4" lift rear shocks, 4" uptravel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thyces, Jun 20, 2017.
  1. Jun 26, 2017 at 1:10 PM
    #81
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    @Thyces the sumo springs are your bumps aren't they? You had more lift than me in the rear and I have dakars. I don't know the shock length differences between yours and my nitro chargers but your atleast 2-3 inches higher than me....you shouldn't be bottomed out. Plus the sumo springs pretty much take out any possibility of you bottoming out.
    Should of measured when we had the chance.....we kinda got pre occupied with fixing other stuff
    Best bet is to remove the shock flex the absolute shit out of it and measure from eye let to eye let.
    Thyces[OP] likes this.
  2. Jun 26, 2017 at 1:12 PM
    #82
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    By your calculations I should have no problems then. When fully flexed out I have 1 3/4 inch.
    tacoma16 likes this.
  3. Jun 26, 2017 at 1:13 PM
    #83
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Some people don't like to read. Myself included
    tacoma16[QUOTED] likes this.
  4. Jun 26, 2017 at 1:19 PM
    #84
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    @Thyces
    Its as simple as this and like stated before. Measure from the top of your bumpstop to where the bumpstop hits your frame add how much your bumpstop is quoted to compress to that initial measurement.
    Now look at your shock. Measure the amount of shock shaft showing, subtract a 1/2 to 3/4in for a margin of error, and that is how much shock compression you have left.
    If the first measurement you took is greater than the second, you need shorter shocks, as like stated again, its only a mater of time before a shock buckles when its being used as a bumpstop.
  5. Jun 26, 2017 at 1:30 PM
    #85
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Cool. By these calculations I'll be good unless I carry over 1500lbs in the back.
  6. Jun 26, 2017 at 1:36 PM
    #86
    nd4spdbh
    SoCal
    You have to consider the fact when at flex, its only one bumpstop holding the rear weight of the entire truck.
    Again, you really need to pull a shock out, to fully flex the truck (lift a tire off the ground and compress the side that doesnt have a shock) and take a measurement, if you did this the thread would be over in about 3 posts instead of 5 pages.
    WOODEX M.E. likes this.
