4" lifts?
Discussion in 'Suspension' started by gearhead06, Apr 30, 2010.
  1. Apr 30, 2010 at 4:37 PM
    gearhead06
    gearhead06 [OP] Active Member
    josh
    columbus
    07 Tacoma v6 4x4
    I have a 3" lift from suspensionconnection.com... I have 4.88 gears Front and Rear with 2 Arb Lockers.. Im running on some 315/75R16 FIERCE ATTITUDE M/T...
    Does any one know where to find like a 4" lift kit at i have a 3" now and its ok but i still rub in some places i need a little more ground clearance and an inch or 2 ill get a little more when i get my new tires i have 32" tires now im looking to get 35" tires so i need to go up some but i really dont want to go up to a 6" lift only if i have to.....
    so if you know of anything plz let me know...
    Thanks
  2. Apr 30, 2010 at 4:52 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    There is a RCD 4.5" lift but I don't know if it will fit 35" without rubbing.
  3. Apr 30, 2010 at 4:54 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    I think some people still rub with 35s with a 6 inch lift.
    Use some more punctuation marks. Little confusing reading the post.
    Good luck with your search.
  4. Apr 30, 2010 at 5:01 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    im pretty sure that you wont be able to clear 35's with only a 4" lift. since your 4x4 spindles are out. theres the 4.5" rcd kit, which runs a few hundred cheaper then doing a procomp stage 2 lift, which is 6". So if you really wanna clear 35's then your gonna have to go with procomp or fabtech. from what everyones said..you will still have to do some trimming with a 6" lift to clear the 35s.
