4 H or 4 L
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Alexgloronado, Jul 26, 2020.
  1. Jul 26, 2020 at 5:26 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    You bet, the answers are in the post above and some below. Quite simply, you’ll bind up. On slippery surfaces, the wheel slip prevents this from happening.
  2. Jul 26, 2020 at 5:28 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Imo as long as you run straight in 4wd h on asphalt keeping speeds under 50 you won't have an issue. Its the slower sharp corners that cause the front differential wheels to crow hop on pavement. Thats when chit happens.
    tonered, Taco Supremo and Tacowin1013 like this.
  3. Jul 26, 2020 at 5:29 PM
    Professor D
    Professor D Ex retired lion tamer
    Gregorny
    Mass
    2019 Toyota Tacoma race car
    Yes
    Never understood this it’s like the new kid in class gotta bully him to see if he is worthy of the cool kids? Atleast that’s what happened to me all my life. Even tho I was never new...
  4. Jul 26, 2020 at 5:32 PM
    Iwilltaco
    Under development
    It’s possible some thought he was joking, others, just harmless fun as long as we eventually give good answers I guess
    jlemmond likes this.
  5. Jul 26, 2020 at 5:34 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    A member with 8 posts is probably not joking---some members here have been around so long that they've seen every post 800 times and get this feeling like they own the place so they like to push new people around...am I close here?
    sparkystaco likes this.
  6. Jul 26, 2020 at 5:34 PM
    Taco Supremo
    Taco Supremo Member
    Heath
    Medicine Hat, Alberta, Canada
    2019 DCSB OR AT
    Go Slow Stuff
    I'm no expert on drivetrains and suspension. Probably fine unless you heard or felt something break. Get it checked if you're unsure.
  7. Jul 26, 2020 at 5:35 PM
    Iwilltaco
    Under development
    Perhaps. We didn’t get any. “Use the search function idiot”.....yet
    shakerhood likes this.
  8. Jul 26, 2020 at 5:36 PM
    Tacowin1013
    Arriving in 3, 2, 1...
  9. Jul 26, 2020 at 5:39 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Nah, don't worry about it, it'll be fine, just don't make a habit of it.
    As mentioned, when turning, the tires are traveling a different distance, so they travel at different speeds.
    Not being a wise guy, and I haven't personally read through it all- but, I think the owner's manual does a good job describing. If you don't have a printed version, you can DL from Toyota. Also, check YouTube, I'm sure there's some good videos.
  10. Jul 26, 2020 at 5:44 PM
    Tacowin1013
    there's good youtube vids that help explain, and also i can't pinpoint exactly but there was a HUGE thread here discussing all the 4x4 modes, functions and such as well that im sure would help OP out in the long run
    Chew[QUOTED] likes this.
  11. Jul 26, 2020 at 5:47 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    4X4 is intended for extreme off road use or deep snow only. It should never be used on a surface where traction is good. And that includes wet rainy pavement and even light patchy snow. Use 4X2 for that. For a short distance in a straight line, such as pulling a boat out of the water on a wet slippery boat ramp all is good, but shift out of 4X4 before turning the wheels.
    LO range reduces the gear ratios almost 3X. It is used to pull heavy loads, or for going very slowly in rugged terrain. It doesn't provide any more traction and won't help if you're already stuck. In fact most of the time it makes things worse in low traction situations.
  12. Jul 26, 2020 at 5:53 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Here is the deal it will tell you right away you don't want to do that. When you make a turn the outside rear wheel will try to drive the inside front wheel faster because of the radius of the turn the steering wheel will turn towards the faster wheel and you will know right away. More than likely the tire will slip but it does put undue stress on all parts involved leave it for the mud and snow.
  13. Jul 26, 2020 at 5:56 PM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    tonered likes this.
  14. Jul 26, 2020 at 6:22 PM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    you can 4hi on the fly and maintain up to 60mph. 4lo you need to be completely stopped. i like 4hi better. for my application ill probably never use 4lo. also, just because you can 4hi on the fly dont get it twisted for all wheel drive because its not. if you wanted a taste of toyotas legendary all-time-4wd you need to buy a limited t4r.
    Taco Supremo likes this.
  15. Jul 26, 2020 at 9:18 PM
    #35
    5465
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    This should be a sticky !!!
  16. Jul 26, 2020 at 9:40 PM
    #36
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    essentially what you are hearing is the wheels turning at different speeds and actually tweaking the frame a small amount, and the frame snaps back in to position. It will not harm the truck. Yes you shouldn’t drive 4H or 4L on the highway just because, but your trucks gears and parts are strong enough to handle it once in a blue moon if it happens by accident. People might disagree with me there but your friends truck is ok.
    4H is good for snow covered roads, and off-road. 4L is designed for sketchy and steep situations, or things like pulling your buddy’s stuck truck out of the mud. Basically, the difference in 4H and 4L is the power division between the front and rear and the gear reduction.
  17. Jul 26, 2020 at 9:53 PM
    #37
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    4lo /does/ provide more traction on certain surfaces by reducing minimum wheel speed. This aids movement on sheer ice, as well as technical, slow off-roading such as rock-climbing. 4lo also gives more torque for slogging through deep mud or thick snow. It aids in steep downhill descents as well by allowing more engine braking for each wheel revolution
    tonered and Taco Supremo like this.
  18. Jul 26, 2020 at 9:58 PM
    #38
    Truks4elk
    Truks4elk Well-Known Member
    3rd gen 4x4 OR crew LB
    4h when it’s really slick
    4l when you have to go super slow in slick, rough or steep terrain (Rock gardens and boat ramps)
    2h the other 99.5% of the time.
    Taco Supremo, Jojee117 and AKGSD like this.
  19. Jul 27, 2020 at 5:34 AM
    #39
    zoo truck
    None
    I sort of disagree with some of that. I've use 4wd H for hundreds of miles on the interstate highways when on slippery icy/slushy roads to dry pavement sections for miles during the winter in my toyota pickups, and never had an issue. As far as pulling the boat up a ramp with a steep incline 4wdL has worked for me. I guess it depends how heavy the boat is.
  20. Jul 27, 2020 at 8:05 AM
    #40
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    One thing here. You cannot engage the rear locker unless you are in 4Lo, so this may not be 100% true.
