4 cycle craftmen trimmer shuts down
Discussion in 'Garage / Workshop' started by vandolizm, Sep 13, 2010.
  1. Sep 13, 2010 at 1:34 PM
    vandolizm
    vandolizm [OP] Well-Known Member
    Katy, Texas
    TRD Sport 4x4
    Icon Stage 1 Coilovers, Icon RR Rear Shocks, TC UCA, TSB Toytec AAL ARB Bumper
    Have a craftsmen 4 cycle 29cc trimmer. It shuts down or runs really rough when i trottle. Is it bad gas, or is it something else.
  2. Sep 13, 2010 at 2:14 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Stupid stuff first-Is the tank full?
    Was the trimmer left sitting without running for an extended period of time?
    Any leaks or visible clogs?
    When was the last time it was serviced??
  3. Sep 13, 2010 at 2:23 PM
    vandolizm
    Katy, Texas
    TRD Sport 4x4
    Gas tank was full.
    Trimmer has been used 2 times a month since purchased in 2008.
    Nothing visible. Did notice gas on my fingers when I touched the gas lines.
    Never been serviced.
    Thanks.
  4. Sep 13, 2010 at 2:30 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Well a gas leak on the lines is no good. It will suck in air threw the hole and be nothing but problems. The other one I'd check is the plug. You might find it needs to be replaced. Even when they look good they could still be done. You need to test it in a spark plug tester and since you probably don't have one of those the easiest and cheapest way is just replace it.
  5. Sep 14, 2010 at 7:18 AM
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
    I have the 40-cc model and I had the same issue when the oil level was low.
  6. Sep 14, 2010 at 7:27 AM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    If you left it for any length of time more than a month, the gas may be clogging the fuel filter (when gas dries it leaves a kind of shellac). I had two of the same trimmer and had to pull the spark plug to soak the cylinder in WD40, and replace the fuel filter.
  7. Sep 14, 2010 at 7:30 AM
    98tacoma27
    Ben
    Not Beech Creek
    Why the hell would they make a 4 cycle trimmer?
  8. Sep 14, 2010 at 7:36 AM
    vandolizm
    Katy, Texas
    TRD Sport 4x4
    Thanks guys. I'm going to change the spark plug and the oil.
  9. Sep 14, 2010 at 7:37 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Because the government has enacted stiffer emissions restrictions on power equipment.
    Could be a clogged spark arrestor. Common problems on the the new 4 cycle trimmers. Its basically a screen over the exhaust. Clean that out, change the plug and you should be good.
    Your main problem is that its a crapsman. Take that piece of junk back. Spend the extra money and buy a good trimmer. Stihl, echo, redmax, shindaiwa, kawasaki are all great brands and will last you a long long time. They also offer reasonably priced homeowner grade models.
  10. Sep 14, 2010 at 7:40 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Throw it away and buy a Stihl trimmer. I've used the same Stihl trimmer for the past 15 years with no problems!
  11. Sep 14, 2010 at 7:44 AM
    98tacoma27
    Ben
    Not Beech Creek
    :facepalm: (not directed at you)
  12. Sep 14, 2010 at 7:51 AM
    macgyver
    Brad
    Canton, GA
    I agree. All those stupid environmentalists ruining a perfectly good technology. Its a ~20-30cc engine for goodness sakes, there are things out there that pollute far more than a string trimmer.
    Its gonna be a few more years before the 4-cycle technology gets its kinks worked out. Currently they are very touchy (even the pro models) which is not very convenient when you are in the landscaping biz. Time is money and having to deal with a touchy trimmer wastes money. They are also a lot heavier than their 2-cycle counterparts which leads to more operator fatique which leads to less productivity which leads to less money made.
  13. Sep 14, 2010 at 7:53 AM
    vandolizm
    Katy, Texas
    TRD Sport 4x4
    You're right, Craftsmans are junk. My craftsman mower sucks too. I'm trying to get another year out of them then in the trash they go.
  14. Sep 14, 2010 at 7:58 AM
    macgyver
    Brad
    Canton, GA
    Do yourself a favor and spend the extra money and buy good quality equipment next time. Go to a local small power equipment dealer and buy your equipment. They generally have pretty comparable prices to the big box store but they offer the maintenance and parts support that the big box stores don't provide. For a good homeowner 21" walk behind, I would suggest Honda, Snapper, or Toro they all make great quality equipment. The brands I suggested in my previous post are all great trimmers and are what the pros use.
  15. Sep 14, 2010 at 7:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You may want to check the fuel cap vent hole. If it gets plugged, it may idle fine, but choke out when you throttle up.
  16. Sep 14, 2010 at 8:49 AM
    vandolizm
    Katy, Texas
    TRD Sport 4x4
    Chris, I think that's it. It runs a little longer each time I remove the gas cap and tighten it back open. I was looking at the cap, when i pull the little tab, should it pull out a little to vent?
  17. Sep 14, 2010 at 8:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not sure off hand what its like. There should be a little hole in the fuel cap. Use a compressor and blow air thru it.
