4" lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RedTaco02, Nov 4, 2008.
  1. Nov 4, 2008 at 7:02 AM
    RedTaco02
    RedTaco02 [OP] That's an old Taco
    Manor, TX
    17 TRD
    Superhides seat covers, ARB front Bumper, Dual Batteries
    :confused: I have a 2.5" lift on my truck right now. I'm curious if there is a 4" lift that does not require the drop down bracket. I'm not worried about the rear leafs, thats an easy fix. Just need some more room for my tires. Anything will help. Thanks.
  2. Nov 4, 2008 at 7:06 AM
    seancanterbury
    seancanterbury Well-Known Member
    SLC, UT
    02 4X4
    A body lift will give you some more tire clearance. I had the same problem here with 33's with a 3 inch lift. just not enough :p
  3. Nov 4, 2008 at 7:13 AM
    RedTaco02
    Manor, TX
    17 TRD
    Yeah thats where I'm at too. Not really big on the whole body lift thing.
  4. Nov 4, 2008 at 7:45 AM
    RedTaco02
    Manor, TX
    17 TRD
    Does anyone know if I could go with a 1.5" spacer on top of my coilovers? If used with diff drop kit?
  5. Nov 4, 2008 at 7:52 AM
    OFFROADCARWASH
    OFFROADCARWASH Well-Known Member
    Jacktown, Mississippi
    2000 Taco customized
    Custom badged black, 100watt LOUDSPEAKER mounted under toolbox, UWS toolbox, All terrain Tires, K&N Ram Air Intake, HUGE flood lights mounted to Tool Box, Cobra CB radio, Francis Antenna, HELLA Blue Headlights, 12 Pad LEDS in Cab lights, Husky Liners, Tinted Windows at 15%, Thrush Glass Pack (burned Out) with 4inch Tip..Remote Crank and Intry, 2 12" subs, Blacked out head lights and tail lights.
    6inch lift is the best all around. looks great and good with tires.
  6. Nov 4, 2008 at 7:54 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Stacking lifts is bad.
  7. Nov 4, 2008 at 7:58 AM
    RedTaco02
    Manor, TX
    17 TRD
    Yeah, just called toyotec. I guess I can just raise my coilovers upto 3.5". Didn't know that.
  8. Nov 4, 2008 at 8:00 AM
    LonghornTaco
    Minnesota
    Have you installed the diff drop? I have the adjustable coilovers as well, but I was told by a lot of people here that 3.5" is really too high. Puts too much stress on the CV joints.
  9. Nov 4, 2008 at 8:48 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    You'll be changing CVs like you change underwear if you go over 3" without a diff drop.
    (that is for those that do change underwear)
  10. Nov 4, 2008 at 9:57 AM
    seancanterbury
    SLC, UT
    02 4X4
    yeah I'm not too big on the body lifts either. Kinda depends on your budget
  11. Nov 4, 2008 at 10:36 AM
    SRFIVE
    SRFIVE Well-Known Member
    Upstate NY
    '09 SR5 AC
    I have 3" (spacer) lift up front, with 1" diff drop and high angle CV's. I run 285/75/16 with no interference issues, just a little frame rub when lock to lock, but that's becasue I have 4.48" backspacing.
    Anyway, I think the problem you'll run into with a higher lift (without dropping or changing the control arms), is alignment. You can only change your control arm angle by so much before your alignment cams run out of adjustment.
  12. Nov 4, 2008 at 11:34 AM
    RedTaco02
    Manor, TX
    17 TRD
    I called Camburg about my coilovers. I guess I can adjust them out to 2 7/8". I'm only at 1 1/2" maybe. Now I'm having a hard time finding shackles to fit on th eDeaver leafs I have in the rear. Any suggestions? Most peoples shackles only fit specific springs.
  13. Nov 4, 2008 at 5:38 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    daystar shackles might fit.. I have set on my 96 that worked with stock and pro-comp leaves
