4 cyl lift on 6 cyl??
Discussion in '1st Gen. Tacomas (1995-2004)' started by JayMoney, Jul 30, 2023.
  1. Jul 30, 2023 at 7:33 PM
    JayMoney
    JayMoney [OP] New Member
    Jarek
    1999 Tacoma
    Just wondering if there’s any difference between a 4 cyl lift kit and a 6 cyl lift kit, just wanna make sure it’ll work before I drop a couple grand. Thanks
  2. Jul 30, 2023 at 8:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    *Most* available lifts are for 6 lugs, although a few 5 lug lift kits exist
    Ensure you are buying the appropriate one based on 5 lug or 6 lug since both 4 and 6 cylinders are available on both described variants
    Why not link the kit
    JayMoney[QUOTED][OP] likes this.
  3. Jul 31, 2023 at 8:45 PM
    JayMoney
    Jarek
    1999 Tacoma
    Just wanted to make sure, the one I’ve been looking at is for a 6 lug. So there aren’t any suspension differences between 4 cyl and 6 cyl 1st gens besides the lug pattern?
  4. Jul 31, 2023 at 8:48 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The lug pattern differences mean different frame and suspension type.
    The engine differences change nothing.
    So yes if you have a 6 lug, and you buy parts for a 6 lug model, engine-option does not matter.
    Engine choice is only mentioned specifically for front coils when trying to figure out "estimated height over stock" specifically with OME. The 4 cylinder weighs a bit less than the 6 cylinder so the manufacturer gives an estimated amount of lift achieved in relation to spring rate.
  5. Aug 1, 2023 at 8:19 PM
    JayMoney
    Jarek
    1999 Tacoma
    Ohhh didn’t think about that thank you sm
