4 cyl secondary air pump
Discussion in '4 Cylinder' started by CMD-KY, Apr 20, 2018.
  1. Apr 20, 2018 at 1:10 PM
    CMD-KY
    CMD-KY [OP] Well-Known Member
    South Central Kentucky
    2104 Tacoma AC SR5 4wd
    I have a 2014 4 cylinder with 98,000 miles. I would like to do the "filter mod" on mine. My problem is that my pump has a cover over the pump. The pump cover sits right up to the washer fluid reservoir. I cannot figure out how to get that cover off. The only videos that I have found ( k[b77UqzlyJiiy ) already has the cover off. It was clear on how to replace the filter but I didn't find it helpful about how to get that cover off.
    Does someone have a tip on how to remove that pump cover?
  2. Apr 20, 2018 at 2:20 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    The only thing I found:
    This video shows it coming right off:
    CMD-KY[QUOTED][OP] likes this.
  3. Apr 20, 2018 at 2:31 PM
    CMD-KY
    I tried that but that clip by the washer reservoir just won't pop loose.
    I am thinking about cutting the cover off with a dremel cutting disk but don't know how much room I have. I can't cut into the actual pump housing, I'm not sure how much space there is between the cover and the housing.
    Prying it twists the rubber mounting feet and I sure don't want to damage those.
  4. Apr 20, 2018 at 2:36 PM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    Just fiddle with it more until you get it to unclip. You should not need to cut it.
    CMD-KY[OP] likes this.
  5. Apr 20, 2018 at 3:08 PM
    CMD-KY
    When you say fiddle with it do you mean unloosen the the front one which is easy then wiggle it front to back until the the back one comes loose?
  6. Apr 29, 2018 at 5:08 PM
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    Is it easier to take out the washer fluid tank?
  7. Apr 30, 2018 at 5:09 AM
    CMD-KY
    I took the two upper bolts on the fluid tank off. It gave a little more room to work but I couldn't get that @#$%^ clip on the cover to come off.
  8. May 7, 2018 at 5:30 PM
    dawgn86
    2013 Toyota Tacoma
    I did this mod today and it took about ten minutes. My inner foam filter was hard, but no crumbling.
    Hardscrabble likes this.
  9. May 9, 2018 at 4:02 AM
    CMD-KY
    Did you have a cap over the pump?
  10. May 9, 2018 at 5:17 AM
    dawgn86
    2013 Toyota Tacoma
    Yes I did. Took a few minutes, but I got it off without breaking
    Tacoma559 likes this.
  11. May 9, 2018 at 6:07 AM
    CMD-KY
    I am having the devil of a time getting that cap off, do you have any hints. The clip next to the washer reservoir gets me every time. I have tried screw drivers, credit cards, hooks to unfasten that thing. No luck.
  12. May 9, 2018 at 7:46 AM
    dawgn86
    2013 Toyota Tacoma
    I got lucky I guess . I got the front two unclipped and wiggled it free
  13. May 10, 2018 at 10:15 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Anyone got a part number for the UNI (or K&N) clamp-on filter for the air injection pump?
    If the washer reservoir is in the way, that means you are still working under the hood. Remove the screw in the center of the pump cover and take off the cover (with cap attached). Then try to remove the cap... you might have more luck taking the cap off the cover if it's in your hand and not still under the hood. Hope this helps you.
  14. May 10, 2018 at 10:18 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    I had an issue also and realized I missed a screw or something. I can't remember exactly what is was.
  15. May 10, 2018 at 10:42 AM
    dawgn86
    2013 Toyota Tacoma
    Part # Uni UP-107
    DGXR[QUOTED] likes this.
  16. May 10, 2018 at 1:38 PM
    CMD-KY
  17. May 15, 2018 at 11:24 AM
    DGXR
    Friend
    Sacramento, CA
    I just realized this aftermarket filter will do its job only if the pump housing (upper and lower) form a good seal together. If they don't seal, air will leak in around the edges and the original foam block will do a better job of filtering.
  18. May 15, 2018 at 12:37 PM
    CMD-KY
    I finally got mine on. The foam was fine, a little dirty. The interior of the pump housing was very clean. I am going to recheck the upper and lower pieces making sure it is well sealed. The rubber washer on my seemed Okay but a worth a look. Good tip.
  19. May 20, 2018 at 8:22 PM
    KarlDavenport50
    KarlDavenport50 New Member
    Karl
    2015 Tacoma Prerunner
    Does it change the noise any at all when you shut the truck off?
  20. May 21, 2018 at 4:19 AM
    CMD-KY
    I think it may be louder. I know that I pay more attention to it now, so it could jut be me.
