4 Bangin, Fuel Sippin, Full Tank Challenge!
Discussion in '4 Cylinder' started by 2TRunner, Aug 29, 2011.
  1. Jan 4, 2014 at 8:27 AM
    #1181
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Tell us more about results of your grill block.
    I've never bothered thinking that the radiator shouldn't really come into play until the engine temp gets up to the thermostat temperature. But I love to hear what effect you are seeing.
  2. Jan 4, 2014 at 10:53 AM
    #1182
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Will do.
    I originally made it for my last truck because the 4.0 took a long time to get heat out of it, i.e. fifteen minutes or more in the real cold air. Once it finally warmed up, it was fine. It was a young engine so it shouldn't have had thermostat issues, but I agree, the radiator shouldn't come into play. However after the block went in I'd have heat in three or four minutes. Its major mileage boost was when used in combination with removal of the fender intake tube. That put the air filter box's opening directly behind the radiator and in the winter it wasn't unusual to have IAT's 30-40F above ambient going down the road.
    This truck has been doing the same to me heat-wise. I hope the grill block speeds things up. I don't get much more than lukewarm heat until I get to work as that heavy iron block is a massive heatsink. Can't do the airbox trick though unfortunately so we'll see if mileage changes. I don't expect much there. After all I got 23.5 mpg last tank bucking snowdrifts in 4x4, how much better can it get in the winter?
  3. Jan 5, 2014 at 8:38 PM
    #1183
    FlightMedic178
    FlightMedic178 Well-Known Member
    Nate
    Phoenix
    2017 DC OR MT
    Bone stock
    Went 522 miles on a single tank when the light came on. Fueled up soon after 18.2 gallons = 28.5 MPG! In a double cab!
  4. Jan 5, 2014 at 9:58 PM
    #1184
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I also run an under the hood intake for better gas mileage.
    8a098052-48fe-43ec-a082-e93bd8aaf3e0_zps_20dc769cf92a24bda78498e5fe62e48f05f63e3a.jpg
    That's superb winter mileage. :thumbsup:
  5. Jan 6, 2014 at 7:30 PM
    #1185
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Filled up this evening, 419.1 miles / 17.14 gallons of Hy-Vee's finest 87 octane gas and corn squeezin's = 24.5 MPG Next tank won't even come close, unless I go visit Mom again. Can't complain too much, my last ten fill ups have averaged 23.5 MPG
  6. Jan 8, 2014 at 1:33 PM
    #1186
    Mr. Pick
    Mr. Pick Well-Known Member
    Middle TN
    '12 AC, SR5, 2.7L, Auto
    I'm running between 22.5 and 24.5 this time of year, which I consider pretty good with cold temps and winter blend gas. I'll take it!
  7. Jan 9, 2014 at 2:56 AM
    #1187
    MikeCB600F
    MikeCB600F Poverty Truck
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    The three days below 0 MPG.......15.6........OUCH OUCH OUCH.. The engine coolant temp never got above 180 and I needed to drive several miles before the trans would shift into over drive.
  8. Jan 9, 2014 at 4:21 AM
    #1188
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    I hear you Mike. This cold snap is offering up some ugly baseline data. The morning temps have been in the low single digits rising into the mid-teens during the day (last 3 days or so). Temps before that weren't much better. Three trips into work netted around 19 MPGs and on the snow days, 4x4 dragged that average down more. Last tank was just a crack above a 20 MPGs average. One thing is clear: ethanol, while not great, isn't the biggest detractor to decent FE. Cold weather is king. I feel for those in the northern most states - that level of cold sucks!
  9. Jan 9, 2014 at 6:20 AM
    #1189
    MikeCB600F
    Plainfield, IL.
    I only had it in 4WD for about five minutes to get through some nasty drifts. I even used some cardboard to block the radiator. The killer was the trans not shifting into OD. The ultra guage was showing 13 to14 MPG before shifting up.
  10. Jan 9, 2014 at 6:23 PM
    #1190
    iroh
    michigander
    tonneau
    This tank is off to a BAD start!
    This winter is really getting horrible. I couldn't go fast enough for 5th gear for six days.
    Here was a 2nd gear day
    http://youtu.be/UzsmX7xAdSQ
    I am LOVING the grill block though. It gets good heat in the cab now and the coolant is staying stable between 186-192F after it warms up.
  11. Jan 10, 2014 at 1:05 PM
    #1191
    Mr. Pick
    Middle TN
    I never have figured out why people live up there..... :D
  12. Jan 12, 2014 at 3:16 PM
    #1192
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    I ran mine till the light came on.342 and 17.7 gallons.265/75-16's.4 cyl 5 speed prerunner access cab.125,000 miles
  13. Jan 14, 2014 at 7:47 AM
    #1193
    Speck
    Speck Well-Known Member
    Tejas
    07 2.7 4x4
    Just checking in to report my best mileage tank yet, 22.6 mpg all highway at speeds up to 80+ (slower than flow of traffic). I thought the excessive speeds would've tanked the MPG but not so in this case for some reason.
    I did just get rotated and balanced which fixed a ~70mph vibration, but I wouldn't think that would have much if any effect.
    2007 AC 2.7L 4x4 w 90k miles and camper shell
  14. Jan 14, 2014 at 8:59 PM
    #1194
    iroh
    michigander
    tonneau
    Now that's redemption from a bad beginning! 306.3 mi, 13.28 gal, avg 23.1 mpg.
    It has to help that I FINALLY got those noisy, heavy all-terrain tires off the truck.
  15. Jan 15, 2014 at 5:32 AM
    #1195
    Mr. Pick
    Middle TN
    Well, pleasant surprise when I filled up Sunday evening. 418.8 miles, 16.48 gallons = 25.4 mpg! Had a little interstate driving in there, so that helped, but that is a really good tank for me in the winter. Long live the 2.7!
  16. Jan 22, 2014 at 7:18 PM
    #1196
    MikeCB600F
    Plainfield, IL.
    Cold weather sure kills the MPG:mad:
  17. Jan 29, 2014 at 4:32 PM
    #1197
    worthywads
    A little better on this tank. The trip to Breckenridge and back last weekend helped a lot with 32 mpg round trip.
    535 miles on 18.474 gallons for 29.0 mpg.
  18. Jan 30, 2014 at 6:39 PM
    #1198
    bhd1223
    bhd1223 Well-Known Member
    Connecticut
    Totaled 05, 07 Frontier CC V6 6-spd
    05 Totaled. Dead: Pulled elbow off airbox, MAF Cal, DT Header, Towing stuff, URD short shifter, hoping to supercharge in the somewhat near future Now: 07 Frontier suspension planned, short shift on the way, tires, toys, etc.
    To think I was happy today to get back over 18 mpg with around 18.7. I guess I'm just too aggressive. I didn't notice it much in the warm months but maybe with the addition of cold temperatures the duratracs are pulling it down some, probably also due to me airing them down a little in the winter. Perhaps the next set I'll jump to the Nokian Rotiiva as my experience with Nokian has been pleasant.
  19. Jan 31, 2014 at 8:48 AM
    #1199
    iroh
    michigander
    tonneau
    It was a short fill, not even 8 gallons, but I wanted to beat the price hike. With burning gas trying to jump a car for 40 minutes I averaged 20.4 mpg, my new worst ever.
    We're supposed to get another foot of snow tomorrow. I don't know where they're going to put it. They just opened up my normal road to work with a road grader and for well over a mile the 'west wall' on that road is 10-15 feet high.
  20. Jan 31, 2014 at 2:56 PM
    #1200
    cnw126
    cnw126 Member
    Delaware
    2013, 4X4, 2.7, 5spd, access cab, Pyrite Mica
    Hello All,
    With all this talk of the cold weather I figured I would chime in!
    Last week I drove to western PA from Delaware. The ambient temp was between 5 and 9 degrees F.
    I got 18 mpg, all highway miles doing pretty much 70 mph the entire way. 15.6 gal for 280 miles.
    The only caveat is that it was hilly, windy, cold and I have only 3500 miles on the truck.
    I was disappointed with the mileage none the less. Worst tank I have had yet.
