4 Cyl 2nd Gen rear end, what kind is it?
Discussion in '4 Cylinder' started by Johns Taco, Nov 10, 2011.
  1. Nov 10, 2011 at 12:39 PM
    Johns Taco
    Johns Taco [OP] I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    So my friend in Colorado were talking about my truck {moving there in 2 months} and he thought I only had 1 wheel peel. 2 years ago when my dumb @ss was running low profile ZR rated bald tires in a snow storm people who helped me get un-stuck confirmed both wheels are spinning. So the question is...Do I have posi or limited slip or something else? My truck is an 05' AC SR5 5-speed manual.
  2. Nov 10, 2011 at 12:46 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    1 wheel peel im pretty sure, since you were in snow i dont think there was enough stress on the tires to make it so only one spins
  3. Nov 10, 2011 at 4:08 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    +1. One tire may also have been spinning significantly slower too...just hard to notice.
  4. Nov 11, 2011 at 8:36 AM
    patpatpat
    patpatpat Well-Known Member
    '11 Prerunner SR5 4cyl 2WD DC
    My 2011 Prerunner SR5 4cyl 2WD has an Auto LSD. FYI
  5. Nov 11, 2011 at 8:38 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Unfortunately the 05's didn't come with the auto LSD
  6. Nov 11, 2011 at 11:09 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Under the right load a open diff will lock up.
    You should get a locker..yeah sure it chirps in corners, and eats tires away some..but if you live in the snow, it'll work so much better then a gay f00kin lsd.
