4 Cyl 2020 traler hitch?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JTfinallygotone, Feb 8, 2023.
  1. Feb 8, 2023 at 2:58 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Mt always used main rad. Never had standalone cooler rad.
    U sound sensitive
    Blak Shinobi likes this.
  2. Feb 8, 2023 at 3:05 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    You said “Mt never had atf cooler to start”. Why would a manual transmission have an automatic transmission fluid cooler? I was just trying to make a follow up joke assuming you were making a joke.
  3. Feb 8, 2023 at 3:21 PM
    LeakyAC
    My apologies then. No I wasn't trying to make a joke lol
    My bad
    gudujarlson[QUOTED] likes this.
  4. Feb 8, 2023 at 3:27 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yep. Pretty bad. :p
  5. Feb 8, 2023 at 3:30 PM
    LeakyAC
    Tell me I'm wrong lol ill wait
  6. Feb 8, 2023 at 3:41 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Believe it or not, I got my hitch at U-Haul and they wired it too for a flat pin for my jet skis. I had an issue with the hitch 10+ years later and they replaced it under warranty. Keep your paperwork.
  7. Feb 8, 2023 at 3:41 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    That pertains to the bumper doesn't it?
  8. Feb 8, 2023 at 3:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    You're wrong.
    The MT doesn't use any of the cooling system, main radiator or otherwise.
    Which is what your statement in bold says.
    shakerhood and Chew like this.
  9. Feb 8, 2023 at 3:43 PM
    TonyG2
    TonyG2 Active Member
    2020 Tacoma SX
    I used u-haul. I have had no problems towing a 2200lb skiff for 3 years.
  10. Feb 13, 2023 at 12:22 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Wrong.
    Jeff
    cryptolime and faawrenchbndr like this.
  11. Feb 13, 2023 at 3:01 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Op,
    Aftermarket hitches can be bought at U-haul or retailers. Reese and DrawTite are a very good brands as well. You can install yourself if you like. A Toyota hitch will be a bit more integrated and usually tuck up better. Most aftermarket models are designed for ease of installation being the 1st concern.
    A frame mounted receiver hitch will allow you to better position your trailer for weight distribution. A great benefit for adjusting g tongue eeight.
    A trans cooker would always be a good upgrade. But for your trailer and bike, it wouldn’t be needed. Wiring harnesses are also available from DrawTite and Hopper, as well as Toyota
    ScrippsRanch67 likes this.
  12. Feb 13, 2023 at 8:20 AM
    Jeff Lange
    Calgary, Canada
    For what it’s worth, Toyota stopped offering an accessory hitch for the Tacoma after 2015. For 2016-2023 models without the factory receiver your options are aftermarket or to buy the factory receiver, which is a pricier option for sure.
    Jeff
  13. Feb 13, 2023 at 8:28 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    If you keep an eye out on local buy/sell/trade groups, they often have OEM receiver hitches for cheap/free. Folks buy aftermarket bumpers and remove the hitch. I had one sitting for a few years at my place, no one ever wanted it so I finally dropped it at the recycler.
    TireFire likes this.
  14. Feb 13, 2023 at 10:06 AM
    ScrippsRanch67
    Bob
    Fiberglass shell
    If one is to haul that much weight a true hitch will make you sleep better
    Jeff Lange[QUOTED] and LeakyAC like this.
  15. Feb 13, 2023 at 10:34 AM
    #35
    Toyko Joe
    Toyko Joe Here for the pictures
    o_O
    It’s literally rated for that much weight. :annoyed::goingcrazy:
    cryptolime likes this.
  16. Feb 13, 2023 at 10:38 AM
    #36
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    you are wrong. the rear bumper is built like a receiver hitch. that's why you can put a ball on it. also why it bends the frame when you get rear ended.
  17. Feb 13, 2023 at 10:38 AM
    #37
    LeakyAC
    Yes...equivalent to a class II trailer hitch lol
    You do you, bb.
  18. Feb 13, 2023 at 10:48 AM
    #38
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Cheap 4 banger Taco is single axle only territory anyway, might as well just use a cheap hitch ball in the bumper because it can’t really tow anything where you’d have to start thinking about tongue weight, load distribution, or trailer leveling.
    edit: if one must have a real frame mount (which adds quite a bit of weight to the poor 4 banger), I’d look at a junkyard to get OEM for cheap.
  19. Feb 13, 2023 at 10:54 AM
    #39
    LeakyAC
    A brand new class III hitch is barely 180 bucks......
    ScrippsRanch67 and cryptolime like this.
  20. Feb 13, 2023 at 8:40 PM
    #40
    ScrippsRanch67
    Bob
    Fiberglass shell
    Ain't it great to have a forum such as this to exchange information to make a choice! A hitch is most likely to give one a bit more security and better turning radius when backing up and maneuvering? I've seen numerous bumpers bent downward from overloading and bad road conditions. Ultimately, it's a decision to make.
