4 inch lift kit?
Discussion in 'Suspension' started by lennythetaco, Jul 16, 2009.
  1. Jul 16, 2009 at 8:58 PM
    lennythetaco
    lennythetaco [OP] Active Member
    does any one know a good 4 inch lift kit for an 09 tacoma 4x4 double cab trd off road
  2. Jul 16, 2009 at 8:59 PM
    Coastie Joe
    Coastie Joe Well-Known Member
    Andy
    NM
    16 TRD Off Road
    RCD Suspension makes a pretty sweet one! :cool:
  3. Jul 16, 2009 at 9:53 PM
    Kenny650
    Kenny650 Well-Known Member
    Your best option would be the Camburg Spindles but you wouldn't be able to run them because you have a 4x4.
  4. Jul 16, 2009 at 11:42 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    So.....this appears to be the best option then. But yes if you have a prerunner the spindles are pimp shit.
  5. Jul 17, 2009 at 5:14 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    X1, get the Total Chaos or Camburg spindles.
  6. Jul 17, 2009 at 8:29 PM
    Kenny650
    Spindles FTW!
  7. Jul 19, 2009 at 3:03 PM
    kris219
    kris219 Well-Known Member
    Kris
    miami
    tacoma trd
    spindle lift with dakar leaf pack, blacked out headlights and tailights, satoshi, debadged, HID headlights n fogs, flowmaster 40 single in dual out
    will you be straight if you just put the spindles on a stock suspension?
  8. Jul 20, 2009 at 12:09 AM
    Kenny650
    if your talking about alignment then yes you will need one. spindles are suppose to keep your stock configuration so you won't be needing UCA's
  9. Jul 20, 2009 at 4:48 AM
    shockittillyareconizeit
    shockittillyareconizeit Well-Known Member
    Dustin
    California
    '07 Coma PreRunner
    Front - Icon 2.5 Coilovers, Maxtrac 4" lift spindles, TC UCA's Rear - Billy's 5100/1.5 AAL, 3" lift blocks MB Predator wheels - 16x8 plasti-dipped matte black Toyo Open Country A/T 305/70/16 Satoshi grille Blacked out badges DTRL Wet Okole seat covers
    You all just answered my questions. Camburg here i come!
  10. Jul 20, 2009 at 8:29 AM
    kris219
    Kris
    miami
    tacoma trd
    no, i mean is it alright to put the spindles on a stock suspension without having to change anything else?
  11. Jul 20, 2009 at 9:03 AM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2018 Tacoma TRD PRO
    As a note to the OP the RCD 4 inch lift will not work on your 4x4 if you have the VSC option. Last I checked with RCD they had not fixed this problem. It causes the onboard computer to freak out. I would verify that the VSC controls do not interfer, as they were testing it again a few months ago.
    I installed Camburg Coil overs and UCAs and I was able to dial it up to 4 inches on my 09 though with no problems and my CV joints are not at extreme angles either.
    Good luck with your choice.
