4 cylinder or V6?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by grmn101, Apr 11, 2020.
  1. Apr 11, 2020 at 6:49 PM
    grmn101
    grmn101 [OP] Member
    So I've decided to get a Tacoma 3rd gen. This will be my first truck. I've been doing research on which model and engine size to get, and everywhere I look they say it depends on your intended use. I will be getting a used model probably from a dealer.
    So my intended use would be to carry stuff in the bed (fitting large thing that would not fit in a SUV or car). I have a motorcycle for commuting to and from work so this would mostly be used only in the afternoons and weekends.
    I do not intend on hauling anything that I can think of.
    Money is a big consideration when deciding on the engine size, and knowing that I will not haul anything it makes me wonder if I even need the extra power. The only reason I'm considering the v6 is because I have heard that the 4 cyl is lacking in power, and I do use my vehicles on the freway alot.
  2. Apr 11, 2020 at 6:53 PM
    BLKYota
    BLKYota Active Member
    2016 Black Sport. 6spd man
    V6 definitely. It’s like motorcycles. If you go to small, you’ll be wanting more soon. And 3rd gens are pricey no matter what. You should get the extra power before regretting
  3. Apr 11, 2020 at 6:58 PM
    lamjam
    lamjam Well-Known Member
    Los Angeles
    2021 TRD Off road 4x4
    when I got mine, I wanted to save money and got the 4, but now I wish I would have just got the 6 from the get go.
    Dagosa, Junkhead, Lucifer1 and 2 others like this.
  4. Apr 11, 2020 at 7:03 PM
    grmn101
    grmn101 [OP] Member
    Thanks for the quick response and input. I do recall I was advised not to get a 300 or lower for a first bike and went with a 500. I am so glad I listened to them and didn't get something that small. I will definitely take that into consideration when making the purchase. thanks.
    Junkhead and Lucifer1 like this.
  5. Apr 11, 2020 at 7:10 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It sounds like the 4 banger will do what you need. I wouldn’t even worry about hauling the full capacity with it. Towing heavy trailers is another story.
    I have owned 3 different 4cyl pickups and they all got the job done, but my current 6cyl taco is a luxury that I would not like to do without given my current needs and wants.
    jetfishn likes this.
  6. Apr 11, 2020 at 7:11 PM
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    Things to think about from a four cylinder owner:
    Where do you live? Elevation and hilly areas are V6 territories. Low elevation and flat lands open up the I4 for consideration
    You mentioned you're not hauling or towing anything, so the 2.7 can again be considered.
    Do you want 4WD and a Double Cab? Four Cylinder isn't even an option.
    If you want RWD then again, the lighter truck makes a four cylinder palatable.
    Do you like to drive fast and are you an (I mean no offense) impatient driver? Probably consider the 6.
    What vehicles have you owned previously? Pretty much, if you've owned a V8 of any kind at any point, you might not like the four. I previously owned a four cylinder Celica and a V6 Chevy Equinox that I drove like a grandma, so getting a four cylinder truck was par for the course for me.
    Acceleration around town between the two at normal (re: legal) speeds doesn't provide that noticeable of a difference given the Four's higher final drive vs. the six. (4.30 vs 3.90 when comparing AT to AT). The six with the Manual is the best way to go for power and power delivery.
    I live in Phoenix, the elevation is low and the grounds are flat. I do hit some inclines going out of town, but the truck just revs to get the job done. I wanted 4WD and didn't need a double cab, so an Access Cab was a no-brainer. I don't really drive fast and I don't consider myself a terribly impatient driver. At highway speeds around here the four cylinder is fine. Travelling the interstate out of town is a different story, so I need to be a bit more patient. Off road is a wash as the four and six are pretty much the same given the limits of traction.
    I sought out my four cylinder and love it. It's a simple engine, there's tons of space in the engine bay for when I eventually have to start wrenching on it, and I'm not a lead footed driver so I'm fine in that regard. I spent $30k and got a brand new, fantastic four wheel drive truck. The SX package has most people guessing I spent $40k and an (admittedly less informed) Tacoma owner thought I owned a TRD Pro.
    But your mileage may vary.
  7. Apr 11, 2020 at 7:11 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I would test drive both the 4 and 6 cylinder models and see what you like.
    shwokee, BRFab, StayinStock and 8 others like this.
  8. Apr 11, 2020 at 7:12 PM
    EYBT
    EYBT Well-Known Member
    Evan
    Oahu, Hawaii
    2014 TRD 4x4
    JBA UCA, Eibach Springs, Bilstein 5100s, 2.5" AAL
    I would go with v6 like others said before, if you get the 4, you might want more later despite using more gas.
    BSFord and shakerhood like this.
  9. Apr 11, 2020 at 7:33 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I have both a V6 and a 4 cylinder (the v6 is a nissan though..) While the 4 cylinder does fine on the freeway, the v6 feels at home there and eats miles like nothing.
    And honestly, the gas mileage isn't that different either. The 4 cylinder is better around town, but that truck 1300lbs lighter and is geared lower, so that isn't really a fair fight. They're about the same on the highway.
    jetfishn and Chew like this.
  10. Apr 11, 2020 at 7:46 PM
    Blackbeard83
    Blackbeard83 Well-Known Member
    Sam
    Massachusetts
    2020 TRD Sport 4x4 ACLB MBM MT
    currently stock
    Welcome to the forum! I think another thing to consider is if you live in an area that has a lot of hills/higher altitude (edit: just saw that @Snaeper mentioned this). The 4 banger may struggle a little bit more. But eitherway, I dont think you can go wrong. Especially, if you don't plan to tow.
    Snaeper and Junkhead like this.
  11. Apr 11, 2020 at 7:53 PM
    Clearwater Bill
    Billy
    Largo Florida
    Exactly
    This. ^
    If you decide the 6 is what you would like better, but the price delta spooks you, either wait and save more or shop a bit older/cheaper.
    As far as personal experience, my 4 cyl 5 lug does everything I want just fine. And the ones with less lug nuts are even cheaper and ride better. (But I also have no need for 4wd.)
    whatstcp and shakerhood[QUOTED] like this.
  12. Apr 11, 2020 at 7:58 PM
    slow TURD I4
    slow TURD I4 Well-Known Member
    SD
    2018 DCSB 2.7
    The 4 cyl will absolutely blow the 6 out of the water when it comes to reliability and longevity. The 4 has a very long record of problem free miles.
    DevilTaco4 likes this.
  13. Apr 11, 2020 at 8:07 PM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    V6 manual trans OP
    mikednw, Junkhead, Lucifer1 and 2 others like this.
  14. Apr 11, 2020 at 8:17 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    While the 2.7 may in fact be immortal, the V6 has proven to be very reliable as well. I mean check out all the threads about problems with the V6...
    159 HP Vs. 278 in a 4500# truck...
  15. Apr 11, 2020 at 8:23 PM
    newb13
    newb13 Well-Known Member
    greg
    winter park florida
    2016 sr5 DCSB v6 blue
    de-badge and tint,tri-fold tonneau,rims and tires
    v-6. i RARELY romp on it but it moves that dbcb very well. :thumbsup::thumbsup: start at s1 and go from there and that bitch goes!
  16. Apr 11, 2020 at 8:25 PM
    Lt. Dangle
    Ohio
    No doubt. I don't know what a 2.7 AC 2wd Taco in the third gen goes for weight wise, but it's gotta be 4000#.
  17. Apr 11, 2020 at 8:27 PM
    RugglesTarlek
    RugglesTarlek Well-Known Member
    California
    basic basic basic 14 AC
    Do the test drive thing. My 4 banger with lots of tools in the back was sluggish on highway onramps and trying to kick past people (hint: you learn not to bother). It's empty now (replaced by a van) and a lot nicer, though I'm not going to say super-quick.
  18. Apr 11, 2020 at 8:28 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    My 2.7 ac 2wd taco said it was 3400 lbs stock no jump seats but with gas and boards and more that I added, it has to be more.
  19. Apr 11, 2020 at 8:30 PM
    Lt. Dangle
    Ohio
    What year?
    According to Toyota.com, a 2.7 2wd AC SR is 3915# lol.
    My TRD OR is 4445# for the record.
    whatstcp likes this.
  20. Apr 11, 2020 at 8:36 PM
    Dammit Evie
    Dammit Evie Evie the Schnauzer
    IDAHO-.-. .-.. .- ... ... .. ..-. .. . -..
    2018 Tacoma TRD Sport 4x4 DCSB A/T MGM
    Exterior Mods: TRD Pro SS catback exhaust | TRD Pro Grille | Redline Tuning hood QuickLIFT | OEM Tacoma bedmat | Black running boards | Derped chrome badges | Me-So Gashole | TRD Pro 17x8Alloy wheels Interior Mods: Black Clazzio Napa Leather seat covers |Aluminum stereo knobs Engine Mods: TRD Pro Intake Air Box Up Coming Mods: 265/70R17 Falken Wildpeak tires
    Absolutely a V6!
    Chew, DAS Taco and BSFord like this.
