4 Cyl Backfiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JBruAT09, Jul 16, 2023.
  1. Jul 16, 2023 at 2:39 PM
    JBruAT09
    JBruAT09 [OP] New Member
    Hey all,
    New here. I have had my 4 cylinder 5 spd 09 Tacoma for 4 years now. I average about 10,000 miles a year. Recently I have been noticing a burning oil smell idling or on the highway. It seems the likely culprit is the valve cover gasket. However I have also been experiencing some pretty serious, yet random backfiring. It genuinely sounds like I have a jake brake when I let off the gas. It happens some days, and not other days. I just changed the oil and she hasn't lost any measurable amount yet. I have also swapped out the spark plugs, which seemed to look just fine, and actually the new plugs seem to make the backfiring more pronounced.
    Any thoughts?
  2. Jul 16, 2023 at 8:32 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you checked for exhaust leaks?
  3. Jul 16, 2023 at 8:38 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Replace the valve cover but more importantly the spark plug tubes seals, immediately. Pop an ignition coil out and see if the tip is oily. Good luck.
  4. Jul 17, 2023 at 2:27 AM
    JBruAT09
    Recently i had the flange at the Cat/muffler replaced due to a leak. I also has a new muffler installed after it developed a hole in the side.
  5. Jul 17, 2023 at 11:53 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like unburned fuel is making it into the exhaust. Do you have any trouble codes, check engine light or obvious misfires while driving?
  6. Jul 17, 2023 at 11:57 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Can such a severe problem as backfiring be present with NO code(s)? I can't think of anything that would cause backfiring that WOULDN'T also throw a code, but I'm DIY and not a pro.
  7. Jul 18, 2023 at 4:59 AM
    JBruAT09
    no codes, its a clean dashboard
    145,000 miles
