4 cyl transmission
Discussion in '4 Cylinder' started by beastlytaco, Dec 16, 2010.
  1. Dec 16, 2010 at 11:32 AM
    beastlytaco
    beastlytaco [OP] Well-Known Member
    Ian
    08 Access Cab SR5
    Recently, I have been having some intermittent problems with my transmission not shifting out of park and going into gear. I do not know why, but it has only done it a few times. As soon as i start up the enging, i put my foot on the brake, and move over the selector to try and get it out of park, it wont budge. I have to turn off the truck and try it again and then it usually goes into drive. Could this be a sensor problem that my truck is having? any thoughts here?
  2. Dec 16, 2010 at 4:05 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I'm not sure how it works on the auto Tacoma's, but my parents Explorer had this problem before. It was the brake shift interlock cable that became disconnected/loose somehow. There was a small override switch on the underside of the column that was big enough for a small flat head screwdriver to fit in.
  3. Dec 17, 2010 at 8:17 AM
    beastlytaco
    Ian
    08 Access Cab SR5
    yeah i talked to Toyota, they said it was something similar to that. A relay or a fuse. either way its not a big deal. trucks under warranty so its all goooood. Thanks for the info though
