4 Cylinder Oil Capacity Not Correct In Manual?
Discussion in '4 Cylinder' started by GrnXnham, Oct 17, 2017.
  1. Oct 17, 2017 at 12:08 AM
    GrnXnham
    GrnXnham [OP] Member
    Tacoma, WA
    2015 PreRunner Auto 4-Banger
    I have a 2015 PreRunner 4 cylinder Automatic.
    The dealership did the first four oil changes but the last couple oil changes I did. I found that when changing the oil, it takes 4.6 Qts of oil to bring the level up to the top line on the stick.
    Strangely, the manual says that it should take 6 Qts of oil when I replace the filter at the same time.
    I've owned a lot of cars/trucks over the years and I have always found the manual to be fairly close on the oil capacity until I changed the oil on this truck. Anyone else change their own oil and notice this? This probably also explains why the dealership kept overfilling it. They read in the manual the capacity and then put in too much!
    Yes, I change the filter also and I also fully drain the oil.
    I can't believe the manual is so far off on the capacity.
  2. Oct 17, 2017 at 6:00 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    What does your dipstick tell you ?
  3. Oct 17, 2017 at 6:03 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    I'd follow the manual honestly. my 2011 says it takes 6 and ive been putting 6 in every change for 100k miles. never a problem.
  4. Oct 17, 2017 at 6:08 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    6 with filter for me
    BassAckwards likes this.
  5. Oct 17, 2017 at 6:09 AM
    jpneely
    Charleston, SC
    also, the dipstick can be a tad difficult to read.
  6. Oct 17, 2017 at 6:16 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah that's weird. The V6 only gets 5.5 quarts so it doesn't make sense in my mind why a smaller engine would get more oil.
    TheCookieMonster likes this.
  7. Oct 17, 2017 at 6:17 AM
    jpneely
    Charleston, SC
    yup, that threw me at first too, but hey, the manual calls for 6 on us. I just follow blindly haha. its worked so far.
    EatSleepTacos[QUOTED] likes this.
  8. Oct 17, 2017 at 6:22 AM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    the manual can be wrong, I had a GEN1 TRD automatic transmission the manual said the trans. takes 2.1 quarts to fill in reality a full pan drain took 4 quarts to fill.
  9. Oct 17, 2017 at 6:44 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    The 2tr-fe takes 6.
  10. Oct 17, 2017 at 2:51 PM
    GrnXnham
    Tacoma, WA
    Okay, so several of you just put in 6. BUT, after you do this and check the dipstick is it overfilled?
  11. Oct 17, 2017 at 2:55 PM
    jpneely
    Charleston, SC
    Yea, mine alsways seems fine.
    5 Lug Fury likes this.
  12. Oct 17, 2017 at 2:56 PM
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    I've always put 6 quarts with a new filter. I don't even fuck with the dipstick.
    BDL5589 and CusterFan like this.
  13. Oct 17, 2017 at 3:45 PM
    Mongoose
    Mongoose Well-Known Member
    Catskill Mts. NY
    The manual says 6 quarts with filter change. I buy the 5 quart jug and a filter. Five quarts with a filter change brings my oil level to 1/2 way between low and full on the dip stick....that's good enough for me as my 2TR-FE doesn't burn or leak oil between changes.
  14. Oct 17, 2017 at 6:56 PM
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    2013 Tacoma 4 cyl.
    Mine takes about 5.2 quarts to be at top marker
    ChocoTaco88 and edgerat like this.
  15. Oct 17, 2017 at 7:01 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You let the engine run for a few minutes for the oil filter to fill up, right?
    Anyway, the manual says the dipstick reading takes precedence over the reference oil capacity.
    ChocoTaco88 and TheCookieMonster like this.
  16. Oct 18, 2017 at 8:25 AM
    TheCookieMonster
    North East
    5.5 qts.
    Plain Jane Taco and SOSC like this.
  17. Oct 18, 2017 at 2:38 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    This, exactly. The oil level is not required to be exactly at the full mark. Anywhere between the two marks is "OK" and 5 quarts is plenty of oil for the 4-cylinder.
    Mongoose[QUOTED] likes this.
  18. Oct 18, 2017 at 2:40 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Im at 222k miles and ive always put 6qts in it when changing the filter as well. Mine burns a quart between changes so i always end up with roughly 5 whenever i change it the next time around.
    SOSC likes this.
  19. Oct 18, 2017 at 2:41 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Yup, critical step.
  20. Oct 18, 2017 at 2:41 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    This ^^
    The capacity of the 2.7 is 6 quarts. It ends up being about 5.5 with the filter, as there usually a bit that doesn't drain out.
    I've own 2 4 banger Tacos before my current rig. 5.5 -5.75 is spot on
