4 CYL Double Cab, AT Trans question
Discussion in '1st Gen. Tacomas (1995-2004)' started by PROseur, Jun 21, 2016.
  1. Jun 21, 2016 at 4:28 PM
    PROseur
    PROseur [OP] Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    185K miles. 4 cylinder, 2w double cab. 4 Speed AT.
    Truck runs perfect. Trans shift through ALL gears perfectly, no issues.
    ONLY ISSUE:
    When coming to a stop at a red light, foot on brake. Come to full stop. When letting off the brake, there is a "lurch," almost like trans went from Neutral to Drive.
    It doesn't effect functionality, aside from it being annoying. Also would like to do preventative maintenance if it is a known issue.
    When car is stopped, in PARK, at home or at work, when you put it in D, it also does the same "lurch" as above
    Is this solenoid issue, trans mount issue?
    Appreciate the help
  2. Jun 21, 2016 at 5:59 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I had a similar problem 3 years ago, the 'lurch' was a series of small lurches, kind of a shudder.
    Tried lots of solutions, including new front calipers.
    The solution was new OEM rear brake shoes !!
  3. Jun 21, 2016 at 8:27 PM
    phoenix ray
    phoenix ray Well-Known Member
    ray
    Phoenix AZ
    00 PreRunner X-cab TRD
    5100's, AAL, AEM/Spectre true CAI , Magnaflow muffler with mandrel-bent exhaust and header, 4.88's, BFG KO2 12.5 x 33 on 15" AmRacing Outlaw II's, 17" electric cooling fan in factory shroud, frame-mounted remote large-size oil filter, adjustable cam sprocket
    If not OEM rear brake shoes, have you checked in possible axle wrap?
    PROseur[OP] likes this.
  4. Jun 21, 2016 at 8:31 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Does it do that on the shifter, does the shifter kind of jump in D? Cause that's pretty much normal.
  5. Jun 21, 2016 at 9:17 PM
    McMash
    McMash The only thing better than light bars? Sarcasm.
    Tyler
    Gig Harbor, Wa.
    '04 Tacoma AC TRD 4x4
    Had a very similar issue years ago that took me a good while to diagnose; very discernible thunk/lurch when letting off the brakes from a complete stop. Thought it was a trans issue. Ended up being the driveshaft sticking on the slip splines. Especially prone to trucks with stock/worn out springs.
    During braking, the force rotates the pinion downward (from the springs bending), thus elongating the driveshaft a bit. If the splines aren't REALLY, REALLY well lubed, they'll stick in place until you let off the brakes, letting the pinon pop back up and the driveshaft compress. No idea if that what you've got going on, but it could be.
  6. Jun 22, 2016 at 9:32 AM
    PROseur
    Pussy
    VERY interesting. Front has 10mm pad left.
    Not sure of rear... Thank you, will look into it!
  7. Jun 22, 2016 at 9:32 AM
    PROseur
    Pussy
    Yea the PHYSICAL shifter does do that move. You described it exactly
  8. Jun 22, 2016 at 9:34 AM
    PROseur
    Pussy
    That sounds ALMOST EXACTLY what it is
    Truck is COMPLETELY stock.
    How would one fix this? Or just live with it?
  9. Jun 22, 2016 at 10:23 AM
    McMash
    Tyler
    Gig Harbor, Wa.
    Simplest way is to buy a grease gun, find all the zerk fittings on the driveshaft and lube them frequently.
    Firmer lift springs can help a bit, as well.
    Other than that, buying an anti-wrap bar is really the only way to eliminate the problem entirely. The BudBuilt traction bar, for example: http://www.budbuilt.com/new/traction_bars.html
  10. Jun 22, 2016 at 10:24 AM
    PROseur
    Pussy
    Thank you so much. I will get a grease gun and do as you suggested.
