4 ignition coils gone bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DPR921, Feb 16, 2015.
  1. Feb 16, 2015 at 2:49 PM
    DPR921
    DPR921 [OP] Well-Known Member
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    So i have a 2008 2.7 and it started running a little funny the other day engine light came on then it started running horrible and wouldnt rev over 3k rpms and the engine light started flashing. I parked it in the closest parking lot i could get to and left it. I called today to have it towed to my local toyota shop, i would have tried fixing it myself thinking one of the coils went bad and was going to swap it around and see if the error code followed it, but it is still under power train warranty so i figured id let the toyota shop deal with it. Anyways it turns out it was the coils and it isnt covered under my power train warranty. Also they said EVERY coil is bad and they leaked water through and all the plugs rusted up. The truck only has 68k miles on it and is very clean and well taken care of. Anyone know what would cause every coil to go bad at once or is it even possible?? Thanks!
  2. Feb 16, 2015 at 4:00 PM
    DPR921
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    I forgot to mention its 700 dollars with labor for 4 new oem coils and plugs.........
  3. Feb 16, 2015 at 4:16 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Its hard to even imagine that what they saying is true. Even if coils leaked any water, it would evaporate pretty quickly since engine gets really hot. Those spark plugs don't rust (one thing Toyota got right)
    So not sure how they are making you spend $700 on this. You sure its not banana in tailpipe ?:p
  4. Feb 16, 2015 at 8:35 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I would ask to see the codes they pulled. There should be one for each cyl.
    IE....
    P0301 - CYL 1
    P0302 - CYL 2
    P0303 - CYL 3
    P0304 - CYL 4
    Not saying these are the codes they pulled, but they are common for coil misfire.
    Read your warranty guide and see if maybe this could be covered by emissions warranty which I believe goes to 80K.
    Call Toyota's customer care 800 number and get their take on it as well.
  5. Feb 16, 2015 at 9:07 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    All four sounds kind of ... well crazy. Possible, but still crazy. Even just two at the same time is a little on the edge of reality.
    TnShooter likes this.
  6. Feb 17, 2015 at 2:28 AM
    DPR921
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    Alright yeah thats what im figuring.. im going to call today and tell them to just change the one in cylinder one for the code i got when the light first came on (p0301). And im going to say im very concerned if all of them did actually go at once because it sounds like i have much bigger problems down the line..
  7. Feb 17, 2015 at 9:06 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I'm thinking there is problem with a common ground or power in the harness if indeed there are codes for all 4 coil packs. And I'd say that's a big IF.
    Something smells like fish, to be sure.
  8. Feb 17, 2015 at 10:39 AM
    DPR921
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    So i called them out on it and was told 3 of them arnt male functioned but they dont seal so theyre letting water in and thats why they were going to replace them. Guy yesterday said every cylinder is misfiring.. i said replace the one coil and touch nothing else. Im going to change the plugs today myself and see how bad these really are.
  9. Feb 17, 2015 at 2:34 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  10. Feb 17, 2015 at 4:38 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Kind of need at least one of them to work or it wouldn't run at all.
  11. Sep 30, 2019 at 12:55 AM
    Allstar
    Allstar New Member
    I am having the same problem with not being able to rev over 3000 RPMs I have changed the crankshaft position sensor and then one coil and it revved up for a while but stop revving. Me and my brother decided to go ahead and just change all 4 and see what happens. We do not have water inside the coils. Were you able to get yours fixed and if so what was the solution PS thank you
  12. Sep 30, 2019 at 12:06 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    They are lying too you,get the truck back and fix it yourself.
  13. Sep 30, 2019 at 2:05 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I betting he got it back a long time ago.
    This was posted in 2015 or 4 years ago.
    Lol.... Just giving you hard time man.
    I’ve done it myself.
    Hopefully the OP will come back and help Allstar out.
    He apparently has the same issue the OP had?
