4" lift. Do I need shims?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thyces, Jun 1, 2017.
  1. Jun 1, 2017 at 5:01 AM
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    I currently have a progressive aal in the rear sitting at 1 3/4" lift. I purchased some fox 2.0 meant for a 4" lift that comes with 2" blocks. Am I ok to install this combo and then buy some shims when I get around to it or should I not even think about it until I get the shims. Secondly.... Do I really even need the shims?
  2. Jun 1, 2017 at 9:57 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Anyone?
  3. Jun 1, 2017 at 9:58 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    Are the blocks tapered?
  4. Jun 1, 2017 at 10:00 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Does it vibrate?
  5. Jun 1, 2017 at 10:02 AM
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    You'll need a carrier bearing drop to if you have vibrations at that height.
    txtaco87 likes this.
  6. Jun 1, 2017 at 10:09 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    I got slight vibrations on highway with just AAL. Wheel balance helped some but added CB drop and better still but still noticeable above 65-70.
    Just dropped a shim in yesterday when I did the Ubolt flip so hopefully this is the last time messing with it.
    Search web /forum for measure driveshaft angles and you can check the driveline yourself. But my guess would be you need something with 4" lift.
  7. Jun 1, 2017 at 10:16 AM
    Pigpen
    Dan
    Northwest Montana
    4" on a prerunner or 4x4? Either way, you'll need to rectify the driveline angles. 4" suspension lift on a 4x4 is a no no though.
  8. Jun 1, 2017 at 10:17 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I have a poly carrier bearing I'll be installing along with the shocks and blocks. I don't currently have the stuff with me (being delivered) so I cant say about the blocks being tapered
  9. Jun 1, 2017 at 10:17 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Please elaborate
  10. Jun 1, 2017 at 10:18 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I have a 4x4
  11. Jun 1, 2017 at 10:22 AM
    Pigpen
    Dan
    Northwest Montana
    With a lift over 3", your CV joints will eat themselves. If you look in the 35 and 37 inch tire threads, those guys are all running 2.5-3" suspension lifts and they cut and hammer away anything that rubs.
  12. Jun 1, 2017 at 10:24 AM
    justdoit
    Colorado Springs
    4" are normally drop down kits.
  13. Jun 1, 2017 at 10:25 AM
    Pigpen
    Dan
    Northwest Montana
    I have minor driveline vibes with a 3" lift in the rear and CB drop. I'm just going to say fuck it and put in a single piece drive shaft.
    Thyces[OP] likes this.
  14. Jun 1, 2017 at 10:27 AM
    Pigpen
    Dan
    Northwest Montana
    Up front I have 2.5" lift and .5" body lift. Going to bump the suspension up to 3" this summer. It was close to 3, but armor, etc has weighed it down.
  15. Jun 1, 2017 at 10:30 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    This is just the rear. At front I have a 5100/885/spc uca combo sitting at about 2.5 lift. I have a full set of rci steel skids coming that should drop me down to 1 3/4-2" in front so I might go with some 886 coils. I run 265 70 17 and am not planning on changing tire size and have no rub. I would like to be at 2.75 in the front 3.75 in the rear. I do carry a leer and some tools all the time in the rear plus the gas tank skid I'm sure I'll be able to get to where I would like to be. My worry is the drive line angles.
  16. Jun 1, 2017 at 10:32 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    One piece seems to be the only way to really get rid of vibes.
  17. Jun 1, 2017 at 10:35 AM
    Pigpen
    Dan
    Northwest Montana
    On 5100s you can run up to a 1/2" spacer (1" lift) without running out of up travel. I have 885/ 5100// 1/4" spacer right now.
    I keep about 500 pounds in the bed of my truck at all times and it sits at 25" from center of hub to fender. That's 3" of lift. It has severe rake - the back looks too high IMO. And I have vibes, even with the CB drop.
  18. Jun 1, 2017 at 10:36 AM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    You'll also want extended rear brake lines if your going up 4"
  19. Jun 1, 2017 at 10:36 AM
    Pigpen
    Dan
    Northwest Montana
    Shims will be a must. CB drop probably will too
  20. Jun 1, 2017 at 10:37 AM
    Pigpen
    Dan
    Northwest Montana
    Depends if droop is extended too.
