4 inch vs 3 inch lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rigo.rivero, Jun 2, 2018.
  1. Jun 4, 2018 at 12:32 PM
    #101
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    I'm running about 2.25" lift with no cab mount chop and 33's. Lift doesn't equal clearance.
  2. Jun 4, 2018 at 12:38 PM
    #102
    Rigo.rivero
    Rigo.rivero [OP] Active Member
    Rigo
    2018 TRD OFF-ROAD
    Blacked out grill and badges.
    So I should be fine with a 2.5 lift and 285/70/17
  3. Jun 4, 2018 at 12:43 PM
    #103
    yaaj2005
    yaaj2005 Well-Known Member
    Fang
    Sacrament, CA
    2014 Toyota Tacoma TRD
    Every truck is different and every lift is different. Try and cross your :fingerscrossed:... You may clear or might not...
  4. Jun 4, 2018 at 12:43 PM
    #104
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    A lot depends on the dimensions of the wheel you're using and if you get aftermarket UCAs that you can push your castor forward with. I have SPC UCAs and had the alignment shop push my tires as far forward as they can to avoid rubbing on the cab mount.
    The only rubbing I get is at full lock in reverse against the mud flap. If I take the mud flap off I will have zero rubbing.
  5. Jun 4, 2018 at 12:57 PM
    #105
    tincup33
    tincup33 Well-Known Member
    Beaverton, OR
    2021 TRD S AG DCSB
    285/70/17, ICON Stage II, 17x9 Fuel Ripper rims with -12 offset, no CMC or trimming. The only rubbing I had was in the front of the fender liners in two small areas...after 5 minutes or so with a heat gun, big screwdriver handle, and a spray bottle of cold water, the rubbing is no more.
    Rigo.rivero[OP] likes this.
  6. Jun 4, 2018 at 1:12 PM
    #106
    Rigo.rivero
    Rigo
    2018 TRD OFF-ROAD
    Thank you guys for the info!!!
    tincup33 likes this.
  7. Jun 5, 2018 at 12:11 PM
    #107
    BajaTom
    BajaTom Well-Known Member
    Tom
    Utahhhh
    2015 Tacoma TRD OR DCSB 4 door
    OME 2.5 886 Dakkar suspension, ARE shell, with Thule bars and cargo rack,
    +1 very good advice here.
    Good luck and let us know what you end up doing.
  8. Jun 5, 2018 at 1:31 PM
    #108
    Gozer the Gozerian
    Gozer the Gozerian Member
    Portland, OR
    2010 V6 Access Cab 4x4 Off-Road (Mag Grey)
    Well this thread is killing me. I tried to get info on the Ruff Country 4" lift over on TN and didn't get any feedback, and ended up putting it in. 4" lift with spacers and SPC upper control arms up front, and a combination of a short block and AAL in the back (with diff drop). Then put some 33" Pro Comp tires on. Sure, it looks great, but you folks have got me seriously worried about long term consequences. I would say I do "light to medium" off-roading. Only had it on about 2 weeks, and I'm getting some moderate vibration in the 15-25 mph range on city streets. :frusty::facepalm::pout:
    Edit: I was hurried in my decision, and for no real good reason...
    Tacomamike mike likes this.
  9. Jun 5, 2018 at 1:58 PM
    #109
    yaaj2005
    Fang
    Sacrament, CA
    Vibration .. It common you're not the only one, just do some search almost everyone have some source of vibration, and solution. I totally forget... If you're going for a 4"... Should have go with RCD 4-5" lift.... RCD, you don't have to get a UCA right away because it a DB. So total almost the same.
  10. Jun 5, 2018 at 2:02 PM
    #110
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Go 5100s, set to 2.5", and beat the pinch weld. Should be plenty. That's what I'm doing. Picked up my 5100s today! :bananadance:
  11. Jun 5, 2018 at 2:12 PM
    #111
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    The vibe is probably from the needle bearing on the front drivers side. To verify if that is the problem, find a straight section of road and shift into 4hi. If the vibes go away in 4hi, then the needle bearing is the problem. The solution to that is replacing the needle bearing with the ECGS bushing. Search ECGS on TW and you will find a lot of information on this.
  12. Jun 5, 2018 at 3:24 PM
    #112
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Wow ....where to start ? Do what many have done , cut your losses now before you do some serious damage $$$$$ wise !
    Put a real suspension under your rig !
  13. Jun 5, 2018 at 3:55 PM
    #113
    Fedup13
    Fedup13 Well-Known Member
    San Diego
    2021 OR DCSB 4x4
    Looks good though
    jdsundevil[QUOTED] likes this.
  14. Jun 5, 2018 at 5:32 PM
    #114
    Gozer the Gozerian
    Portland, OR
    Okay, so I just realized there are two similar sounding brands, Rough Country and Tuff Country (I don't have much familiarity with either and confused them). I believe the OP's question was about the Rough Country. What I put on my truck in the Tuff Country. Is that better? Removing/swapping the lift to under 3" would be costly (would require also swapping tires). I hope this isn't thread jacking; seems possibly pertinent to the OP.
  15. Jun 5, 2018 at 5:44 PM
    #115
    Tacomamike mike
    Michael
    That’s kinda like asking goneria or syphilis !
    They both have a lot of problems!
    Cut your losses and get bilstien 5100 all around and OME coils ...a few options on those. Camburg/ totalchaos UCA’s and Dakar’s in rear. Or just 3leaf AAL you will be happy and it’s the best bang for your buck on a budget .
    tcjacado likes this.
  16. Jun 5, 2018 at 5:46 PM
    #116
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    @tacomamike....I thought that was true or at least at the top of the list?
    Joe23[QUOTED] likes this.
  17. Jun 5, 2018 at 5:53 PM
    #117
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    Did you measure before and after from center of front hub to bottom of front fender? I’d be really surprised if you actually got 4 inches of lift and your ride would be absolutely horrible.
  18. Jun 5, 2018 at 7:13 PM
    #118
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much for your recommendation @Clearwater Bill we truly appreciate it! :D:D:D
  19. Jun 5, 2018 at 7:15 PM
    #119
    HeadStrong Off-Road
    Thank you so much for your recommendation @Tacomamike mike we truly appreciate it! :headbang:
  20. Jun 5, 2018 at 8:51 PM
    #120
    Tacomamike mike
    Michael
    Fox/king are at top, it’s subjective as to who’s saying it . I like to think my Fox DSC are the best. But then again they’re mine :).
    Icon are great in my opinion, I have them under one of my Jeeps .
    FOX FOX
    helix66[QUOTED] likes this.
