4 cylinder spark plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcass77, Apr 27, 2008.
  1. Apr 27, 2008 at 7:50 PM
    bcass77
    bcass77 [OP] Member
    Ft. Collins, CO
    06 SR5 4x4 2.7
    I'm at about 30,000 miles and was going to replace the spark plugs in my 2.7l. Looking at the service schedule, it looks like only the 6 cylinder engines require the plugs to be changed every 30,000. From what I could tell the 4 cylinders don't require the plugs to be changed until 120,000 miles. Is this correct?
    Thanks
  2. Apr 27, 2008 at 7:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its true.....the 4 cyls come from the factory with iridiums already there, so you can change them out at 120k. the v6 comes with standard copper core plugs which need to be changed every 30k.
  3. Apr 27, 2008 at 8:01 PM
    bcass77
    bcass77 [OP] Member
    Ft. Collins, CO
    06 SR5 4x4 2.7
    cool, thanks.
  4. Apr 28, 2008 at 11:38 AM
    pdxyota
    pdxyota Well-Known Member
    Greg
    Newberg, OR
    2005 4x4 5M 2TR-FE SR5 Access Cab Indigo Ink Pearl
    TSB x 2 because first TSB leaf springs broke
    That and the timing chain make this 2.7 pretty solid and easy to drive/care for.:D
  5. Apr 28, 2008 at 2:08 PM
    bcass77
    bcass77 [OP] Member
    Ft. Collins, CO
    06 SR5 4x4 2.7
    May be a dumb question, but is there any reason to worry about the plugs getting seized in the cylinder heads after 120,000 miles? Any need to take them out and put a bit of anti-seize on the threads?
