4 cylinder 2.7 gurgling noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by LIRR, Mar 5, 2015.
  1. Mar 5, 2015 at 8:17 AM
    LIRR
    LIRR [OP] Member
    Brian
    Pa
    02 SR5 Taco w/alts
    Intermittent gurgling noise coming from the drivers side, I think????? Anyone??
    And there is more!
    Every so often I get a squealing from one of my belts. When I checked the belts for wear 1 looked almost new and the other was also good. Just purchased this truck so I don't know the exact dates on the belts. Any Help Would Be Much Appreciated!
  2. Mar 5, 2015 at 8:28 AM
    LIRR
    LIRR [OP] Member
    Brian
    Pa
    02 SR5 Taco w/alts
    1/4 tension on the belts too????????
  3. Mar 5, 2015 at 11:30 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    wiggle the two idler pulleys, if they have any movement at all to them then replace them. they are notorious fort going bad every 30-40k miles.
    as to the gurgling? don't know but check your fluids, radiator and PS pump, it could be one of these is low
  4. Mar 5, 2015 at 11:55 AM
    markmb45
    markmb45 Well-Known Member
    Mark
    Utah
    99 4x4 Reg Cab 3.4, auto, e-locker
    V6,Auto, e-locker 4runner dash, seats
    When does it gurgle? While running or when it is turned off. Could be low on coolant, I had a 85 4runner gurgled when turned off, Bad Head gasket allowing coolant to boil. Good Luck
  5. Mar 8, 2015 at 5:06 PM
    LIRR
    LIRR [OP] Member
    Brian
    Pa
    02 SR5 Taco w/alts
    Thanks guys, I'll do just that with the idler pulley's and double check my fluids. Truck was running too Mark. Do you think it could possibly be the wrong coolant?????
  6. Mar 8, 2015 at 5:15 PM
    Clearwater Bill
    Billy
    Largo Florida
    The coolant could be wrong chemistry wise, but that would not create a noise.
    After checking the idlers (R&R if required), try pulling of the belts, cleaning the pulleys of any build up, check the belts p/N for proper application and examine.
    If any doubt, just replace them.
    If they look ok, try reinstalling, tension properly, and see what happens.
    Caution; over tensioning belts can damage drive accessories such as alternators. And expensive mistake to make a worn belt quit squealing.
