i was getting in my jeep.
  7. Nov 15, 2013 at 11:05 AM
    #1147
    bhd1223
    bhd1223 Well-Known Member
    Connecticut
    Totaled 05, 07 Frontier CC V6 6-spd
    05 Totaled. Dead: Pulled elbow off airbox, MAF Cal, DT Header, Towing stuff, URD short shifter, hoping to supercharge in the somewhat near future Now: 07 Frontier suspension planned, short shift on the way, tires, toys, etc.
    May I ask how?
  8. Nov 15, 2013 at 5:02 PM
    #1148
    Rich91710
    Rich
    Los Angeles
    08 Base
    18-19 is not bad for large tires on a 4x4 with a lot of stop and go driving.
    Stop and go is a killer, even on my 5-lug spinning 215's.
    If I never got on the freeway, I wouldn't top 18.
  9. Nov 15, 2013 at 8:01 PM
    #1149
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    I personally shift between 2200-2500 rpm
    2k is a little low for me, and 70 is my max speed on the highway to keep the Rpms below the 2400 range
    I have a intake, headers and a straight through exhaust, it helps quite abit
    Better flow of air coming in and exhaust going out
  10. Nov 16, 2013 at 10:10 AM
    #1150
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    Colder weather and winter blend, lost about 2.5MPG since mid October.
  11. Nov 16, 2013 at 11:17 AM
    #1151
    iroh
    michigander
    tonneau
    Yeah it's annoying to look at the ultragauge on the first leg of my commute and it's sitting pretty at 16-18 mpg when it used to do 20-22 there. Oh well, the 4.0L would read 11-13 at that point in the winter.
    Having a tough time keeping the meter above 22 avg this tank. I had three days with 20+ mph headwinds so far (Monday was 25 gusting to 40, sometimes it got up to 18-19 mpg going downhill). It came off of full at 55 miles and passed 3/4 at 93 miles, but it waited until 190 miles until half. Who knows, maybe the sender's sick. Don't trust the gauge.
    I need to get that grill block in.
  12. Nov 16, 2013 at 4:13 PM
    #1152
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    I've experienced about the same thing recently in Minneapolis. About 2 to 2.5 mpg drop from normal summer temps. Getting 20 to 20.5 mpg on my standard work route now.
  13. Nov 17, 2013 at 8:13 AM
    #1153
    Rackster
    Kevin
    Connecticut
    Once the truck warms up, I'm seeing intake temps 20-30F warmer than ambient. So this translates to temps around 60-80F through the intake. Even running leaner than I otherwise would be without the WAI, averaging above 22 MPGs is a tough challenge. I'm thinking about a few mod's to get the engine warmed up quicker and get the intake air up a few more degrees. But the point of it may be moot: cold air and winter blend are tough to beat.
    I'm also wondering what the % of ethanol is since the switch. I've heard the summer fuel is a blend here in the NE as well. The pumps have the ethanol sticker attached - assumed it was for the winter fuel only though.
  14. Nov 18, 2013 at 5:50 AM
    #1154
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    I'm not a big fan of ethanol, and the higher the percent of ethanol, the lower the fuel mileage.
  15. Nov 18, 2013 at 8:01 PM
    #1155
    Rich91710
    Rich
    Los Angeles
    08 Base
    I am... but not in my truck unless I'm bringning it home from Bevmo.
  16. Nov 24, 2013 at 4:44 PM
    #1156
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Winter sucks!
    525 miles on 18.52 for 28.3 MPG.
    Yeah I whine. :p
  17. Nov 24, 2013 at 5:54 PM
    #1157
    Rackster
    Kevin
    Connecticut
    17F degrees the other morning - low 20s tomorrow. Hoping to keep it above 21 MPGs.
  18. Nov 25, 2013 at 6:31 PM
    #1158
    iroh
    michigander
    tonneau
    It was 17F here this morning too. The tranny doesn't like it.
    Then we got ice this afternoon. Traffic limited to 40 mph means even though I'm already 8 gallons in, the tank avg on the gauge still rose six tenths in 22 miles. Unfortunately I'll probably burn half my savings off starting it up tomorrow morning.
  19. Nov 25, 2013 at 8:37 PM
    #1159
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    Lately, I have had the chance to work at a jobsite that is approximately 77 miles away. My past 4 tanks consist of 85-90% highway miles, cruising at 70-80 MPH with some stop and go traffic thrown in. I have been getting 27-28 mpg, barely approaching WorthyWads territory. I might be able to do better if I reduce my cruising speed, but I've been working 10-11 hour days, and I just want to get home as quickly as I can so I can get some sleep! Very happy with my recent MPG results, especially with the cold morning starts.
  20. Nov 26, 2013 at 3:58 AM
    #1160
    Rackster
    Kevin
    Connecticut
    LOL - that's the truth of it!! I note that I get to about 176F at about 3 miles and 180F+ at about 7 miles. That stretch really takes a bite out of the MPGs. If I can creep up the back hill (no traffic ever), I can hit my waypoints at about +10% more fuel consumed. Using the usual route, I'm +15% or more. All of the fluids are thick and sticky. Roll distances are drastically down. Today I averaged about 21 MPGs on the ride in (up hill and morning chill/cold to contend with). It'll take some work to get 23 on the ride home to get a 22 MPG average. But that's the challenge!!
    FWIW: the intake temps have been averaging +30F with the current location (next to the exhaust manifold). I've seen a few over 40F on the ride home when it warms up here a bit.
