4 cylinder towing 500 miles
Discussion in 'Towing' started by joshdoodles, Oct 18, 2011.
  1. Oct 18, 2011 at 10:56 PM
    joshdoodles
    joshdoodles [OP] Member
    josh
    jonesboro, ar
    2011 prerunner sr5 2.7 access cab
    Doug Thorley header, Afe stage 2 air intake with prodry s filter, Access sport tonneau cover, Steelcraft side steps
    I have a 2011 access cab tacoma prerunner automatic with a 4 cylinder. Im about to take a 500-600 mile from jonesboro, ar to central indiana with my honda rancher in a trailer behind me.. the four wheeler weighs 650 lbs, trailer I figure weighs 800 lbs . My family and gear in the truck weighs probably 500 lbs, and thats probably overshooting it a little. So trailer and atv weighs no more than 1400lbs, well under the 3500 towing capacity. Ive towed with the truck several times with no problem, but no more than 50 miles or so, NOT 1200 miles. My questions are, is it ok to tow it in D as long as im up to 70 miles an hour, I have no way of turning off overdrive, just shifting to 3rd gear and i really dont want to be doing 3200 rpms all the way to indiana! I do not have the trans cooler, no towing package, I had toyota install a hidden hitch frame mounted receiver hitch with 4 plug hookup....anybody make me feel better about this? p.s this is a somewhat flat drive, cruise control ok? as long as were on a flat long road
  2. Oct 18, 2011 at 11:09 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    I dont see a problem, as long as you are towing most of the time on flat ground and with a properly placed/balanced load on your trailer. A lot of the times people will have problems cause of over loading which it sounds like you are not and of course not knowing how to load a trailer. If you know hot to load then the weight that you are going to haul sounds good
  3. Oct 18, 2011 at 11:16 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd be dropping the $100 bucks for a trans cooler.
  4. Oct 20, 2011 at 6:16 PM
    bpurdy
    bpurdy Member
    Bobby
    Duluth MN
    2011 Reg Cab Tacoma 4x4 5 speed
    Heavy Duty Tow Package, Field Logic Graphics Aries Black Grille Guard Ionic Tonneau Cover
    I have a 2.7 I4 tacoma as well and towing with it is no problem. I tow 3500 daily because I tow a lawn service rig all around the hills of duluth. My milage goes way down, but the truck stays cool, and it hauls the weight around with little struggle. My truck is a stick, and its only a regular cab, but you wont have any issues. I have towed up to 6000lbs with this truck for short runs.
  5. Oct 22, 2011 at 12:38 AM
    joshdoodles
    josh
    jonesboro, ar
    thanks for the responses, I can post my experience when i get back so the next guy knows he's good to go..
  6. Oct 22, 2011 at 12:43 AM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    i have a first gen 5 speed, i hauled a trailer weighing a little more then 2k pounds 500 miles + over a steep grade. It did it just fine, couple things to remember. You will be slow as hell and you will suck more fuel then you ever imagined a 4cyl could. I did like 50-55 and got 15-20mpg Slow and steady will win the race and keep your truck alive
  7. Nov 15, 2011 at 4:38 PM
    o5iiawah
    o5iiawah Well-Known Member
    Tim
    Philly 'burbs, PA
    '11 4x2 access cab 2.7l
    Took my 2.7 5-lug from Gainesville, FL to Philly towing a 5x8 U-haul trailer loaded with crap. Bed and cab were also pretty full.
    Truck did fine. I wouldn't worry.
  8. Nov 27, 2011 at 6:23 PM
    joshdoodles
    josh
    jonesboro, ar
    well, im back from my trip, the truck did great, felt very stable and under control, ride actually felt better with the weight. I got between 17.8 and 19.4 mpg..which is good considering the trailer I thought. It held interstate speed strong at 70-75 mph....kicking out of gear only a few times for bigger hills, I kept it in 3rd through town....I put it back in overdrive above 55 mph...did better than i expected through the hilly parts of indiana. It stayed cool and pulled strong.....Im satisfied
