4" lift. Do I need shims?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thyces, Jun 1, 2017.
  1. Jun 1, 2017 at 10:38 AM
    Pigpen
    Dan
    Northwest Montana
    Just raising up on stock springs won't need new lines.
  2. Jun 1, 2017 at 10:38 AM
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    What leaves are you running?
  3. Jun 1, 2017 at 10:39 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Yeah just the tsb leafs and a wheelers progressive aal.
  4. Jun 1, 2017 at 10:39 AM
    Pigpen
    Dan
    Northwest Montana
    Full Dakar pack with AAL and airbags with cradles
    Thyces[OP] likes this.
  5. Jun 1, 2017 at 10:41 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    That would explain your lift.... I'm probably going to get a local company to make me some custom leafs to match my desired height/load.
  6. Jun 1, 2017 at 10:41 AM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    True, if running factory leafs with blocks he might be able to get away with it. My new version dakars have quite a bit of travel compared to my factory and when I have it on the lift at work with rear end hanging, the extended brake lines would be tugged on if the rear had another inch of droop.
  7. Jun 1, 2017 at 10:44 AM
    Pigpen
    Dan
    Northwest Montana
    Yeah. I have 3" extended lines (23" I believe?). I have some 29" lines I'm going to install next time I bleed my brakes. Then I'll pull a couple of the retainer bolts in top of my leaf packs so they'll really flex.
  8. Jun 1, 2017 at 10:45 AM
    Pigpen
    Dan
    Northwest Montana
    Running B110 shocks in the rear
  9. Jun 1, 2017 at 10:55 AM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    :muscleflexing: Gotta get that extra flex! I think I have the 23" on as well, also running extended b110-5100
    Pigpen[QUOTED] likes this.
  10. Jun 1, 2017 at 11:16 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I Just measured. I'm at 23 1/4" center of hub to fender. So with a 2 inch block I will be 25 1/4 which is actually not that bad..... Still need shims? I guess I would have to measure angle to determine?
  11. Jun 1, 2017 at 11:31 AM
    Pigpen
    Dan
    Northwest Montana
    Measuring the angles after install is the only way to be sure what shim you'll need, but you're going to need shims.
  12. Jun 1, 2017 at 11:46 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Cool. Thanks for all the info.
    Pigpen likes this.
  13. Jun 1, 2017 at 11:54 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    One more thing.... Since I won't be running the full height recommended for the shocks, should I make a spacer for my bump stops so the shock doesn't bottom out?
  14. Jun 1, 2017 at 11:57 AM
    Pigpen
    Dan
    Northwest Montana
    Yes. I use my air bags as extended bump stops. One hard hit could destroy your shocks if they bottom out. This has been known to happen on pavement.
  15. Jun 1, 2017 at 11:58 AM
    #35
    Pigpen
    Dan
    Northwest Montana
    Of course it can happen off road too
