4 inch lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by quintaco86, Feb 26, 2016.
  1. Feb 26, 2016 at 8:52 AM
    quintaco86
    quintaco86 [OP] Member
    2013 tacoma sport
    Hey everyone i have a 2013 DCSB. Sport and Im about to get a 4 inch lift and want to know if there is any problem fitting a 295/70r17.
  2. Feb 26, 2016 at 10:31 AM
    Pigpen
    Dan
    Northwest Montana
    You should be fine...
    ...as long as you have a sawzall, big effing hammer, angle grinder and can weld.
    Welcome to TW :wave:
    bahndrvr and geekhouse23 like this.
  3. Feb 26, 2016 at 10:32 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    You will get more clearance with a 3" lift :anonymous:
    DustStorm4x4 likes this.
  4. Feb 26, 2016 at 2:41 PM
    quintaco86
    2013 tacoma sport
    Thanks and does anyone have any photos of a 4 inch lift with 295's
  5. Feb 26, 2016 at 2:44 PM
    geekhouse23
    What will the primary use and function of the lift be?
  6. Feb 26, 2016 at 2:46 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    As stated above, your issue with fitting 295s isn't with how much lift you have, a 3" lift will give you enough tire to fender clearance. Your problem would be figuring out the correct backspacing on your wheel to keep the tire from rubbing on the inner fenderwell and cab mounts. A 4" lift would actually make the problem worse because as you extend your upper and lower control arms, you bring the entire hub slightly closer to those obstructions.
    geekhouse23 likes this.
  7. Feb 26, 2016 at 3:32 PM
    quintaco86
    2013 tacoma sport
    Im really just doing it for looks as i dont do a lot of off roading now, but the reason i say a 4 inch lift is because i found one with tuff country that comes with the uca's and everything for less than i could buy a 3 inch and uca's. For rims i plan on keeping the stock ones for now and just getting some spacers.
  8. Feb 26, 2016 at 3:35 PM
    geekhouse23
    :facepalm: @Rock Lobster
    There's a reason those are cheaper; cheaper quality, crappy ride and the list goes on and on.
    Buy once, cry once.
    Let me know your budget and I can recommend you something better that you will be happy with.
  9. Feb 26, 2016 at 3:40 PM
    quintaco86
    2013 tacoma sport
    I am trying to stay under 1500 but thats with tires
  10. Feb 26, 2016 at 3:44 PM
    geekhouse23
    5100's all around with an AAL in the rear for under 2.5" and you won't need UCA's
    But that's on your budget. I give you 6 months or less with "junk country" lift before pure shopping around for something better. Lifting isn't a cheap feat, there's a right way to do it and tuff country, rough country and pro comp aren't it.
    Mr.PowerTrays likes this.
  11. Feb 26, 2016 at 3:49 PM
    quintaco86
    2013 tacoma sport
    What is a really good lift u would recommend that is 3 inch or higher? Im not against saving up and going with the best.
  12. Feb 26, 2016 at 3:50 PM
    geekhouse23
    Full OME kit with new leaf pack and light racing UCAs
  13. Feb 26, 2016 at 3:52 PM
    quintaco86
    2013 tacoma sport
    Ok l will look into it and thanks for the help
  14. Feb 26, 2016 at 3:53 PM
    geekhouse23
    Sure thing. Let me know if you have any other questions.
    @DrFunker doesn't call me "Liftman" for nothing..
  15. Feb 26, 2016 at 3:58 PM
    quintaco86
    2013 tacoma sport
    If i keep the stock rims whats the best size of tire to go with if i get the full ome lift
  16. Feb 26, 2016 at 3:58 PM
    geekhouse23
    Do you want to cut and trim or no?
  17. Feb 26, 2016 at 4:00 PM
    quintaco86
    2013 tacoma sport
    Dont matter
  18. Feb 26, 2016 at 4:02 PM
    geekhouse23
    No trim - 265/75
    Minor to major trimming - 285/75+
  19. Feb 26, 2016 at 4:05 PM
    quintaco86
    2013 tacoma sport
    Thanks again
  20. Feb 28, 2016 at 8:27 PM
    Pigpen
    Dan
    Northwest Montana
    My tires cost more than your budget stated above, and I opted for a less expensive lift. Set your priorities, do your research, then spend your money. Do this right the first time - listen to @geekhouse23
    There's a thread somewhere with all the basic info about lifting these trucks. There are many others which are less consolidated, but have great info (with a few rogue opinions sprinkled in)
