4 codes after heavy acceleration(P2197,P2195,P0174,P0171)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bleeds, Jun 27, 2021.
  1. Jun 27, 2021 at 2:07 PM
    Bleeds
    Bleeds [OP] Member
    2005 Taco 4.0
    I did a search but I haven't found anything similar to my situation. Here's what's going on:
    2005 Prerunner 4.0L
    235,000 miles
    Truck runs great overall but if I go out onto the highway and stomp on it, the OBD will show the above 4 codes pending and eventually it'll throw the CEL. The truck seems to accelerate normally. No stuttering or hesitation. I'd recently replaced the upstream 02 sensors due to P0171/0174. Admittedly, they're Amazon specials but all codes came right back. Also, both OEM upstream sensors "failed" about the same time which isn't likely. If I keep it below highway speeds or accelerate slowly at highway speeds, I'll never get the codes. I've checked all vacuum lines and can't see any cracks/splits/deterioration/loose hoses. I've also replaced the MAF sensor.
    So this is leading me to the fuel pump and the possibility the pickup/filter is very slightly blocked which slightly restricts fuel delivery under heavy acceleration. Additionally, the autostart won't start because manual starts requires one more crank than the autostart cranks. I'd put a fuel pressure tester on it but I'm sure once running at idle it'll read normal. Again, it's only at high speeds and heavy acceleration. I just don't believe it's an injector because acceleration is smooth, I simply will get the codes.
    Anyone with guesses or insight, feel free to chime in. Also, if anyone has changed the fuel pump, let me know what you think is the best way to go about it. Right now I plan to take the box off for ease of access instead of laying on my back and dropping tools on my face.
  2. Jun 27, 2021 at 2:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Bleeds[OP] likes this.
  3. Jun 27, 2021 at 2:28 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    16 yr old truck, original pump and filter. 235k miles....
    Replace the pump n filter and i bet it all stops
    Your fuel pump cant keep up with the demands for fueling at higher rpms and loads. The truck likely runs just fine under WOT conditions as stock they demand SUCH a rich fuel mixture that when they do go "lean" due to fuel pump problems, they are likely still plenty rich.
    That stated, i wouldnt risk it. replace that fuel pump.
    Torspd, Bleeds[OP] and TnShooter like this.
  4. Jun 27, 2021 at 3:01 PM
    Bleeds
    Bleeds [OP] Member
    2005 Taco 4.0
    Thanks guys
    TnShooter likes this.
  5. Jul 2, 2021 at 1:18 PM
    Bleeds
    Bleeds [OP] Member
    2005 Taco 4.0
    Update: well, the pump didn’t fix it. For having 235,000 miles, that pump was impeccably clean which was impressive. So I’m still getting all four codes only when I’m at highway speeds and stand on it. The pending codes had actually gone away because my son never got over 50 for a few days. So now what? Injectors maybe slightly plugged? Or should I try putting in OEM O2 sensors first? This one is really a head scratcher.
  6. Jul 2, 2021 at 2:01 PM
    TnShooter
    Deogee
    STOCK
    Maybe the fuel pump relay isn’t switching to high speed?
    Could it be that it’s stuck on Low Speed?
    You could jump it temporarily and see.
    The fuel pump is supposed to operate on High speed when starting the truck.
    But it very well may start just fine even if the relay is stuck on low?
    To be honest, I doubt that’s the problem.
    As the resistor usually fails. I can’t say I’ve seen a relay fail?
    But there’s a first time for everything!
    It’s certainly something I’d be tempted to check if it were my truck.
    @Jimmyh did a great job of explaining the relay and resistors purpose here.
    https://www.tacomaworld.com/threads/fuel-pump-resistor-symptoms.632838/#post-21729932
    Here are pictures to the location of the resistor.
    https://www.tacomaworld.com/threads/07-tacoma-fuel-and-vacuum-line-diagram.693109/#post-24511272
  7. Jul 2, 2021 at 3:53 PM
    Bleeds
    Bleeds [OP] Member
    2005 Taco 4.0
    I simply disconnected it. It started fine and then died a few seconds later. Plugged it back in and started and ran fine. I don’t know, everything looks OK physically. Also, the codes are all gone again. It just doesn’t like highway speed.
  8. Jul 2, 2021 at 5:33 PM
    Taco'09
    Taco'09 Well-Known Member
    OP. I'm a bit confused here. Did you replace the fuel pump and if so was it an aftermarket pump?
  9. Jul 2, 2021 at 5:46 PM
    Bleeds
    Bleeds [OP] Member
    2005 Taco 4.0
    Most recent part was an aftermarket fuel pump. I’ve also replaced the MAF and both O2 sensors(also aftermarket). I’ve inspected all vacuum hoses and they look good. I’m showing lean in both banks but only after hard acceleration at highway speeds.
  10. Jul 2, 2021 at 9:10 PM
    TnShooter
    Deogee
    STOCK
    Thats what it should do if you disconnect the resistor.
    The truck starts on High speed, then switches to low speed shortly after start up.
    If the relay we’re stuck stuck on low speed, the truck probably wouldn’t have started.
    So, the mystery remains.
    I mean, it’s not likely both the A/F Sensor and the O2 Sensor went out at the same time.
    Do you have a scan tool capable of monitoring A/F and O2 voltages?
  11. Jul 3, 2021 at 12:14 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Look for any exhaust leaks upstream or around the oxygen sensors
  12. Jul 3, 2021 at 12:22 AM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    Look for cracked/loose intake side parts too
  13. Jul 3, 2021 at 6:59 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    These Amazon special upstream sensors. They weren't Denso, correct? What brand did you choose? That could be a major part of the problem.
    As in the OE were old and beyond their lives, but the new ones aren't quality enough to perform properly. Lazy or Faulty signals.
  14. Jul 3, 2021 at 10:05 AM
    Bleeds
    Bleeds [OP] Member
    2005 Taco 4.0
    Bank 1 and 2 Sensor 1 both showing 3.3V
  15. Jul 3, 2021 at 10:06 AM
    Bleeds
    Bleeds [OP] Member
    2005 Taco 4.0
    Correct, not Denso but I forget the brand.
  16. Jul 3, 2021 at 11:29 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It could have been residual fuel pressure it was running on for a few seconds.
    What you need to do is:
    1.) Disconnect the fuel pump Resistor.
    2.) Jumper across the harness side connector terminals. This is the high speed mode for the pump.
    3.) Test it under a full load and see if it is still running like crap when you drive it hard.
    If it still craps out you know it isn't the resistor. If it runs as it should then it is the resistor.
    blu92in99 likes this.
  17. Jul 3, 2021 at 1:24 PM
    Bleeds
    Bleeds [OP] Member
    2005 Taco 4.0
    But it doesn’t run like crap, ever. I simply get codes. That’s what’s so annoying.
  18. Jul 3, 2021 at 1:32 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    It seems you visually checked potential vacuum leaks. You need to use brake cleaner and spray it around all possible leaks to see if the engine stumbles. It's a great way to check for leaks.
    Bleeds[OP] and Jimmyh like this.
  19. Jul 3, 2021 at 5:16 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    OK
    Test it under a full load and see if it is still Getting the codes when you drive it hard.
    If it still Gets the codes you know it isn't the resistor.
    If it runs without getting the codes then it is the resistor.
  20. Jul 3, 2021 at 9:59 PM
    captaintofuburger
    captaintofuburger Well-Known Member
    2011 Base 4wd 4banger
    All indicators if all above are ruled out. 235k. Wouldn't be unreasonable to question the FPR and or injectors. I don't know what they run $ wise, would be easier to diagnose if something was following a specific cylinder. I dislike part hanging, but there's not a real DIY way I'm aware of to see how functional they are. If you could borrow a set somehow, that would be great. I've had witch-hunter rebuild some of mine in the past. They will show you pre tests and flow rates vs post tests etc.
    Edit:
    I should have formatted / specified better. I was mainly talking about the injectors. You could get a set of noid lights, but I would suspect based on what's known that it would be a flow issue, not an electrical issue. The FPR on the other hand, run the truck a while, shut it down, pop the vac line to it, and see if gas comes out. However with the low/high fuel delivery system, you may want to try starting the truck, unplug the vac line, then pull a vacuum with a standard hand pump so it opens up more, then see if gas shoots all over. Get ready to shut down quick!
