4 cylinder squeaky/chirpy?
Discussion in '4 Cylinder' started by Lightsped, Oct 7, 2015.
  1. Oct 7, 2015 at 7:14 PM
    Lightsped
    Lightsped [OP] Well-Known Member
    David
    Acworth/Kennesaw, Georgia
    Basic 2wd RC 5 speed
    I have a 5 speed 4 cyl Tacoma. 60k miles. When I am casually accelerating from a stop, I am letting the clutch out as I press the gas. As the clutch is let out, and the truck is at low rpms (idle speed or maybe alittle higher) I get a squeaky/chirpy sound from under the hood. As the rpms get to normal levels the sound is gone. Also, when I go over slight bumps in the road I get the same squeaky/chirpy sound. Even makes the sound if I coast (rolling in neutral - engine speed at idle) over slight bumps in the road. To my ears it sounds like something with the belt, but I checked my belt and it appeared fine. Also this squeaky sound does not happen when the motor is cold.
    Any ideas? I hate to take it to the dealer to diagnose. Figured someone here might have an idea.
  2. Oct 30, 2015 at 10:59 PM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    I think you and I have the same problem...
  3. Oct 30, 2015 at 11:01 PM
    Taco Pete626
    Peter
    Southern California
  4. Dec 9, 2015 at 5:38 PM
    Taco Pete626
    Peter
    Southern California
    I just had my catalytic converter replaced per the recent service campaign for the 2tr-Fe. After they replaced the cat, I no longer hear this noise. Hope this helps anyone out there experiencing anything similar.
