4 Bangin, Fuel Sippin, Full Tank Challenge!
Discussion in '4 Cylinder' started by 2TRunner, Aug 29, 2011.
  1. Oct 6, 2016 at 11:20 AM
    #1401
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Maybe an increase in the rolling resistance compared to the old ones. If that's the only thing that has changed since the new tires they may be responsible.
  2. Oct 6, 2016 at 1:29 PM
    #1402
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    The Firestones are suppose to be low rolling resistance. Looking at tire specs, they are 5 pounds per tire heavier. 20 pounds should not make that much difference. I could see it if I went to LT tires.
  3. Oct 6, 2016 at 1:35 PM
    #1403
    T4RFTMFW
    T4RFTMFW Well-Known Member
    The 2.7 is extremely sensitive to tire weight.
    I lost 25% economy when I left the OEM Dunlops.
    23Skidoo likes this.
  4. Oct 6, 2016 at 1:39 PM
    #1404
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    When I went from the oem Firestones to Michelin rain-x that claimed improved rolling resistance I lost 2+ mpg and could tell immediately that my coasting was way shorter than before. Finally after 50K they are approaching the Firestones.
  5. Oct 6, 2016 at 3:41 PM
    #1405
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    these are actually 1 pound lighter than the dunflops in the same size according to Tirerack. my truck all of a sudden has been getting 23mpg down from 24.5 mpg im suspecting winter fuel
  6. Oct 6, 2016 at 5:33 PM
    #1406
    MikeCB600F
    Plainfield, IL.
    Destination LE black sidewall 31lbs
    Destination LE raised white letters 36lbs
    I bought the raised letter version.
    Refineries can start making winter blend September 15 and summer blend April 15.
  7. Oct 11, 2016 at 2:49 PM
    #1407
    Mush Mouse
    mush
    2013 SR5
    wow the white letters weigh 5lbs.:eek: I found out that my tires were 3lbs low on air and for some reason my TPSM light did not go on:notsure:not winter blend fuel
  8. Oct 11, 2016 at 4:01 PM
    #1408
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    TPMS won't come on until it hits around 26 psi.
    Mush Mouse[QUOTED] likes this.
  9. Oct 12, 2016 at 10:38 AM
    #1409
    MikeCB600F
    Plainfield, IL.
    Not only does the raised letters weigh 5 pounds, they are raised enough to cause wind resistance :D. The psi on the tires was 34 to 35. I will see what the next tank gets.
  10. Oct 12, 2016 at 12:04 PM
    #1410
    Mush Mouse
    mush
    2013 SR5
    i just got my truckrecently but I have been running the doneflops at 32psi, the door jam says 30psi all 4 tires,i notice if I get 160-165 miles on the 1st 1/4 tank of gas I will be close to 24.5-25 mpgs which is pretty good. my next tire after the doneflops will be the Michelin ms2 in p245/75/16 they are 35lbs. a tire the doneflops 32lbs. hopefully the fuel mpgs will be the same I know the ms2s will ride and perform a whole lot better for sure.
  11. Oct 12, 2016 at 12:18 PM
    #1411
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    2004 double cab driving 80% city 20% highway. 2" lift and some bigger tires. Getting around 20-21mpgs.
  12. Nov 3, 2016 at 1:06 PM
    #1412
    MikeCB600F
    Plainfield, IL.
    My MPG is slowly increasing. :) I swapped vehicles with my mom for a week for vacation. The Taco had a lowly 20 mpg for the week:mad:
  13. Nov 4, 2016 at 7:37 AM
    #1413
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Just read a few of the first pages, and a few of the latest pages.
    I have a 2nd gen 4x4, 4cyl, manual, access cab, long bed, stock wheel/tires, removed carbon paper filter thingy. The tank is around 21 gal I think. If you have the same truck and get more than 400 miles out of a tank, please don't drive in front of me or hold up the left hand lane, you are in fact the person I scream obscenities at on a daily basis! Hit the gas and get where you need to be damn it!
  14. Nov 4, 2016 at 7:41 AM
    #1414
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Please don't drive behind me, and always pass on the left.
  15. Nov 4, 2016 at 7:43 AM
    #1415
    dirty deeds
    Nick
    Eastern KY
    Obviously I would pass you on the left, as long as you aren't trying to drag race a semi up a hill on the interstate :)
  16. Nov 4, 2016 at 8:06 AM
    #1416
    Mush Mouse
    mush
    2013 SR5
  17. Nov 4, 2016 at 8:08 AM
    #1417
    dirty deeds
    Nick
    Eastern KY
    The stogey, not so much. But weaving AND using signals, yes!
    Always use your signal, AT THE VERY LEAST drive the speed limit if not a little faster. The rest of the world has somewhere to be, that's why you bought a vehicle in the first place.
  18. Nov 4, 2016 at 8:09 AM
    #1418
    dirty deeds
    Nick
    Eastern KY
  19. Nov 4, 2016 at 8:35 AM
    #1419
    Mush Mouse
    mush
    2013 SR5
    dirty deeds[QUOTED] likes this.
  20. Nov 11, 2016 at 5:59 AM
    #1420
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    470.7 miles to the light. Tank was filled to first click only. 85%hwy, CC set at 60mph (used digital speedo on Waze app).
    http://imgur.com/a/yC7xh
    I haven't filled up yet to confirm, but I'm thinking this tank might be north of 26mpg.
    Edit: 25.98mpg
    RogueTRD, Mush Mouse and PvilleJohn like this.
