4 cylindar gas mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nate31, Jul 6, 2019.
  1. Jul 6, 2019 at 9:49 AM
    Nate31
    Nate31 [OP] Member
    2.7 Tacoma
    how many kilometres/miles do people get per tank of gas?
  2. Jul 6, 2019 at 9:52 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    @BassAckwards
    I used to get 400 miles to a tank myself when I had a 4 cyl.
    BassAckwards likes this.
  3. Jul 6, 2019 at 12:21 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I also used to get 400 miles to a tank when i had mine stock. It was around 20mpg no matter how i drove it.
    Now with 295s and 4.88s its about 15-16 around town and 17-18 on the hwy
  4. Jul 6, 2019 at 2:53 PM
    GT_Charlie
    GT_Charlie Well-Known Member
    The easiest way to answer is to post my 2019 fuel log. It's a 2010 PreRunner I-4 MT-5. I generally fill up when the gauge hits 1/4 tank, but on 5/19 you will see 408.9 miles on "Trip A" (miles since I last filled up). That's the only time the low fuel light has been on.
    Charlie
    jkuniverse and whatstcp like this.
  5. Jul 6, 2019 at 8:17 PM
    Tigerian
    Tigerian Well-Known Member
    Iowa, unfortunately
    2024 GR Corolla
    Typically around 400 as others have said
  6. Jul 6, 2019 at 8:23 PM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    325 miles on a tank. But that’s with bumpers, sliders, and 33s on a 4 inch lift.
  7. Jul 6, 2019 at 8:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    IIRC it was around 375 to 400 per tank.
    That was just at or right before the fuel light would come on.
  8. Jul 6, 2019 at 8:46 PM
    Ten Rounder
    Ten Rounder Old Man and his Dog
    Southwest Montana
    20 TRD Offroad, 19 4Runner Premium SR5
    Heated seats, It's Montana
    4x4 vs 2x4, most forget some of drag around an extra axle. I saw 400 once, a long trip DOWN the Salmon River, then down the Bitterroot. Then there’s all that extra iron and cap. Average never more that 18, but always pretty close.
  9. Jul 7, 2019 at 1:35 PM
    Dens71TA
    Dens71TA Well-Known Member
    2014 SR5 ACLB 4x4 2.7L A4
    2014 2.7L Auto 4x4 Access cab. Low 400's in the summer time. Cold weather really does a number on MPG. Usually lose around 100 miles per tank during the middle of winter.
  10. Jul 7, 2019 at 1:42 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I converted my 2x4 to 4x4. I kept religious track of my fuel mileage for a long time before and after. I can say definitely that adding 4x4 made no difference in my fuel mileage. I could still get 24-25 mpg if I drove conservatively. The lift and added weight of bumpers and sliders made a little difference (maybe 1-2mpg). Bigger tires just straight killed it. I’m lucky to get 18mpg on the hwy with 33’s.
  11. Jul 8, 2019 at 10:50 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    The right way to compare is MPG, but....
    4WD, and I get 400+ per tank mostly highway and I got 500 highway one time- but that was pushing it :) My odo reads high, so the 500 was really 480, and I'm sure I put at ~21 gallons in it. I "top off" the tank by ~2 gallons after the first click. In the winter, if I use it as a daily driver for work, 15 miles one way, the mileage suffers as said- and 400 probably wouldn't happen.
  12. Jul 8, 2019 at 11:00 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I usually get 360-400 miles (580-640 km) before the fuel light comes on, which takes about 17.5 gallons (66 liters) to fill. My average MPG has been around 22.5 for the past couple years. Fuelly shows higher average MPG because that is a historical average for my vehicle and includes the good old days before blended fuels (E10).
  13. Jul 8, 2019 at 11:07 AM
    Nate31
    Nate31 [OP] Member
    2.7 Tacoma
    Well then my gas gadge was all messed up because my gas light use to turn on at 420km then I noticed the gas gadge started to slow down and now when I’m around 400km I’m still at 1/4. I’m guessing it’s working right now. I always thought I had a 60 liter tank on my 2010 4cyl because when I’d fill up when the gas light came on I’d only put 55-57 liters in. But then some one told me it’s an 80 liter so I figured I’d ask people to see what’s going on
  14. Jul 8, 2019 at 11:09 AM
    DGXR
    Friend
    Sacramento, CA
    80 liters (21.1 gallons) is correct tank size but you'll never get that much gas in the tank unless it's been drained or replaced (fully dry).
  15. Jul 8, 2019 at 11:17 AM
    Nate31
    Nate31 [OP] Member
    2.7 Tacoma
    Ya I always thought it was 60 because when the light turned on I’d fill it with 55ish liters so it must have been reading wrong then. And now it’s reading correct from what I’m gathering
  16. Jul 8, 2019 at 12:04 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    08 access cab, 5spd.
    19-22 depending on variables.
    4X4 btw
  17. Aug 30, 2019 at 8:26 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    456 when the light came on. Put 18.5 in about 10 miles later. ‘14 2.7lL AC 5M
  18. Sep 10, 2019 at 8:18 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    12.8 gallons at 329 trip a. Right at 27 mpg which would be 486 at 18 gallons, 540 at 20, or 547 coasting to a stop.
  19. Sep 10, 2019 at 9:30 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Usually around 400 miles per if I fill up after the light comes on (which I try to avoid as I like my fuel pump.
    Based on my math I average 21 mpg in town. I have an 06 4cyl, 5spd Mt, 4x4 access cab with camper shell...stock suspension and steel wheels with load E tires.
  20. Sep 10, 2019 at 9:43 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Oh, and the trip up to Ft Bragg had a load of hogwire on the topper roof plus a full bed and cab. ~1000lbs and maybe 850lbs on the trip back. Needed 45psi in the air bags to firm it up.
