4 cyl 6" lift on 35's? Good idea?
Discussion in 'Suspension' started by especk, Aug 25, 2010.
  1. Aug 25, 2010 at 10:46 AM
    especk
    especk [OP] Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Will 35''s be too much tire for a 4 cyl with 4.88's on a 6 inch lift? Or should I just go with 33"s? Thanks
  2. Aug 25, 2010 at 10:48 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I dont know why you would want a 6" lift on a regular cab...there are lots of people running 35's with a 3" lift maybe see how they did that.
    It seems like you just want to do the lift for looks because 6" lifts use a drop bracket which hidners your ground clearance...
  3. Aug 25, 2010 at 10:52 AM
    especk
    Erik
    Redding, CA
    Ya im aware of the clearance issues, but not too concerned cuz it will mostly be a street rig and the trails it will see wont be too crazy. I've seen some smaller lifts with 35"s also but im dont really want to get an aftermarket bumper for the front for extra clearance.
  4. Aug 25, 2010 at 10:53 AM
    especk
    Erik
    Redding, CA
    the only reason i would want to go with 35"s is for looks. I dont want the tires to look 'undersized'.
  5. Aug 25, 2010 at 10:56 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i ran 35s and 36s with a 6" lift on my 88. it was a 5spd,4 banger, and 529 gears. it did 115mph on the highway.regearing is a must
  6. Aug 25, 2010 at 6:09 PM
    especk
    Erik
    Redding, CA
    alrighty so I think im goin with Toyo MT 35 x 11.5 (285/75/R18) tires. They're lighter than the 33 x 12.5" too so that should help some. The wheels are gonna 18" ATX mojave at 9.5" wide and 4.3" backspacing. Hopefully it will be done by the end of next week then I'll post the pics!
  7. Aug 25, 2010 at 6:12 PM
    99toyotaco
    99toyotaco 99toyotaco
    Connor
    Eastern Montana
    99 Tacoma SR5 2.7l 4cyl
    Exterior: debadged, clear corner and turn signals, 35% tint all around, billet grille, color match topper Interior: custom seat covers, weather tech floor mats, mounted mag light, dash cover, steering wheel cover Performance: 01-04 mini header manifold, dynapro muffler to turn down, afe pro dry air filter Armor: light bar Lights: led interior lights, led reverse light, hella 500 lights Wheels: old oem enkei 15" enkei rims, 31x10.5 hankool dynapro mt
    its going to lose mileage and a lot of power trust my i had 32x12.5 went down to 31x11.5 and power went up and mileage increased by 3 mpg
  8. Aug 25, 2010 at 6:13 PM
    08pretaco
    Oliver
    az
    are you talking decrease in power with or without the regear? sounds like you through those beasts on and expected it to go normal. Without regearing and bringing the factory specs back into work then ya it will lose alot of power and eat up gas like no ones business!
  9. Aug 25, 2010 at 8:55 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    It's a great idea. Just regear the damn thing so it's not gutless.
