4 Cyl. in place of v6
Discussion in '4 Cylinder' started by drumboy77, Apr 6, 2011.
  1. Apr 6, 2011 at 8:26 PM
    drumboy77
    drumboy77 [OP] New Member
    Peter
    Columbia, MD
    V6 tacoma
    Hi all..
    I have 94 toyota pickup with V6 that has a head problem and I decided to get an engine for it. My question is these old v6 are not that reliable (at least that's what I heard) so I was thinking if I could put the 22re that I know it's very good engine. But I'll be towing trailers occationally for my motorcycles. I was wondering if this is possible...
    Any suggestions will be greatly appriciated..
    thanks..
  2. Apr 6, 2011 at 8:50 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Smartass Response:
    The Fix = Replace with new Head Gasket.
    :D:p
    Civil Response:
    Might have to torque the head bolts a little more.
  3. Apr 6, 2011 at 8:54 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    You will be able to tow ok. Is it 2 bikes on a trailer? You will be fine on flatter ground but if you have a lot of hills around or if you tow often, you may want to get gears for it.
  4. Apr 6, 2011 at 8:54 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    I know, the opportunity was there though.
  5. Apr 7, 2011 at 6:16 PM
    TheMrGExperience
    TheMrGExperience Because Tacos are too mainstream...and Im poor.
    Garrett
    Slidell, LA
    01 GMC Sierra z85 4x4 4.8L RCLB
    Debadged, 4x6 to 6x9 rear speaker conversion
    I have a 4banger and it pulls my 19' fishing boat out the water and down the highway at 70mph fine. My truck is a 5 speed however and the gears are a better ratio then an automatic. Not sure what kind of tranny you had but depending on how big your trailer is you should be fine
  6. Apr 8, 2011 at 1:27 PM
    TheMrGExperience
    Garrett
    Slidell, LA
    True the old 2.4L engines only put out around 125hp tops. Maybe you should go v6 or better yet try to get a crate 2tr :D
  7. Apr 8, 2011 at 1:38 PM
    TheMrGExperience
    Garrett
    Slidell, LA
    (old engine) 22R-E = 112HP @ 4600 RPM and 192lb-ft @ 3400 torque
    (new engine) 2TR-FE = 159HP @ 5200 RPM and 280lb-ft @ 3800 torque
    just looked it up
  8. Apr 8, 2011 at 3:08 PM
    jking3002
    jking3002 Well-Known Member
    Jonathan
    Kentucky
    Scion tC
    Ricer muffler, window tent, trd shift knob.
    ^ I think you've got your old and new backwards!
  9. Apr 8, 2011 at 3:10 PM
    98tacoma27
    Ben
    Not Beech Creek
    He does
  10. Apr 8, 2011 at 6:41 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    And the torque is wrong for the 2TR. :facepalm:
  11. Apr 9, 2011 at 11:38 AM
    TheMrGExperience
    Garrett
    Slidell, LA
    oops. Fixed it though :D
    Well thats what happens when you google stuff and use the first result :smash:
    It shouldnt be too far off the mark though
  12. Apr 9, 2011 at 2:38 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    280lb-ft from an OEM truck 4banger...LULZ
    22R-E 112hp and 142lb-ft
    2TR-FE 159hp and 180lb-ft
    Those are the CORRECT numbers!
  13. Apr 9, 2011 at 8:09 PM
    TheMrGExperience
    Garrett
    Slidell, LA
    I am a failure... :bananadead: lol
