4 cylinder okay with 33in tires?
Discussion in '4 Cylinder' started by tacofox, Dec 21, 2013.
  1. Dec 21, 2013 at 8:47 PM
    tacofox
    tacofox [OP] Well-Known Member
    Isaac
    MO
    11 reg cab 4x4
    So I was thinking about getting a 4 cylinder access cab 4x4 taco but my only question is can it hold up to some bigger tires no bigger then 33in and some off roading.
  2. Dec 21, 2013 at 8:53 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    No problem its all in the gearing.
  3. Dec 21, 2013 at 11:04 PM
    VAYoder4167
    VAYoder4167 Well-Known Member
    Frank
    Lynchburg, VA
    Lifted 04 toyota tacoma sr-5
    Magnaflow dual catback exhaust, 5100 bilsteins all around with 1" body lift and stock coils, 33" BF Goodrich sitting on a set of 15" Alloy Ion wheels
    Yes the 4 cylinder can handle 33s quite easily actually that's what I have and it's a nice setup but you may have to make sure you have the right gearing and maybe end up upgrading your clutch to handle the tires alittle bit better. I'm getting ready to upgrade to a marlin crawler clutch kit and flywheel. Good luck.
  4. Dec 22, 2013 at 7:43 AM
    tacofox
    Isaac
    MO
    11 reg cab 4x4
    Like what kind of gearing? I don't really get that...
  5. Dec 22, 2013 at 7:50 AM
    JLee
    Jerry
    Grass valley CA
    Your rear axle has gears in it when you put larger tires on its harder to turn them. So changing the gears helps you run larger tires with little to no change on how the truck drives.
  6. Dec 22, 2013 at 8:33 AM
    tacofox
    Isaac
    MO
    11 reg cab 4x4
    Is it expensive to do?
  7. Dec 22, 2013 at 8:41 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Yes. A new set up third is about 700 to 800
    Check the stricker in the drivers side door and see what your gear is now. My 4cyl 4x4 came with 4.56 gears and it's not too bad. But going up obviously would help, just can't pay for that now. But I've grown used to it.
    On a closed course both loaded down win camp gear (monte weighed way more) I and a v6 5spd 1st gen drag raced and we both topped out at like 85 ha. And it took forever to get there.
    TLDR: yes it can handle it, it's just slow
  8. Dec 22, 2013 at 8:41 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Yes, but don't worry about it. You'll be just fine on 33"s.
  9. Dec 22, 2013 at 8:46 AM
    BamaToy1997
    Bill
    Navarre, FL
    Basics are, as the tires get larger it takes more "torque" to turn them. By going to a "taller" gear (higher ratio) you are allowing the engine to provide more of it's torque to the wheels. Once you get your truck you can look at the information on it to find the current gear ratio, and then figure out where you need to go from there.
    It really depends on what size, and what brand. I would suggest that if you have never done it, or seen it done, take it to a shop. If you get a 4WD you will have to change out both front and rear. If you just have a 2WD you only have rear gears.
    I would say that on average you would be looking at somewhere between $550-700 each axle. Again that is dependent on labor rate, and the gears that you get.
  10. Dec 23, 2013 at 12:54 AM
    Brooke379
    Brooke379 Well-Known Member
    brooke
    Claremont 909
    03 Something taco
    took out over load leaf spring, double chamber magna flow, Pink emblem, took off most Decals, 4inch fagtech, 4k HIDs, two 10 p1 rockford fostgate. Aftermarket head unit. 3.73 to a 4.10 gearing, Plasti dip the sides, customized headliner, added a flag mount and slapped on a dirtlawz decal
    I took my diff out of axel and took it to yota masters in corona and they upgraded me for 300... If you take them the truck it's more expensive but it's so easy to take it out
  11. Dec 23, 2013 at 3:31 AM
    Brooke379
    brooke
    Claremont 909
    03 Something taco
    Yeah just labor to press the gears into place. I'm not sure what you mean by a kit, they had the gears n only charged for the pressing. There is a link to a form on here on "how to" take out your diff on a first gen. I can send it to you
  12. Dec 23, 2013 at 3:34 AM
    Brooke379
    brooke
    Claremont 909
    03 Something taco
  13. Dec 23, 2013 at 3:36 AM
    Brooke379
    brooke
    Claremont 909
    03 Something taco
    Wait. Darn I'm sorry man I lost the link
  14. Dec 23, 2013 at 7:21 AM
    BamaToy1997
    Bill
    Navarre, FL
    They charged you $300 to change out just the gears? :eek::eek::eek:
    Wow, I only charge $300 for the rear diff of a Tacoma when I do the ENTIRE job. That includes removing and reinstalling the 3rd.
  15. Dec 24, 2013 at 11:39 AM
    Brooke379
    brooke
    Claremont 909
    03 Something taco
    Oh wow... If only you where in Cali hahha
  16. Dec 25, 2013 at 9:03 AM
    BamaToy1997
    Bill
    Navarre, FL
    You could almost afford the drive for the savings. lmao. Any and all TW members are more than welcome to come to my shop. Ladies get a bigger discount :p. (Note the humor there, not the perv)
  17. Dec 26, 2013 at 9:10 AM
    Brooke379
    brooke
    Claremont 909
    03 Something taco
    Hahahahaha and you're in Alabama?
  18. Dec 27, 2013 at 9:48 AM
    BamaToy1997
    Bill
    Navarre, FL
    LMAO, yes, I am in Bama. I was just really being a smart ass. Welcome to come see how us "hillbillies" go wheeling any time you all get tired of sunny California. (Which would be never I would guess, hahaha)
  19. Dec 30, 2013 at 8:32 AM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    My experience:
    05 access cab 2.7 5 speed w/ 285/70/17's
    The truck drove fine around town but once it got off road and into some muck I would have to slip the clutch a lot in 4H from a stop. I found myself going into 4L quite a bit to save the clutch. The 4 cylinder 5 speeds come with 4.11's, if I kept the truck I was thinking about going with at least 4.56's if not 4.88's.
