4 cylinder double cab review (Prerunner)
Discussion in '4 Cylinder' started by hwork50, Aug 27, 2010.
  1. Nov 23, 2010 at 9:53 PM
    #41
    Tacotaco
    Tacotaco New Member
    2011 Duoble Cab PreRunner I-4
    I have the exactly same model as yours. I just had two fills so far. The first tank gave me 24mpg and the second one 23 mpg. I drive probably 80% highway and 20% local.
    How did your long trip turn out with the truck?
  2. Nov 24, 2010 at 7:23 PM
    #42
    Concord Mike
    Concord Mike Member
    Concord
    Tacoma
    I got 23 MPG on my all-highway trip down I-5 and up over the grapevine. Not bad. Wasn't carrying much load, just me and my wife, the dog and some luggage.
  3. Nov 27, 2010 at 7:10 PM
    #43
    Bonnet
    Bonnet New Member
    Brian
    Texas
    11prerunnerdblecabsr54cyl
    Bought my 4 cylinder 2011 prerunner double cab short bed at the end of october and so far it has been great! I bought it for good gas mileage (22 mpg after 3 fillups) and occasional light hauling. I doubt I will ever tow anything with it. It is a sr5, automatic, timberland mica. I test drove the v6 and yes couLd tell a bit of difference. But commuting back and forth driving on the interstate the 4 banger suits me well. This is the first Toyota I have owned and have been impressed with the truck. It is very roomy, quiet and maneuvers quite well. The only option I wish it had was a compass and thermometer. After driving various vehicles the past 10 years that had these it took a bit for me to not look around when I get in the truck and not see them.
  4. Nov 28, 2010 at 7:33 AM
    #44
    sweater914
    sweater914 Well-Known Member
    North Dakota
    '09 I4 5spd Access Cab Timberland Mica SR5
    I'm glad you guys bought this option. My wife has been quietly complaining about having to use the clutch on her 2wd AC SR5 5spd and I'm starting to research a replacement. I'd like a DC for the extra space but not the mileage penalty of the V6.
    For the current owners, does the 4spd auto chase gears? What kind of RPM are you seeing on the interstate at 75mph? Have you towed with your vehicles, if so how much weight and at what speed?
  5. Nov 28, 2010 at 6:26 PM
    #45
    Redfish
    Redfish Well-Known Member
    2100 +- RPM @ 75-80mph in the interstate. I tow a 3500lb boat no problems, cant tell its back there. Inclines are an issue when on autopilot but I am starting to think its the autopilot and not the engine as it wont high rev when I dont use the autopilot. Cant beat the gas mileage. You can buy a full size truck that gets the same or better mileage as the v6.
  6. Nov 28, 2010 at 9:14 PM
    #46
    Concord Mike
    Concord Mike Member
    Concord
    Tacoma
    Bonnet - ditto for me. I wish they had the thermometer and compass in the 2011 model. Trying to find an aftermarket thermometer but they all look so tacky. Other than that, my 4 banger is great. I was also amazed at the turning radius. About the same as my old Honda Accord.
  7. Nov 29, 2010 at 8:22 AM
    #47
    Tacotaco
    Tacotaco New Member
    Has anyone tried the truck (DC I4) in snow yet? Since it is RWD and lack power a bit, I am not sure how it performs when driving in snow. Any inputs will be appreciated. We have not had any snow in MD yet. :)...
  8. Nov 29, 2010 at 10:56 AM
    #48
    Ninja14
    Ninja14 Well-Known Member
    Arkansas
    02 Tacoma DC 4x4 TRD OffRoad - 96 4runner 4x4
    I got 16 mpg out of my 05 Tundra AC 4x4 4.7 V-8 with auto trans
  9. Nov 29, 2010 at 7:39 PM
    #49
    scrappletaco
    scrappletaco Damn Deer and Idoit Drivers
    Josh
    Williamsport PA
    2011 reg cab 4x4, Debadged and dirty
    Debadged, Removed Charcoal filter
    Actually the i-4 not having as much power may help you in the snow. It will be easier to keep wheel spin down helping the truck track better in snow plus traction control will help you stay straight. That just my experience with a 4cly 2wd taco in the mountains in PA.
  10. Nov 30, 2010 at 8:24 AM
    #50
    Tacotaco
    Tacotaco New Member
    That's an interesting point. Will wait to see if it works.
    Some other people suggest to put a sand bad in the back to generate extra weight.
  11. Dec 1, 2010 at 2:23 PM
    #51
    Ninja14
    Arkansas
    put your 4 wheeler back there....then if your stuck you still got a ride out
  12. Dec 1, 2010 at 6:10 PM
    #52
    Redfish
    And the newer tundras are getting even better mpgs. The v-6 tacoma should be getting 20mpg + and the 4cyl should get in the high 20's low 30's
  13. Dec 6, 2011 at 3:17 PM
    #53
    martya
    martya New Member
    12 Pre-Runner TRD
    Got mine August 2011. New Mexico - about 4000 to 7000 feet altitude. Have only done 3 tanks of gas. First got 29mpg mainly highway - I was babying it to see what it could do. Was really surprised. Second got 26 mpg on mixed highway at 75 mph and mountain roads at around 35 mph - was also surprised. Third was almost totally in town - got 21.8 mpg. I have cap on back.
    Swapped OE tires for 15" Geolanders. They are just barely broken in and we got lots of snow and ice last two days. Truck does fine in snow, although I would put Blizzaks on it if I lived at higher elevation. On ice the truck is fine, but the tires require driving very slowly. Traction control works. ABS is your friend.
    Blizzaks would also solve the ice problem, and studded tires would be even better. With sticky rubber the truck is very easy to control. I've driven Northern winters most of my life, so base this on lots of vehicles - wish the automatic had a 'creep home' gear, but 1st works.
    Today I took the truck up a very rough dirt road, almost trail with snow on it. Left it in 1st up the hill. Traction control came on only once for about 3 feet.
    I miss the go-for-it of 4x4, but this truck is very well balanced, and I think with good tires it is close to 4x4.
  14. Dec 6, 2011 at 5:28 PM
    #54
    TacoTitan11
    TacoTitan11 Well-Known Member
    Mr. C
    North Carolina
    2012 Tacoma
    2011 double cab prerunner here, with 14k miles, average 23 mpg.....i was hesitant buying it, but glad i did
  15. Dec 6, 2011 at 8:19 PM
    #55
    johnanm
    johnanm Well-Known Member
    Up
    2011 Double Cab 2.7L Prerunner
    Bilstein 5100 @ 1.75" front shocks on stock springs, AFE ProDry drop-in, white DTRLs, Sylvania ZXE headlamps, DeeZee bed mat, Tailgate hose clamp mod, cheap snap craigslist tonneau, Weathertech vent visors, secondary air filter removed, Class III hitch
    Completely agree. Same truck, same mpg
  16. Dec 6, 2011 at 8:33 PM
    #56
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB MGM
    Afe CAI (removed back to stock intake), TSB 4 leaf pack with Firestone Air Bags and Daystar cradels, 3rd OEM HU, Wranger All Terrain Adventure with Kevlar 265/75/16, Cali raised LED pods, Wheeler Off Road Front Bump Stops.
    The main reason why I switched from a 2006 AC 4-cyl to a 2009 DCSB V6 was the lack of power in the 4-cyl.
    In the 4-cyl, highway driving I got 25 mpgs and in the city was 18 mpgs.
    In my V6 I consistantly got 21 mpgs mixed on the 245/75/16 OEM tire, so you don't loose mpgs all that much. When I went up in tire size to a 265/75/16, my mpgs when down to 18 mpgs mixed with 16 mpgs city, but my highway stayed at 21 mpgs so if you keep the tire size small, 245, then you'll be fine.
  17. Dec 10, 2011 at 8:43 PM
    #57
    4X4SUPERWHITE
    4X4SUPERWHITE Active Member
    MA
    Stock,V6 SR5 DC
    stock
    Is Dcab the same as a crew cab? I like the 2011 euro models (Hilux) with crew cab, 4x4, or 4x2, 4cyl, turbo diesel.
  18. Dec 10, 2011 at 11:29 PM
    #58
    MidnightSun
    MidnightSun Active Member
    Tim
    San Francisco, CA
    2002 PreRunner Double Cab
    I drove one in Thailand. 4 Cyl Turbo Diesel. I love it. Plenty of torque.
    I have a 2002 Double Cab Prerunner 4 Cyl.
  19. Dec 10, 2011 at 11:58 PM
    #59
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    You don't need tons of horsepower for snow driving.
    You need traction and a capable driver.
  20. Dec 11, 2011 at 12:03 AM
    #60
    jflan
    Vancouver, WA
    Yeah, DC (double cab) is Toyota lingo for crew cab.
    AC (access cab) is Toyota lingo for king cab.
