4" lift rear shocks, 4" uptravel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thyces, Jun 20, 2017.
  1. Jun 20, 2017 at 8:40 AM
    Rusty15Tacoma
    Rusty15Tacoma Well-Known Member
    Rusty
    San Diego
    2015 MGM TRD Offroad
    Bilstein 5100 w/ OME 886, Built Right UCA's, Dirt King LCA's, 5125 2"-2.5" lift rear shocks, Alcan HD 8pack rear, Level 8 Guardian 16" wheels, blacked out badges, 285/75R16 Hercules Trail Digger, 20% tint, BHLM Retrofit.
    Is your truck level at 4"? Also, hub to fender and shock travel/length isnt the best way to measure. If you can, you should pull the shock and flex out the suspension. Measure at fully extended and fully compressed from shock mount to shock mount. That will give you what size shock you need.
    Looks like the shock is a 12" shock mounted in the stock location. You could raise the mount and even it out, like most running extended shocks. Hard to tell, but those blocks don't quite look 4" either, but I'm also looking at it on a small ass screen.
    Should take 45min to figure it out.
    ChadsPride likes this.
  2. Jun 20, 2017 at 9:01 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    measure your bump stop distance, what is it?
  3. Jun 20, 2017 at 9:34 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    this is why you measure shit before you buy shocks..... you bought shocks that were WAY WAY too long for your setup.
    ChadsPride and agunday21 like this.
  4. Jun 20, 2017 at 9:46 AM
    paranoid56
    San Diego
    14 double cab taco
    no, this is why you buy the longest shocks and make new mounts to fit :D
    ChadsPride and Thyces[OP] like this.
  5. Jun 20, 2017 at 10:26 AM
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    blocks are 2" with 2"aal
  6. Jun 20, 2017 at 10:26 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    6 1/4"
  7. Jun 20, 2017 at 10:27 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    So get a relocate done?
  8. Jun 20, 2017 at 11:14 AM
    nd4spdbh
    SoCal
    Lets do some math.
    4 inchs of shock travel left
    6.25 inches of space between bumpstop and frame, not to mention compression of the bump stop (lets say 1/2 the height of the bumpstop so add an inch and a half to 2 in more) so a total of lets just keep round numbers of 9in of possible up travel
    Yeah you need to get proper length shocks, relocate the top mount of your current ones, or extend your bumpstops SIGNIFICANTLY (not recommended)
    What you really need to do is pull a shock out and go fully compress that side, Measure from the center of the bottom eye, to the bottom mounting surface of the upper shock mount. Then subtract 3/4in for saftey and that is your MAXIMUM compressed shock length.
    That is the only measurement you need, as at that point the extended and travel lenghts are essentially determined by the bounds of your compressed shock length.
    agunday21 likes this.
  9. Jun 20, 2017 at 12:43 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Thanks for all the info. I thought they looked way too compressed. If you look at my original post you'll see I'm installing sumo springs. They are 6" and can only compress to 3". I am going tonight to a fabricator to talk about a shock relocate. Until then the sumo springs will stop from bottoming out.
  10. Jun 20, 2017 at 2:57 PM
    nd4spdbh
    SoCal
    But if you have 6.5in of space between the sumo spring and frame, and only 4 in from shock bottom the sumo spring doesnt even touch!!! (unless i read your measurements wrong)
  11. Jun 20, 2017 at 3:14 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    As it sits the sumo is in contact with the frame. 3" max compression leaves me 1" to spare.
  12. Jun 20, 2017 at 3:48 PM
    Rusty15Tacoma
    Rusty
    San Diego
    I think you need to reevaluate your setup if you haven't already purchased the springs
  13. Jun 20, 2017 at 3:50 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Springs are already installed. I'm going to do a mount relocate and Dakars eventually. I think she can hold for now.
  14. Jun 20, 2017 at 3:52 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    This is totally not ideal. But I don't have time right now to remove and reinstall my 5100s. Plus... I really like it at this height.
  15. Jun 20, 2017 at 4:02 PM
    #35
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I want to use the sumo springs for sure and would like to keep the 4" lift in the rear. What set up would you suggest? I would imagine the shock relocation would solve my issues.
  16. Jun 20, 2017 at 4:06 PM
    #36
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    After reading this entire thread and looking at the pictures, I wouldn't take that rig wheeling any time soon. You are going to crush a shock housing no doubt about it. They are way too long.
  17. Jun 20, 2017 at 4:13 PM
    #37
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Ok.... Can someone please answer my previous question? Will a shock relocation bracket solve this issue? I'm meeting up with a fabricator tomorrow.
  18. Jun 20, 2017 at 4:14 PM
    #38
    WOODEX M.E.
    Corey
    Maine
    Well most likely it will help, but thats really not the proper way to fix this.
  19. Jun 20, 2017 at 4:14 PM
    #39
    Thyces
    Ontario
    2009 DCLB TRD Sport
    What would you suggest?
  20. Jun 20, 2017 at 4:16 PM
    #40
    WOODEX M.E.
    Corey
    Maine
    Buy the correct shocks for your truck. Its much better than grinding and welding parts of your frame.
    Rear shocks are cheap.
    TxFireman likes this.
