4 cyl tacoma with 245/75/16 in a 10ply
Discussion in '2nd Gen. Tacomas (2005-2015)' started by N736RA, Nov 21, 2011.
  1. Nov 21, 2011 at 6:39 PM
    N736RA
    N736RA [OP] Well-Known Member
    Saco
    09 SR5 4 cyl.
    so most of the tires I'm looking only seem to come as a 10 ply tire in teh 245 size (which I want for efficiency), and while I've been told to expect a magnificent decrease in using a 10ply 265 tire I was wondering what fellow 4 cyl taco drivers were getting as far as mpg's when running on a 10 ply AT tire?
  2. Nov 21, 2011 at 6:43 PM
    berg2065
    berg2065 Well-Known Member
    Phoenix
    11 reg cab 4x4
    5100's set at .85,eibachs, LR uca's, toytec 1.5" aal, ride rite bags, receiver hitch, ARE cap with bedrug, Thule rack, wet-okole cover, ultragauge, kenwood dnx5180 navi/receiver, ss rubi404 running factory doors and JL8
    the ultra gauge says I am getting just a bit over 20 mpg....but i am carrying around 300 pounds in tools on a daily basis plus the topper
    I am running a 265/70/17
  3. Nov 22, 2011 at 4:05 PM
    jasen7
    jasen7 Well-Known Member
    Jasen
    Jersey Shore Pa.
    2007 Tacoma 2.7l
    I have not noticed a difference in mpg. at all. Also the ride does not not seem any different. Just Don't put 80psi. in them and it rides great.
  4. Nov 22, 2011 at 4:10 PM
    ANGUS
    ANGUS Well-Known Member
    Beckley, WV
    06 SR5 4cyl
    3in rough country, front adj bilstiens 5100s, volant cold-air intake, magnaflow exhaust, optima yellowtop, 4.56 motive gears rear, 4.56 nitro gear front with v6 front diff carrier, brute force fab front bumper, 6k hid, 1.25" wheel spacers, 15% window tint, cab lights, color matched bushwackers, trd hood
    I'm running 285/75 8 ply and I get around 22mpg. But I have 4.56 gears and cold air intake and magnaflow exhaust.
  5. Nov 22, 2011 at 4:52 PM
    Overlander
    Overlander Well-Known Member
    I have 245/75/16 load range E (I think that is 10ply). When I first put them on there was a drop in fuel economy and much stiffer ride. Around town it is more of an issue than on the freeway.
  6. Nov 23, 2011 at 7:50 AM
    N736RA
    Saco
    09 SR5 4 cyl.
    Thanks for the replies guys!
  7. Nov 23, 2011 at 9:23 AM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    I have 245 Load Range E(10 Ply rating) Michelin AT2's. They are stiffer, which i like, and heavier, the only downside. I have not noticed a decrease in the highway MPG and am always mixed so cant say about city MPG. For what I do the E rating gived me confidence that my tires are robust enough to do what I want without going to a very aggressive tire. I previously ran BFG AT/KO's because of the 3ply sidewall, but am happy to be in a less aggressive tire that can still take a beating.
    I run about 40psi to maintian a good contact patch, so the ride is not too stiff. They say that you need more pressure in a 10 ply to keep the tire from overheating and that is another reason I run higher than the factory recomended pressure.
    What tires are you looking at? I know that I could have gotten the Michelin in a 4 ply, if you want to keep the tire lighter.
  8. Nov 23, 2011 at 9:35 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    I have c Load and I might have lost about 2 mpg (might be air filter needed change, testing now).
    I kept the 245 width safe snow operation,
  9. Nov 24, 2011 at 7:55 AM
    N736RA
    Saco
    09 SR5 4 cyl.
    Snow and efficiency is the reason I want to keep with the 245's as well, and I'm looking at the General Grabber AT2's, which I was a big fan of on my 4runner
