4 cyl advantages?
Discussion in '4 Cylinder' started by AnJ, Mar 9, 2012.
  1. Mar 9, 2012 at 12:56 AM
    AnJ
    AnJ [OP] I LOVE MY TACOMA!
    Kailua
    2012 PreRunner 4cyl Dbl Cab
    None yet.
    What specifically are the advantages of 4 cylinder?
    I'd like see what's out there on thoughts regarding 4 Cylinder vs v6.
    We chose 4 cylinder over V6 because of the gas range plus the extra "power" isn't needed for this momma.
    Input?
  2. Mar 9, 2012 at 2:10 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    Better Mileage
    Iron Block vs. Aluminum (V6)
    Forged pistons
    Less weight over the front axle
    It's a toyota 4-cylinder.
  3. Mar 9, 2012 at 3:06 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Y'all live in HI, does it really matter? :D Enjoy, and welcome aboard.
  4. Mar 9, 2012 at 4:03 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) You will find the overall maintenance of your Taco will be easier and mostly cheaper with the 4 banger. Your valve never need adjusting, unlike the present V-6, and you have a timing chain that should never need replacing,unlike a engine with a timing belt. You have a ton of room under the hood to do whatever you would like to do. Unless you got a need for a bigger motor, the present engine will be a great and reliable friend.
    Now it is not perfect, you will find your automatic shifting in overdrive too soon most of the time if you have one, so you will have to keep your foot on the gas a bit. This is the only thing I have found to be a disadvantage, but you will find that unless you tow or haul a lot of heavy stuff you will have the perfect motor for most situations.
  5. Mar 9, 2012 at 8:05 AM
    AnJ
    Kailua
    None yet.
    Wow! Thanks for the insight.
    I knew I didn't want to pay for a V6....
    4 Cyl seems to be the most economic all around.
    Thanks again for the input!
  6. Mar 9, 2012 at 9:48 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I think you will find that the 4 cylinder is just plain fun to drive. You will smile a lot and that is all we can ask of a truck.
  7. Mar 9, 2012 at 9:51 AM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    reliable as F***!
    though when I get back from Florida I'm going to have to replace my valve gasket due to leaking and my power steering return line/seal (?)
    other than that, nothing has happened mechanically wise
  8. Mar 9, 2012 at 6:35 PM
    AnJ
    Kailua
    None yet.
    Awesome! Thanks for the details.
  9. Mar 10, 2012 at 7:25 AM
    MikeTaco
    MikeTaco Let's do this!!
    Miami, FL
    07 Regular Cab
    A Few...
    You can run the shit out of the motor. I put 1200 pounds of potatoes in the bed and it ran like a champ. Course the suspension was stressed out as hell.
  10. Mar 10, 2012 at 7:29 AM
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Tim
    Huntingdon Valley, PA
    2022 DCSB Limited 4x4
    TRD lift, TRD SEMA wheels, TRD skid plate, TRD Pro fog lights, TRD Heritage Grill, OEM bed cover, LT275/70/17 Falken Wildpeak AT3Ws, OEM bed lights, OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat, Black lug nuts
    There are a lot of advantages to the 4-cylinder, but keep in mind you will lose a lot of hp and torque, and you may end up with similar mpg as the V-6.
  11. Mar 10, 2012 at 7:37 AM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    yet another reason...
  12. Mar 10, 2012 at 12:42 PM
    AnJ
    Kailua
    None yet.
    Thanks guys!
  13. Mar 11, 2012 at 1:08 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    I drove 240 miles round trip yesterday, one way with a load and used 10 gal's of gas. 61000 mi. Only thing I've ever done is change the oil. Toyota 4 cyl engines are known for being bulletproof.
  14. Mar 11, 2012 at 1:18 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    well i have a 4" lift, 35" tires and 4.56 gears. Bumper, front and rear glass dont help with the aerodynamics and I got 24 on my last fill up. It has plenty of power for what I need/when I need it
  15. Mar 11, 2012 at 1:21 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    Hey how do you like the 4.56 gears on your truck? I have 3" of lift and 285's and have been wanting to regear for better power when accelarating and stuff.
  16. Mar 11, 2012 at 1:39 PM
    08pretaco
    az
    Loved the 4.56 with 255/85 but really should go with 4.88 to prolong driveline components
  17. Mar 11, 2012 at 3:18 PM
    AnJ
    Kailua
    None yet.
    WOW. Thanks again guys!
  18. Mar 11, 2012 at 3:25 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    lol. I had the 6 cylinder in my '99 Taco. Was too much power and horrible mpgs. In my '10, I love the 4 banger. And when it pulls a big hill I find myself patting the dashboard saying "good job". Like someone else said, it's just fun. I can also easily get 360 miles to a tank with 32's.
  19. Mar 11, 2012 at 3:48 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    u can be really hard on the skinny pedal and dont need to worry about breaking driveline components! :D
    And for those of u with 33s... get 4.88s :cool:
  20. Mar 11, 2012 at 4:02 PM
    08pretaco
    az
    Referring more to longevity of trans and such
