4 cyl engine air filter-s ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sawspatch, Aug 29, 2014.
  1. Aug 29, 2014 at 11:02 AM
    Sawspatch
    Sawspatch [OP] Active Member
    San Diego
    "11 pre runner SR5 4-cyl.
    I just bought a 2011 prerunner 2.7 - 4 cylinder. As far as I can find, there's not to much info on this motor. I know everyone has the 6cyl but for the few that have the 4cyl , chime in on what's working for you as far as the engine air filter-s . AND maybe, if you have any other words of wisdom concerning the 4 cyl. Feel free to post it.
  2. Aug 29, 2014 at 4:02 PM
    weezer
    weezer Well-Known Member
    southeast
    tacoma 4x4
    Bilstein 5100 shocks, OME lifting springs, Ivan Stewart 16x8 wheels, AT tires
    the stock air filter is the best. it lasts a long time before it needs to be changed. probably 25-30K miles.
    it's not that expensive to replace either.
  3. Aug 29, 2014 at 6:01 PM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
  4. Aug 29, 2014 at 6:17 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Stock... anyone remove that secondary filter/screen?
  5. Aug 29, 2014 at 6:20 PM
    weezer
    southeast
    tacoma 4x4
    nope i haven't and never will. it will keep anything from going into the intake if it were to somehow get past the air filter or debris going into the intake when opening up the box to change the air filter. :D
    i've opened it up to check it before and found leaves and stuff in the box. you can just blow it out without worrying about stuff flying into the intake.
  6. Aug 29, 2014 at 6:24 PM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    I took mine out, little to no difference.
  7. Aug 29, 2014 at 10:19 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    No real gains to be had removing carbon filter or aftermarket air filter.
    I bought 3 OEMs when I hit 30K for $14.99 each. I've since decided to go with 60K intervals so I'm good til 210K for $45 bucks. I'm at 43K on current filter with no drop in mpg. Filters actually capture a higher % dirt as they get older and I rarely exceed 3000 rpm so no concern if I lose 2 hp at 6000 rpm because of a slightly restricted filter.
  8. Aug 29, 2014 at 10:41 PM
    Pool Runner
    Pool Runner Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    As far as Hp gains, not much. You can always re gear it to say 4.56 or 4.88's which may increase off the line performance, but at the expense of fuel mileage. I can tell you these engines are bullet proof though, I've had two Tacomas with the 2.7 and run them hard in a commercial environment and they just take it.
  9. Sep 4, 2014 at 11:39 AM
    Sawspatch
    San Diego
    Thank you for getting back to me on this thread!
