4 Bangin, Fuel Sippin, Full Tank Challenge!
Discussion in '4 Cylinder' started by 2TRunner, Aug 29, 2011.
  1. Dec 3, 2016 at 3:09 PM
    #1421
    Gun guy
    Gun guy Tacoma Fanboy
    05 Trd Off road AC MT & 08 Tacoma 2.7 AC MT
    I had a v6 2005 manual for 5 years (second gen ) , and I just got an 08 manual 4 banger.
    I haven't done calculations yet, but I can say without a doubt the four banger is getting better mileage.
    They are both double cabs, and honestly it almost seems like I'm getting twice as much mileage.
    The v6 would average below 15 city, and this four banger is definitely around twenty or above.
    I'll make sure to do some calculations and report back.
    Also, I drive my trucks with a heavy foot.
    Mush Mouse likes this.
  2. Dec 17, 2016 at 4:22 PM
    #1422
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    448 miles on 16.812 gallons for 26.6 mpg. Getting cold, time to start walking to work.
  3. Dec 17, 2016 at 4:49 PM
    #1423
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    Anybody hyper driving?
  4. Dec 17, 2016 at 5:32 PM
    #1424
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    What's that?
  5. Dec 17, 2016 at 5:59 PM
    #1425
    InfernoTonka
  6. Dec 17, 2016 at 6:10 PM
    #1426
    InfernoTonka
    Hyper driving is when you've had WAY TOO MUCH coffee and chased it with a couple of Red Bulls?
    :sorry: :violent:
  7. Dec 19, 2016 at 12:25 PM
    #1427
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I thought the 2nd gen 4-cylinder double cab models came out around 2014?
    Prior to that, 4-cylinder models were either access cab or regular cabs.
  8. Dec 19, 2016 at 11:42 PM
    #1428
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I get right around 20mpg. Give or take depending on the temperature. I idle A LOT. It gets so cold here that I have warm it up and let it run pretty much all the time. The usual warm up is at least 10 minutes. When it's below 30 degrees. If I stop to fuel, I let it idle. If I stop to go into a store, I let it idle. If it's down around 0 degrees? It idles while I go shopping. My 3RZ idles a lot! It's the way it is in the real world where it gets really cold. Idling saves on starters and batteries when the temp really drops. Since there is no gas shortage and there never has been it's not a problem. If I spend a day running around on trails which I can't do, for the most part, of the winter I get around 15 mpg when off road. Mine is a daily driver so I "can" go places where I don't go because there is no point in "thrashing" the daily driver for no reason.
  9. Dec 20, 2016 at 11:03 AM
    #1429
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    21.43mpg mother**k:annoyed:
  10. Jan 12, 2017 at 11:53 AM
    #1430
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    I added a new wheel/tire package, and a cap since this ... and we've had a warm few days which enabled me to test mpg once again. I took this screen shot of my Torque dashboard, and have since driven about 75 more miles and currently sitting at 25.7 for overall average. Accuracy has been within .1mpg. Basically no change with all the mods, I'm pretty happy with that.
    Upper left is instant read mpg, to the right of that is overall average (reset about a half mile prior to this fuel up). Lower right mpg gauge is trip average. Average mph to the right side is for moving avg only.
    I'm headed out to Ohio tomorrow, but I'll likely only get about 22mpg ... since I like to bump my speed up to 70 on really long trips to save time.
  11. Feb 20, 2017 at 4:07 PM
    #1431
    worthywads
    I lied, never did start walking to work. Worst tank ever 428.3 miles on 18.611 gallons for 23.0 mpg. Not many long drives. Oh well it's almost spring.
  12. Feb 27, 2017 at 9:14 AM
    #1432
    RdRunr
    RdRunr Well-Known Member
    Dan
    still in the Matrix
    2014 Base, white, reg cab, 2.7L, 5-spd
    DT header, Flowmaster 50 Series Delta Flow muffler
    InfernoTonka[QUOTED] likes this.
  13. Feb 27, 2017 at 9:25 AM
    #1433
    InfernoTonka
    I've noticed that it works as well. It seems to boil down to not going over 50mph as much as you can get away with. I like to lay off the gas going downhill. Also adjusting my speed ahead of a stop helps too. Simple things that can make big differences.
  14. Feb 27, 2017 at 8:40 PM
    #1434
    TRVLR500
    Wyoming
    The vast majority of that just isn't feasible where I live. The winters are too harsh, the wind is off the charts, the temps are too low and you get run over by Super Duties and semi's if you're doing less than 75 mph. Yes, about half of it could be done but not all of it.
  15. Feb 28, 2017 at 9:31 AM
    #1435
    snefo
    snefo Well-Known Member
    I drive easy. I once had 289 miles on the trip gauge when reaching exactly half a tank. It's usually 250+.
    I experimented with 5w30 oil, and would reach the half tank mark at 235-238 miles...so no more 5w30 for me.
    I have a 2016 SR 4x4 AC manual trans with stock wheels and tires. I also have the LCE header which helped the fuel economy considerably. Before the header, 250 miles to the half tank mark with me trying hard was my personal best. Now I can do that without thinking much about it and running around with the air conditioning on about half the time. The engine is smoother too.
    I ordered the AFE pro dry s air filter and will do the charcoal filter delete soon.
  16. Feb 28, 2017 at 11:27 AM
    #1436
    Andrew_v949
    Andrew_v949 Well-Known Member
    I'm seriously kicking around getting a 4cyl tacoma as my daily. My commute is exactly this (san diego to LA) and my driving habits are exactly this as well.
    I've been reading this thread and numbers seem to be all over the place. I know a lot of it has to to with driver habits and such. Right now I'm looking to get a Toyota Matrix because it can actually haul a small trailer or a 4cyl tacoma. Decisions, decisions
  17. Feb 28, 2017 at 12:22 PM
    #1437
    Mush Mouse
    mush
    2013 SR5
    24.39mpg, just DDing it
  18. Feb 28, 2017 at 7:18 PM
    #1438
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    Well it all comes down to whether you prioritize MPG or ultimate utility. Keep in mind my Taco was a regular cab, 2wd and 5 MT. It might be harder to get better MPG with the other trims. The matrix is a good car.
  19. Feb 28, 2017 at 8:10 PM
    #1439
    TRVLR500
    Wyoming
    I avarage around 19 mpg but I idle a LOT as cold as it gets here. I let it warm up for 10 mins. or so in the morning and if I stop at a convenience store or something on my way to work I don't shut it off. Even if I go shopping where I'll be in there for 20 mins I let it idle if its down around zero degrees. I've gotten as high as 24 mpg. I also live in the mountains and everywhere I go there is a hill or a steep grade and the speed limit here is 75 or 80 mph so if you're doing anything less than 70 mph you get run over by the hundreds of Super Duties around here. I've gotten as low as 14 mpg if I spend a day on the weekend driving around on trails.
  20. Feb 28, 2017 at 11:13 PM
    #1440
    JohnLin15
    JohnLin15 The Slower DC
    Johnny
    Alabama/Mississippi
    2015 MGM DCSB Prerunner
    16-18 MPG in town
    20 MPG on highway (~80mph)
    All stock.
    About to put 265/75/16's on :rofl:
