4 cylinder 2.7 liter DUAL-VVT-i
Discussion in '4 Cylinder' started by Scott K, Jun 18, 2011.
  1. Jul 7, 2011 at 2:06 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Those V-8's and EcoBoost V--6's in full size trucks really get 16-18 MPG in the real world at 75 MPH. Just go to a Ford forum, all kinds of disappointed owners. Yes, there are some that get the 22 or so MPG's on the highway, but they are not the majority. My neighbor has a F-150 with the new better MPG V-8 motor, and his UltraGauge show a 15.6 Ave MPG after 6 months of use. My 4 cyl Taco shows 25.1 Ave MPG since Xmas. At todays gas prices that represents about $18 if his F-150 got the same mileage for every 20 gallons of fuel.
  2. Jul 7, 2011 at 2:30 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Aluminum is not cheap, but I definitely agree that it's way too easy to strip threads out of aluminum.
  3. Mar 12, 2013 at 1:19 PM
    2004TacomaSR5
    2004TacomaSR5 Sentinel Prime
    Jon
    Montana
    2004 Tacoma DCSB & '79 Toyota Pickup 4WD
    My friend had a 89 Mazda B2600 and my truck is like a rocket compared to that thing. He'd usually have to downshift all the way to 3rd on most hills out on the road. I've never had to downshift to anything lower than 4 on hills unless I am towing. This thing has plenty of power for my needs, moves the truck around just fine.
  4. Apr 2, 2013 at 2:26 PM
    EFalco50
    EFalco50 Woah! How did that get here?
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Weather Tech Floor liners, AFE drop in air filter, BFG All Terrain's, Fog lights, Reese Hitch, Undercoating/Rustproofing,
  5. Apr 17, 2013 at 9:45 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Whats the differences between the 1st gen 2.7 and the 2nd gen 2.7? Specs? etc. after searching the forum and google, it doesn't look like there's been much discussion. Was there any improvement?
    Thanks!
  6. May 13, 2013 at 9:58 AM
    Lwb053
    Lwb053 Active Member
    Keith
    Tampa
    2010 PreRunner Regular Cab
    Sorry to dredge up a month-dead-thread, but....
    Exhaust-only variable valve timing is not a performance trick, it's an emission trick. Think about it from the standpoint of what you can change by modifying exhaust valve timing without a corresponding mod to the intake valve timing:
    1) Open the exhaust valve sooner - immediately begins dropping cylinder pressure, there goes torque.
    2) Close the valve sooner - incomplete cylinder evacuation, now you have old stuff taking up space when the next intake cycle starts.
    3) Open the valve later - the exhaust stroke ends up being a partial compression stroke until the valve opens. Another loss of power.
    4) Close the valve later - the intake stroke begins drawing at least some burnt exhaust gas back into the cylinder through the open valve.
    Using #1 or #3 above, you have a loss of power. We know the 2TR-FE is a little torque monster for its size, so these are almost certainly not what's going on.
    However, #2 and #4 can be used to displace fresh air/fuel under given conditions. This is exactly what an Exhaust Gas Recirc (EGR) system does. And by using exhaust valve timing, rather than an external and easily defeatible EGR system, Toyota has ensured that the engine meets emissions requirements for as long as the system is installed and functional.
    Now, when used with variable intake valve timing, there are a LOT more options. But modifying the "goes outs" timing without doing anything for the "goes ins" timings, isn't netting any power.
    The preceeding has been my opinion. Take it for what it's worth, or what you paid for it, which ever makes you happier. :)
  7. May 13, 2013 at 6:54 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Just adding a bit of information here, but the front wheel drive engines are not selectively designed to run in ONLY a FWD chassis. The block can just as easily be installed in a RWD application. The only changes would be in intake and exhaust system routing.
  8. May 18, 2013 at 7:40 PM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    Good info...just wanted to add that I'm not touching another toyota 4 cylinder pickup until toyota at least does DVVT(preferably w/direct injection). The 2TR is just not enough of an improvement over my 3rz to warrant making payments on one.
  9. May 19, 2013 at 8:24 PM
    The Shape
    The Shape Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    As much as I love my truck, I would love to see them make a pickup smaller that the current Tacoma. I would buy it
  10. May 19, 2013 at 9:21 PM
    13Greysled
    13Greysled Well-Known Member
    WA
    13' Taco
    Tint
    I like the size of the 2nd gens, at least with the lifted 4wd suspension. But a more powerfull motor getting the same mpg would definately be feasible and a nice addition to the 4cyl.
  11. May 21, 2013 at 10:58 PM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    When I see those compression ratios....I think of boost/turbocharging ;) if only they would, which I think wouldn't be a bad idea
    Them they can incorporate that into the little scions and a Camry sport or smaller displacement with a turbo still
    I would love to see Toyota put a turbo on a few vehicles of theirs and see how they perform...
    What if they made a Toyotaboost motor
    A stronger 4.0 twin turbo in a tundra? Just makin up some ideas but I think it would definitely be cool if it would be effective
  12. May 21, 2013 at 11:01 PM
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    X2 if I buy another taco it will be a v6
    Not gonna mess with another 4banger
  13. Jun 6, 2013 at 4:22 PM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    I don't mind the 4 cylinder. They're cheaper to buy, maintain, and get better mileage. But I want toyota to actually come into the new millenum and offer DVVT on their 4 cylinder. I think pretty much every family sedan has a more powerful 4 cylinder. This is just toyota trying to keep costs down. But I'm not paying for a new truck if they're gonna be cheap.
  14. Jun 9, 2013 at 7:12 PM
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
    I've got to agree. It's going to take a lot more for me than a new grill and interior.
    They probably want that gap there since they've maintained it for a reason. They've expanded the 2.7 line because that's what the market wants. If you're into performance though it's probably their best upsell to the 4.0. I wish that wasn't the case.
    I hope more and more aftermarket vendors capitalize on this and fill that gap.
  15. Jun 22, 2013 at 6:06 PM
    #35
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
  16. Dec 15, 2013 at 12:05 PM
    #36
    rpriest500
    rpriest500 Member
    Rick
    St. Louis area
    '10 FJ
    Sony NAV/DVD...,
    Finally, I think I found the answer in this post. Am I correct? "Dual" adds variable timing to the exhaust valves also.
    Now, it late 2013. Been a Taco owner since the 70's. First one was the Hi-Lux 1 Ton. The enlargement of the chassis threw me for a loop. Gas prices going up and Toyota phases out their small truck. In 2011 it was new truck time. Passed 100K with '02 Taco. Was offered $9,000 cause it was so clean. In March of 2011 found a new 2010 FJ. Purchased it cause it did not require a new $1,800 camper shell. I was outside my budget already. And sales tax was $1,818! The 4.0 Dual VVT-i is powerful (compared to the previous four poppers). The mileage is better than the old 4 cylinder's at 21.5 overall. The reason I'd consider making a move now that the V6 has impressed me so is interior space. The FJ is so limited. Even with the back seat removed, I can't carry much. I camp and fish a LOT. Had to downsize all my gear. So, while my FJ is still worth a considerable amount, I'm just thinking about going back to a Tacoma. If it was the same "EXACT" motor, I'd do it in a heart beat. This thread answered my concern about the "Dual" thing. Is it a big deal? You tell me. Thank You!
  17. Dec 15, 2013 at 8:16 PM
    #37
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I'm satisfied with the mileage with my 2.7 2TR. The worst I've gotten so far is 20 mpg on winter blend with a fully loaded truck crawling up and down steep narrow canyon roads in first gear. And the best I've gotten is 29 mpg on summer blend freeway driving.
    Greg
  18. Dec 16, 2013 at 6:59 AM
    #38
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
  19. Dec 16, 2013 at 8:36 AM
    #39
    Lwb053
    Keith
    Tampa
    rpriest500
    "Dual" variable valve timing means that both the intake and exhaust sides have the ability to modify the timing.
    In the case of the 2TR-FE, we're single variable cam timing, only on the exhaust cam. This allows a very flat torque curve.
    Adding variable valve timing to the intake cam would typically add a little power, but comes at a weight and complexity penalty.
  20. Dec 16, 2013 at 3:40 PM
    #40
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    That all sounds good except the VVT is on the intake cam on the 2TR. Also any other engine with Single VVT will have it on the intake cam. It's REAL OLD tech. As in my 93 VG30DETT Nissan 300zx engine has it and that was the 3rd year of it. It's more basic but it has it.
