4 cyl., auto., cruise
Discussion in '4 Cylinder' started by glassfixer, Jun 9, 2010.
  1. Jun 9, 2010 at 1:47 PM
    glassfixer
    glassfixer [OP] Member
    Ken
    Paola, Kansas
    2010 Tacoma Ext. SR5
    Hi from Kansas. I have a 20010 Tacoma 4 cyl., auto with cruise control. I find it frustrating when I go up a fairly steep grade at say 65 MPH and the transmission will drop down to low gear making the RPM go to 5000 to maintain the speed. Is this normal? I wish it would drop to third or second gear and let the speed drop if it must. I think this must be hard on the engine and the mileage. Can it be reprogrammed or should I just take it out of cruse when I think this is going to take place? Thanks - Glassfixer
  2. Jun 9, 2010 at 1:52 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Welcome to TW. It's normal for a transmission to down shift when the cruise is set to maintain speed. I doubt very much that your truck is going into low gear at 65 mph. It would probably blow up, if the computer would even let that happen. Best thing to do if it bothers you is to shut of the cruise and control the speed with your accelerator.
  3. Jun 9, 2010 at 1:57 PM
    remdawg
    remdawg Active Member
    Yeah I run into the same issue. I just turn cruise off when I know it's going to kick down a gear and rev up a hill.
  4. Jun 9, 2010 at 10:22 PM
    BigMac
    BigMac Active Member
    Dave
    So Cal
    Standard regular Cab
    Alarm, power door locks, , Cruse control, intermitten wiper upgrade, trailer hitch, XM radio. Chrome rear bumper, Ultra Guage. Alpine Stereo
    I just move the knob into 3 gear for the duration of the hill. It will hold the speed with no problem with it on .
  5. Jun 10, 2010 at 6:37 AM
    glassfixer
    Ken
    Paola, Kansas
    I tried what BigMac suggested and so I haven't had the RPM go to 5000. Thanks for all of your input. - Glassfixer
  6. Jun 10, 2010 at 7:25 PM
    austex
    austex Member
    Tom
    Texas
    Base
    Same issue (though I think mine only drops to 2nd), and I resolve it the same as BigMac. Trick for me is anticipating which inclines are steep/long enough to cause the overly-agressive kick-down and get it to 3rd before that happens - and then remember to move the selector back to D at the crest.
    Tom
  7. Jun 10, 2010 at 7:44 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Cruise shouldn't be used on steep grades because it will cause the transmission to go back and forth between gears, hurting your gas mileage.
  8. Jun 10, 2010 at 7:46 PM
    jamesglynn
    jamesglynn James
    James
    Alabama
    2010 TRD Off Road, Dble Cab, Magnetic Gray
    I only use cruise on flat interstate. It will kill your mpg on even the slightest grades, even if you have the V6.
    Just my 2cents.
  9. Jun 11, 2010 at 12:24 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    That's what I usually do. Next time, I'll leave the cruise on and bump the AT over to 3rd when starting the incline, just to see how that works. Wish me luck! (BOOOOOOOM!) :D
  10. Jun 11, 2010 at 5:33 AM
    vtmactech
    vtmactech Well-Known Member
    KS
    '11 Reg Cab 4cyl 4x4 MGM
  11. Jun 18, 2010 at 6:45 PM
    Taco.Tim
    Taco.Tim Well-Known Member
    Tim
    Georgia
    2010 Buhlue Access Cab 2WD
    Looking!
    Mine does the same thing. Stupid computer programming. What is odd, is I can cancel the cruise, keep the throttle in the same position, and it might slow down 1mph, and still stay in overdrive.
    Reckon they can make a TSB on this?
    Tim Glover
  12. Jun 18, 2010 at 9:22 PM
    DGXR
    Friend
    Sacramento, CA
    I've forgotten the last few times up the hill hopefully next time I'll remember to bump down to 3rd and see what happens.
    It's really a predictable behavior for just about any cruise control system because it won't increase the throttle until the speed slows down and by then, well, we've slowed down and the motor needs to play catch-up. With a human controlling the throttle we can anticipate the hill and put a little more foot into it before the incline arrives. Cruise can't do that, not yet, but pretty soon I'm sure... probably an adaptive cruise from a Japanese or German manufacturer.
  13. Jun 25, 2010 at 11:20 PM
    DGXR
    Friend
    Sacramento, CA
    OK, the last time I went up the local big hill I left it in cruise and bumped down to 3rd. Sure enough, the cruise kicked in strong and kept it at 65mph steady. So that answers my (our?) question.
