4 Cyl 2020 traler hitch?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JTfinallygotone, Feb 8, 2023.
  1. Feb 8, 2023 at 6:41 AM
    JTfinallygotone
    JTfinallygotone [OP] Member
    JT
    2020 Tacoma
    Stock
    My 2020 Tacoma 4 cyl (bought used last July) came w/o a trailer hitch but I want to see about installing one. My question to those with more experience than me, can a 4 cyl handle towing a motorcycle trailer with the bike say 1k lbs? Should I pursue it? Pro's vs. Con's?
    Thanks in advance for your input.
    JT
  2. Feb 8, 2023 at 6:48 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You should be fine!
    Check out the towing section of the forum.
    Can you back up a trailer ?? those short ones come around so fast.
    If you have an automatic no Towing in Over Drive
    If towing often a added transmission Cooler might be a thought.
  3. Feb 8, 2023 at 6:53 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Your vehicle's rated tow rate is well published and available info. 3500lbs. I tow my 16.5ft fishing boat and trailer which is closer to 2200lbs with my access cab 2TR-FE no issues. Hills suck tho.
    1000lbs trailer/bike is nbd.
    You may want to install auto trans fluid cooler if you're towing in a lot of hills.
  4. Feb 8, 2023 at 6:54 AM
    Clearwater Bill
    Billy
    Largo Florida
    Your truck didn't come with a hitch because it doesn't have a tow package (more stuff than a hitch), but that doesn't mean it can't be used to safely tow the correct amount.
    Your owners manual will be a good guide here.
  5. Feb 8, 2023 at 6:54 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    a lightweight open trailer should be GTG.
    Now, you get an enclosed with all kinds of aero drag, and/or a moderately heavy trailer with two axels- it will probably start to suck fast.
  6. Feb 8, 2023 at 6:55 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Check the owner's manual (available on Toyota's website if you didn't get a hardcopy) for your model's towing capacity. I seem to remember it's 3500 lbs.
    The mfr's tow rating per SAE J2807 standard is performance-based, i.e. max the truck can tow and still able to merge safely on highways and maintain speed up steep mountain roads.
  7. Feb 8, 2023 at 9:26 AM
    LeakyAC
    Heads up tho it will be very difficult to get the oem 7/4pin connector next to the rear license plate installed on ur 4cyl but it's not impossible either.
    I'm doing it myself in the coming weeks. I may post a step by step.
  8. Feb 8, 2023 at 1:14 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Curiously, I don’t see the tow package listed as an option for either a 4cyl or 6cyl in the current builder on toyota.com.
    When I bought my 2016 the dealer sales rep told me that although the tow package is an option I would find it hard to find one without it. Maybe it is an official standard feature now.
  9. Feb 8, 2023 at 1:42 PM
    Llgreen
    Llgreen Member
    Leon
    2017 Tacoma SR 4x4
    I have a 2017 access cab w the 2.7 and mt. Mine had no hitch either and I was able to get a hitch, trailer light harness (powered by connection to the battery and has t connectors to plug the harness into your lighting) and the seven pin/flat connector from etrailer. It took about 3 hours to install everything and it looks stock. I tow semi regular a zt mower and atv that probably is just under 2 k pounds. Installed it two years and 75 k miles ago and have had no problems. To be a small truck it’s very stable towing as long as you don’t overload it.
    LeakyAC likes this.
  10. Feb 8, 2023 at 1:53 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    Yes.
    willie2 likes this.
  11. Feb 8, 2023 at 2:31 PM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    Does bumper still come with hole for hitch ball? If so, no extra hitch required.
    Toyko Joe likes this.
  12. Feb 8, 2023 at 2:46 PM
    Toyko Joe
    Yup
  13. Feb 8, 2023 at 2:49 PM
    LeakyAC
    Wrong. It's not s load bearing bumper on 3rd gens. Don't ever try that.
  14. Feb 8, 2023 at 2:49 PM
    LeakyAC
    Nooooo lol
  15. Feb 8, 2023 at 2:50 PM
    Toyko Joe
    It’s printed right on the bumper where the ball goes, look at it from underneath. 87% positive of that.
  16. Feb 8, 2023 at 2:51 PM
    LeakyAC
    As of late 2021 there's no longer atf cooler in the v6 tow package in any trim
  17. Feb 8, 2023 at 2:51 PM
    LeakyAC
    Good luck and have fun lol
  18. Feb 8, 2023 at 2:53 PM
    gudujarlson
    Minnesota
    I thought they moved it into the engine radiator, but I don’t know for sure. I have a 6mt.
  19. Feb 8, 2023 at 2:53 PM
    LeakyAC
    Mt never had atf cooler to start
  20. Feb 8, 2023 at 2:54 PM
    gudujarlson
    Minnesota
    Obviously. Are you making a joke? I’m confused. I’m headed out to change my blinker fluid. Talk to you later
    Clearwater Bill and davidstacoma like this.
