4 cylinder manual transmission help
Discussion in 'Technical Chat' started by 08pretaco, May 19, 2012.
  1. May 19, 2012 at 12:50 PM
    08pretaco
    08pretaco [OP] Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I am trying to figure out if on the 05+ 4 cylinder engines, the transmission differs between the 5 and 6 lug.
    From my research online I cannot really tell if there are any differences and just wanted to confirm.
    Reason for asking is because ever since my transmission was replaced, with a 5 lug model ( I can tell 5 lug due to the shift knob ), I have been having a noise in 5th gear just chillen around 50-55 mph. Dealership tells me its nothing to worry about but it sounds like a spun bearing maybe.
    Thanks for the help in advance
  2. May 21, 2012 at 5:45 PM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    According to the factory service manual, the only manual transmission for the '05+ 4cyl is the R155. There is an R155F for the 4x4 models, but it's the same internally, just doesn't have the tail shaft extension housing so the transfer case can bolt up.
  3. May 21, 2012 at 11:22 PM
    jassco
    jassco Well-Known Member
    Boston
    2008 4runner, UrbanRunner Silver
    Isn't the shift knob without the sr5 or trd the same? Those two options come with leather wrapped, so even a 4x4 could have that black knob if no options were added. Only one model with two configurations. Shift knob is option specific.
