4 inches of lift. HELP.
Discussion in 'Suspension' started by Packattack116, Aug 15, 2019.
  1. Aug 15, 2019 at 10:06 AM
    Packattack116
    Packattack116 [OP] Active Member
    Devin
    Mississippi
    2016 Tacoma TRD Off Road
    3 to 1 leveling. 1.25 Spacers. 10 Sundown Audio sub. 285/75/16 Cooper AT3 XLT
    I want 4 inches of lift and I know the simple route is rough country but those are cuss words on this page I see so can somebody tell me what else I need of better quality but around the same price? Basically what I need to tell my shop when I go in to order everything I want done.
  2. Aug 15, 2019 at 10:13 AM
    Ossaris
    Ossaris A Bad Person Doing Good Things
    Aliens
    SoCal
    2016 TRD OR 4x4 w/ 6112s & 5160s
    Lights for days! Sasquachified!
    That's a bit of a tough ask. If you're willing to put a bit more in, you can grab a Bilstein kit that'll give you roughly what you'd want
  3. Aug 15, 2019 at 10:15 AM
    Ossaris
    Aliens
    SoCal
    It also depends on what you want and how you're going to use it. If you have no intention of offroading or aren't doing anything crazy, RC kit will probably suit you just fine if you just want the lift. If you want something more useful, it's going to come down to a get-what-you-pay-for argument. Just my .02
  4. Aug 15, 2019 at 10:18 AM
    Packattack116
    Devin
    Mississippi
    Yeah I want a quality lift, i don’t really do off-roading at all at the moment but I might later down the road but that’s unsure. But I just don’t want to buy a rough country and later on have nightmare issues with alignment and stress on axles and what not
  5. Aug 15, 2019 at 10:27 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Cheap lift steals from droop, it doesn't magically add to overall travel. A 4" lift means a front tire could become airborne instead of stuck to the road. Plus you'll never see another spec alignment.
  6. Aug 15, 2019 at 1:21 PM
    Ossaris
    Aliens
    SoCal
    Grab a set of Bilstein 5100s with 5160s in the rear. You can AAL if you want too. That'll give you more like 2-3 inches but will be superior to RC lift in quality for about the same price. If you want better fronts, go for the 6100s or 8112s. I'm running the 6100/5160 kit myself and am quite happy with it for the majority of what I do.
  7. Aug 15, 2019 at 1:23 PM
    Shellshock
    Iowa
    The real question is why do you need 4” over 2-3”?
    0uTkAsT likes this.
  8. Aug 22, 2019 at 11:09 AM
    BLACK04TRD
    BLACK04TRD Well-Known Member
    Bethesda, MD
    2004 Tacoma TRD, 3.4L, 5spd -- SOLD
    Stock AF
    I would start by deciding what size tire you want to run and then getting the minimum amount of lift to make those tires fit. No sense putting on a 4'' lift that will mess up your driveline angles if a 2 or 3 inch lift would suffice.
    Just my 2 cents.
  9. Aug 29, 2019 at 3:41 AM
    NorthShoreTacos
    NorthShoreTacos Well-Known Member
    Hawaii
    I just picked up a BDS 6" Kit with Fox 2.5 front and 2.0s in the back. Going to replace the leafs in the back and toss the blocks the kit comes with (also tossing the front spacer). Check BDS I believe they have a 4" Kit also. I guess a Drop Bracket is all the same, but the BDS parts look quality over the Rough Country. I would look into BDS, if moneys tight I believe the ProComp Kit is better then the RC Kit. Just what I have learned myself, I haven't installed the kit yet.... Waiting for rims. Good luck on here, all the 2-3" purists are going to act like they are Baha Pros, and have never driven there truck to the local mall. If your interested I can send you pics of the Kit PM me.
    Packattack116[OP] likes this.
