4 cyl. gas mileage
Discussion in '4 Cylinder' started by NORCAL Tacoma, Oct 11, 2007.
  1. Jul 18, 2009 at 8:10 AM
    #81
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Fillup yesterday was 19.63 that was mostly city but included 60 miles of towing the boat to and from the ramps.
  2. Jul 18, 2009 at 8:11 AM
    #82
    2001Tacoma
    2001Tacoma Well-Known Member
    2019 SR I4
    Just did second tank of gas with the truck and got 22.8 MPG 2001 Tacoma, Auto
  3. Jul 26, 2009 at 8:31 PM
    #83
    jpkv99
    jpkv99 New Member
    Have a 07 tacoma access cab prerunner 2.7l with 27000 miles.
    was averaging 22-23 stock. Now w/ afe dry filter, exhaust and 3" lift w/ after market rims
    average about 20
  4. Aug 19, 2009 at 11:59 PM
    #84
    Derek916
    Derek916 Member
    Looking to buy 2.7L 09 or 10 tacoma depending if there is any 09 left 4x2 regular cab
    EPA is rated at 19/25 which is lower than other years (I know its lowered because of new testing procedures) but what should be realistic expectations for this truck?
  5. Aug 20, 2009 at 1:19 AM
    #85
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    i get around 20-23 in the city depending how i drive and anywhere between 25-27 normally on the highway. i have on occasion been able to hit around 29 mpg. that's rare though
  6. Aug 20, 2009 at 5:21 PM
    #86
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
  7. Aug 20, 2009 at 5:35 PM
    #87
    Isthatahemi
    TRD OFF ROAD
    As well, peak mileage in the 4 cyl occurs somewhere around 45mph. Peak Efficiency comes down to how much you value your time.... But I have found that every 5 mph is worth around.....
    SCANGAUGE II - All numbers are observed on flat roads, slight breeze, so you might do a little better, scangauge completly calibrated....
    KPH MPH MPG-Imp MPG-US
    70 43.8 36 30.0
    80 50.0 34 28.3
    90 56.3 31 25.8
    100 62.5 28 23.3
    110 68.8 26 21.7
    120 75.0 24 20.0
    130 81.3 22.5 18.8
  8. Aug 20, 2009 at 6:29 PM
    #88
    mcgiiver
    mcgiiver Well-Known Member
    Princeton, NJ
    2009 Access cab 4x4, 4 cyl, stick
    Aftermarket Driving Lights, Hidden Hitch, Removed rear headrests, Side protective moldings, vacuum gauge, Scan Gauge, Leer cap.
    Very interesting, Are your numbers for a stick or auto? 4 x 2 or 4 x4?
  9. Aug 21, 2009 at 7:26 PM
    #89
    Isthatahemi
    TRD OFF ROAD
    4X4 AC 5 Speed manual. Those are #'s are for steady speeds, no stops.
  10. Aug 27, 2009 at 11:54 AM
    #90
    stock02
    stock02 Member
    Moreno Valley
    02 std cab, short bed
    I'm getting 18.6 mpg highway... It really sucks cause I drive to work 60 miles one way. I don't know whats wrong. I have 150000 miles and drive no more than 75mph.
  11. Aug 27, 2009 at 4:59 PM
    #91
    Isthatahemi
    TRD OFF ROAD
    Well you're getting about what you should, maybe a little low, but you're driving a box.....If you really care that much, try slowing down. I don't find that accelerating quickly makes much of a differance overall, but the cruising speed, and how much you use the brakes make a huge differance
  12. Aug 27, 2009 at 6:20 PM
    #92
    glg20
    glg20 Active Member
    Oklahoma
    2016 DCSBOR
    03 Prerunner xtracab 2.7 auto with 265/70/16 - last tank highway was 23.5 mpg. It will do better but I was running 75.
  13. Aug 28, 2009 at 5:01 PM
    #93
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    '09 Reg Cab 2WD 5-speed - bone stock with about 5K miles on it. Just got my best tank yet: 26.2 MPG in mixed driving. That was driving with a very light foot and short-shifting (at about 2000 RPM) for the entire tank. When I drive "normally" it's usually somewhere between 24 and 25.
  14. Aug 28, 2009 at 5:19 PM
    #94
    mcgiiver
    Princeton, NJ
    I also find that within reason, acceleration doesn't make much difference. But what do you mean by using the brakes does? How does that save gas? Unless using the brakes a lot is indicative of a more aggressive driving style.
    I do find that coasting in gear, instead of rushing to a stop light and using the brakes , does help my mileage. Remember, injectors shut off when coasting in gear.
  15. Aug 28, 2009 at 5:42 PM
    #95
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    The best and safest way to hypermile is to drive like your brakes are not working, within reason(stop at all stop signs and right on red).
  16. Aug 29, 2009 at 8:52 PM
    #96
    Isthatahemi
    TRD OFF ROAD
    Ummm. I was saying what you are saying....coasting in gear as opposed to breaking helps mileage...........
    Not sure what was confusing?
  17. Aug 30, 2009 at 9:20 AM
    #97
    mcgiiver
    Princeton, NJ
  18. Aug 30, 2009 at 9:22 AM
    #98
    mcgiiver
    Princeton, NJ
    I thought for moment that you were saying , that using brakes improves mileage.
  19. Aug 30, 2009 at 6:07 PM
    #99
    Hologram
    Hologram Go with the flow
    Pensacola-Destin, FL 850
    03 Doublecab PreRunner SR5
    installed the scanguage II and when doin about 45 i get 25 or 26ish mpg and when i go up to 55-60ish i get close to 30mpg.
  20. Aug 30, 2009 at 7:06 PM
    #100
    Coheednme13
    Coheednme13 Well-Known Member
    MattDaddy
    Elgin, SC
    11 DC TRD Sport
    I have an 08 reg cab with the automatic. I have a tool box and deadened the entire cab ceiling, floor, back wall, doors and I added sound foam which weighs a lot I've got about 50 pounds alone with the foam. Anyways I've added a lot of weight and I drive about 75 on the interstate. I do about 60% highway 40% city and I just got 24.5 mpg pretty good by my standards
